caseyl Samba Member
Posted: Mon Jun 09, 2025 9:45 am Post subject: Broken Syncro Front Transmission Mount Ear |
Hey Samba,
It looks like I broke this ear on my syncro transmission. Has anyone had any success welding this cast mount?
I could probably get creative and made a specifically shaped washer instead of welding.
Is the standard procedure to disassemble the case prior to welding?
I have a tig welder and would probably do it myself. Does anyone know what rod works best?
I believe the case is a later model (1990-1991 or so) aluminum one.
Thanks in advance everyone. I was pretty bummed out when I saw this. |
Sodo Samba Member
Joined: July 06, 2007 Posts: 10639 Location: Western WA
Posted: Mon Jun 09, 2025 10:14 am Post subject: Re: Broken Syncro Front Transmission Mount Ear |
All low-gear housings are aluminum and its a weldable aluminum.
It's a HUGE job to weld that.
You don't have to disassemble the trans.
But the trans has to come out.
The Low gear housing is NLA.
I hope you kept the broken piece, can weld it back on at trans rebuild ( or 3rd/4th hub replacement ! ) time
This mount is a simple function, but it requires BOTH ears.
It not only supports the trans - it resists output torque (to the front-prop-shaft).
I would fab a rectangular steel "washer" that nestles into the recess, just bridging over, with a 'leg' tacked on to make up for the missing aluminum ear (if that makes sense).
Maybe with Permatex Ultra-gray sealing between the steel and the aluminum.
If you have an aluminum-welder-guy, it could be made from aluminum. _________________
....KTMs, GasGas, SPOT mtb |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 10374 Location: Orbiting San Diego
Posted: Mon Jun 09, 2025 10:29 am Post subject: Re: Broken Syncro Front Transmission Mount Ear |
I've had a broken and missing ear welded back before.
My tranny guy had a donor ear to have welded on.
Those low gear housings can get badly cracked in the bearing area so then a bad one can become an ear donor for another.
The tranny was taken out of the van but wasn't opened up when mine was welded.
Mark |
MsTaboo  Samba Member
Joined: June 02, 2006 Posts: 4549 Location: East Kootenay, British Columbia
Posted: Mon Jun 09, 2025 2:34 pm Post subject: Re: Broken Syncro Front Transmission Mount Ear |
https://www.germantransaxle.com/product/pioneer-machine-werks-low-gear-housing/ _________________ Currently:
All that's needed for evil to prevail is for good people to do nothing.
Resist Kleptocratic Oligarchy (and Idiocracy)! |
4Gears4Tires Samba Member
Posted: Mon Jun 09, 2025 9:06 pm Post subject: Re: Broken Syncro Front Transmission Mount Ear |
Well that's not cheap at all.
I'd try to get some angle iron, flat iron, or bar stock and make some sort of sleeve to go over the arm. _________________ '87 Syncro Ferric Oxyhydroxide Superleggera Edition
'85 Westy Sciuridae Domus Edition |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 8403 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Tue Jun 10, 2025 6:22 pm Post subject: Re: Broken Syncro Front Transmission Mount Ear |
4Gears4Tires wrote: |
Well that's not cheap at all… |
Hence: $$$yncro…
Good luck, I’ll be over in the 1WD/cheap & slow lane…
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
zerotofifty Samba Member
Posted: Tue Jun 10, 2025 10:14 pm Post subject: Re: Broken Syncro Front Transmission Mount Ear |
dhaavers wrote: |
Hence: $$$yncro…
- Dave |
That is one reason I bought a Jeep for off roading. Less coin and more capable. _________________ Sorry About That Chief.
Give Peace a Chance.
Words to live by. |
markswagen Samba Member
Joined: January 28, 2018 Posts: 1555 Location: san diego
Posted: Tue Jun 10, 2025 10:26 pm Post subject: Re: Broken Syncro Front Transmission Mount Ear |
that's as maybe, but when you are on hells revenge and a bunch of razor side by side drivers get upset because the were taken out on an ''extreme trail'' because there are fucking volkswagens everywhere.
no sir, you can keep your jeep, the engine is in the wrong place anyway.
FWIW, my syncro transmission has had both support tabs welded back on, no idea the story behind it, it was long before my caretakership.
zerotofifty wrote: |
That is one reason I bought a Jeep for off roading. Less coin and more capable. |
_________________ markswagen {mobile mechanic} san diego area all early VW's cared for.
619 201 0310 |
Sodo Samba Member
Posted: Wed Jun 11, 2025 7:47 am Post subject: Re: Broken Syncro Front Transmission Mount Ear |
syncro is expensive.
