AlexTheBug Samba Member
Joined: July 15, 2021 Posts: 13 Location: San Jose, CA
Posted: Thu Dec 05, 2024 4:36 pm Post subject: Headlights tripping out |
Hey guys -- been struggling with my headlights for my '68 beetle.
Not too long ago, they worked fine. Then I started noticing that they would turn on and off while driving. When the headlights turned off, the blue high beam indicator would turn on, but the high beams themselves were not actually on. Sometimes, just the left side would stay on and the right side would go out -- and the high beam indicator light would come on. I also found that they would go back to normal if I slightly pushed in the switch a bit. I was able to get by with that for a while -- finding just the right spot on the switch to get the headlights to work correctly.
I should mention that the high beams were working fine all along -- when I turn them on, they always came on and the indicator showed appropriately. Similarly, the running lights always worked correctly.
Finally my little fix stopped working and no matter what I did with the switch, only one headlight (or none) would turn on, and the blue high beam indicator was always on when I engaged the headlights.
I replaced the switch, going from the original '68 switch to a '71 switch from JBugs with the "X" terminal. I dutifully jumped power from the 30 terminal to the X to power the headlights. At first, it worked correctly. But then, as I was driving away, the issue came back -- one headlight, blue HB indicator.
I've checked all of the fuses. I've fiddled with the wires (essentially leaving everything in place). Should I try replacing the relay? Other ideas? |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17629 Location: Left coast, Canada
Posted: Thu Dec 05, 2024 5:49 pm Post subject: Re: Headlights tripping out |
I bet the switch is loose in the dash. Or the switch is falling apart. _________________
bsairhead Samba Member
Joined: October 08, 2008 Posts: 4521 Location: viroqua wi.
Posted: Thu Dec 05, 2024 6:58 pm Post subject: Re: Headlights tripping out |
Bruce wrote: |
I bet the switch is loose in the dash. Or the switch is falling apart. |
Loose in the dash? How would that cause an issue? |
VW_Jimbo  Samba Member
Joined: May 22, 2016 Posts: 11274 Location: Huntington Beach, CA
Posted: Thu Dec 05, 2024 10:51 pm Post subject: Re: Headlights tripping out |
You lost a ground path and the circuit has found a new path through the high beam dash bulb. That would be my guess.
Grounds good at the bulbs? Does your dimmer switch have clean contacts? Wiring in good shape? How about the wiring and connector at the bulbs? _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo!  |
Posted: Fri Dec 06, 2024 11:59 am Post subject: Re: Headlights tripping out |
The switch is good. It's brand new and seated just fine.
I'm gonna try VW_Jimbo's suggestion. Last night as I was driving, it kept going back and forth between working and doing the high beam thing -- every time I hit a good bump in the road. Or when I toggled the high beams on and off. VW_Jimbo's idea makes a lot of sense to me cuz it seems to be some sort of loose connection -- perhaps at the lights cuz they're so affected by the bumps in the road? Grounds make sense. |
Posted: Fri Dec 06, 2024 1:55 pm Post subject: Re: Headlights tripping out |
AlexTheBug wrote: |
That sounds like a loose wire, a loose connector, or a loose wire in a crimp connector. You might want to tug on a few wires. Not super hard but a little tug and see what manifests.
It is possible the contacts within a switch have seen better days. Those tension springs after several thousand heat cycles lose a tiny bit of their stiffness. This causing poor contact areas. All worth reviewing while you visually inspect the entire system.
He’ll, I have found unscripted butt connectors behind the headlight sockets. It could be anything and anywhere along those wire paths!
Additionally, low level lighting can be traced back to the oxidized fuses. I was taught to roll the fuses in their individual slots, to clean them up. If you do that and start hearing arcing, it may be a corrosion issue. I fixed MANY headlight issues just rolling fuses! MANY! _________________ Jimbo
TDCTDI wrote: |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 16663 Location: North Florida, USA
Posted: Sat Dec 07, 2024 9:45 am Post subject: Re: Headlights tripping out |
I'm wondering if your fuse box is miswired? Here is a simplified diagram from Speedy Jim's site showing how the headlights circuits work.
Note how the blue high beam indicator wire comes off one of the high beam fuses.
Note how the single white wire from the headlight dimmer relay powers two linked fuses at the fuse box and the output wires are white. Take a closer look at your fuse box in the trunk. You should see a single white wire coming off the flasher relay connecting to the INPUT side of fuse#3 where a brass bar links fuse #3 and #4 together. This way this one white wire powers both headlight fuses/filaments.
Test: When you have the situation where the high beam indicator on the speedometer is ON but the high beams are not... get to the trunk side of the fuse box and ID which fuse (#4?) has the blue/white indicator wire AND the white high beam output wire. Disconnect the white output wire. This disconnects the headlight from the fuse box. Does the high beam indicator lamp go out? This suggests the indicator is being power from the headlight rather than the dimmer relay.
Take a VM or test lamp and confirm each of the four headlight fuses are powered in pairs when the headlights are ON in high and low positions. The two yellow wire fuses are powered when low beams are ON. Two white wire fuses are powered when high beams are ON.
Swap fuses. The fuse conductors may be broken and only being held in place by the tension of the clips holding the fuses in place. Physically remove the fuses and check them. They don't always fail by melting in the middle.
_________________ AshMan40
Posted: Mon Dec 09, 2024 11:42 am Post subject: Re: Headlights tripping out |
Fun update -- it was just a loose ground by the headlight. Kinda anti-climactic really. But thank you all for your help! Saved me $$ from taking it to the mechanic. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33223 Location: Hot Arizona
Posted: Mon Dec 09, 2024 11:49 am Post subject: Re: Headlights tripping out |
AlexTheBug wrote: |
Smart update, not only did you save yourself big money - assuming that "any ol' mechanic" could've troubleshot that - any are not so good with electrics - You have helped countless others here !!!! This is why we post our solutions.
And we've all made dumb errors: the point is to keep learning and improving. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
gt1953 Samba Member
Joined: May 08, 2002 Posts: 13952 Location: White Mountains Arizona
Posted: Mon Dec 09, 2024 1:44 pm Post subject: Re: Headlights tripping out |
While you are at it check all of the grounds....clean them up bright and shiny...fuse holder also. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
heimlich  VWNOS.com
Joined: November 20, 2016 Posts: 7516 Location: Houston, Texas
Posted: Tue Dec 10, 2024 5:37 pm Post subject: Re: Headlights tripping out |
Something is loose. Open the hood at night and wiggle things around. You'll find it. _________________ www.vwnos.com [email protected]