But you can't wake up in a jeep
in a beautiful, almost inaccessible campsite,
sit up,
open the stove
make coffee
markswagen wrote: |
FWIW, my syncro transmission has had both support tabs welded back on, no idea the story behind it, it was long before my caretakership. |
One was broken somehow.
Then they drove it with only one ear and propshaft torque twisted the other ear off? _________________
Posted: Wed Jun 11, 2025 5:54 pm Post subject: Re: Broken Syncro Front Transmission Mount Ear |
Sodo wrote: |
sit up,
open the stove
make coffee
markswagen wrote: |
Then they drove it with only one ear and propshaft torque twisted the other ear off? |
Actually I can wake up in my jeep, I have a bed in it, and I can wake up open up the stove and make tea (I am a tea guy, not a coffee guy) The Jeep will take me places the vanagon cannot go.
I still have the Vanagon and it does remarkably well off road, but no way can it do the trails my Jeep can. I like the remoteness of where the Jeep can take me, as I am an anti social kind of guy
My Jeep is very affordable verses a syncro too.
Both are good vehicles, with some aspects being better on one verses the other. _________________ Sorry About That Chief.
Words to live by. |
Posted: Wed Jun 11, 2025 5:59 pm Post subject: Re: Broken Syncro Front Transmission Mount Ear |
markswagen wrote: |
When you get stuck on a trail, I will be happy to pull you out with my
old Jeep as in general I like to help folks, specially old VW folks.
And yes it is less costly than a syncro. My Jeep is considered some what mild in the off road world, yet is more capable on the trails by far than any Vanagon I have ever seen. _________________ Sorry About That Chief.
Words to live by. |
Sodo Samba Member
Posted: Wed Jun 11, 2025 6:12 pm Post subject: Re: Broken Syncro Front Transmission Mount Ear |
OK then, UNCLE !
Bet you can't sleep or make tea in a Razor. _________________
MarkWard Samba Member
Joined: February 09, 2005 Posts: 18753 Location: Retired South Florida
Posted: Thu Jun 12, 2025 10:27 am Post subject: Re: Broken Syncro Front Transmission Mount Ear |
OP, I might have a cracked case I would sell on as a donor. PM me if you need to go that route. I’ll wait to hear before digging it out. |
WiboBusMan Samba Member
Joined: September 26, 2009 Posts: 160 Location: Canada
Posted: Thu Jun 12, 2025 5:32 pm Post subject: Re: Broken Syncro Front Transmission Mount Ear |
Sodo wrote: |
If you can, welding would be the preferred fix, but...
If you still have the ear, a top quality structural epoxy, with impeccable surface prep, reinforced with a steel pin or two, and fiberglass mat, or better, carbon fibre, will fix this very solidly.
W _________________ Science has sacrificed Truth on the altar of its narrative. |
?Waldo? Samba Member
Joined: February 22, 2006 Posts: 10012 Location: Where?
Posted: Thu Jun 12, 2025 6:53 pm Post subject: Re: Broken Syncro Front Transmission Mount Ear |
caseyl wrote: |
I have a tig welder and would probably do it myself. |
Considering that he has a TIG and apparently the ability to use it, that seems to me to be the way to go, and other options seem much less desirable. I have a TIG welder, and if it were mine, I wouldn't even consider the other options that have been mentioned. |
caseyl Samba Member
Posted: Tue Jun 17, 2025 5:04 pm Post subject: Re: Broken Syncro Front Transmission Mount Ear |
Thanks for all of the replies everyone. Hopefully soon I can drop this transmission and get a better look at the damage.
I will be sure to update the thread with the fix. |
Posted: Tue Jun 17, 2025 5:45 pm Post subject: Re: Broken Syncro Front Transmission Mount Ear |
If you be welding the repair, consider adding some more metal so in as to beef it up better than stock, perhaps likewise on any other ear. Evidently other folks have these break so it is a design weakness.
If you do all the prep work, adding some more reinforcement should be little extra effort.
Anyhows, that be what I be thinking of doing. Dont let this happen again.
good luck, keep us informed on your fix. _________________ Sorry About That Chief.
Words to live by. |
Phishman068 Samba Member
Joined: February 19, 2007 Posts: 2000 Location: Pittsburgh PA (ish)
