Help!? What pads & rotors for SCP 1st gen Brake kits?
SyncroScott
SyncroScott is offline
PostPosted: Thu Jun 12, 2025 10:38 am    Post subject: Help!? What pads & rotors for SCP 1st gen Brake kits? Reply with quote
Hi, its been way toooooo long...but good to be getting back in the scene!
I'm resurrecting my trusty Syncro after a lengthy hibernation. I need to get some new pads and rotors for my original, 1st gen Small Car Performance Big Brake Kit and Rear Disc Conversion Kit. Trouble is that I am having trouble finding exactly what those pads/rotors were. SMP seems to only have records for their new stuff. IIRC, the fronts are Gerlings off an Audi 5000 and the rears are New Beetle? I have my original pack slip that indicated following info but the part #s don't seem to lead to anything very specific when I search the interweb..
"Front - Pads:D447SM, Rotors: 8E0-615-301A
Rear - Pads:D363SM, Rotors: 447-615-601A"
Can anyone please help me track down what these parts are?
'90 Flat-top Syncro
‘17 Golf Wagon
'18 Golf
MarkWard
MarkWard is offline
PostPosted: Thu Jun 12, 2025 11:32 am    Post subject: Re: Help!? What pads & rotors for SCP 1st gen Brake kits? Reply with quote
Not to be snarky, but have you googled those numbers? You might be surprised. Here is a problem with aftermarket kits, the companies progress and support for the earlier stuff is gone. We had a customer that needed replacement GW front rotors. They were out of stock on indefinite back order.
While expensive, I’d order 2 of everything if I was installing aftermarket brakes to ensure I had spares. I’m surprised Smallcar can’t help
SyncroScott
PostPosted: Thu Jun 12, 2025 11:50 am    Post subject: Re: Help!? What pads & rotors for SCP 1st gen Brake kits? Reply with quote
It might come as a surprise to some, but I did in fact Google those numbers...which turned up nothing specific...hence the post and plead for help. I was also told that brake numbers are not standardized (seriously?!) which might be why i'm not turning up exactly what I need when searching the web with those IDs. Crying or Very sad
'90 Flat-top Syncro
‘17 Golf Wagon
'18 Golf
dobryan
dobryan is offline
PostPosted: Thu Jun 12, 2025 11:55 am    Post subject: Re: Help!? What pads & rotors for SCP 1st gen Brake kits? Reply with quote
I do this every time. My parts supply is well labeled...
Dave O
The Western Syncro build
MarkWard
MarkWard is offline
PostPosted: Thu Jun 12, 2025 12:24 pm    Post subject: Re: Help!? What pads & rotors for SCP 1st gen Brake kits? Reply with quote
The 447 number sounds like an Audi number. https://parts.audiusa.com/p/Audi__/Disc-Brake-Rotor/48779022/447615601A.html
The D on the pads reminds me of Repco Metalmaster pad numbers.
Worse case, Pegasus Auto Supply has Hawk and Performance friction pad templates you might be able to match up. Coleman Machine can make custom rotors for less than you might think. You could send one of each. Porterfield brakes can take your old pads and refurbish them. So lots of options.
wesitarz
wesitarz is offline
PostPosted: Thu Jun 12, 2025 5:27 pm    Post subject: Re: Help!? What pads & rotors for SCP 1st gen Brake kits? Reply with quote
Rear brakes are from a 1990 vintage Audi V8. Caliper is Girling stamped 4143.
Rotor was Zimmerman (I sourced from FCP Euro), cheap Chinese Centric cracked on installation. Rockauto has pads, calipers and rebuild kits.
ALIKA T3
ALIKA T3 is offline
PostPosted: Thu Jun 12, 2025 11:59 pm    Post subject: Re: Help!? What pads & rotors for SCP 1st gen Brake kits? Reply with quote
Like Mark said, Google...
Front rotors:
https://www.autohausaz.com/pn/SP25115?srsltid=AfmB...BpNMGgBToV
Front pads, with the VW part number listed for further research
https://www.pelicanparts.com/More_Info/D447SM.htm?...5vkMzG408D
You get the idea, I'll let you do the rear.
wesitarz
wesitarz is offline
PostPosted: Fri Jun 13, 2025 1:04 am    Post subject: Re: Help!? What pads & rotors for SCP 1st gen Brake kits? Reply with quote
Front rotors:
From the Pelican parts link the front looks like they are from the 1988 Audi 5000
SyncroScott
PostPosted: Fri Jun 13, 2025 4:14 am    Post subject: Re: Help!? What pads & rotors for SCP 1st gen Brake kits? Reply with quote
Wow, thanks so much, I really appreciate the help!!
Mark and Alika: I feel sorta foolish; not sure where I was going wrong but my internet searches didn't turn up anything that definitive. I am going to assume that my general brake ignorance didn't help and I just wasn't sure what I was looking for or at. I really appreciate the leads, thanks!
Wesitarz: that Audi info would corroborate my fuzzy memory of where I suspected the SCP sourced components back then. Very helpful, thanks!
'90 Flat-top Syncro
‘17 Golf Wagon
'18 Golf
termuehlen Premium Member
termuehlen is offline
PostPosted: Fri Jun 13, 2025 9:09 am    Post subject: Re: Help!? What pads & rotors for SCP 1st gen Brake kits? Reply with quote
First gen Small Car Brakes:
Front
Rotor
1998 VW Passat
Zimmermann 8E0-615-301C
Pad
PBR Deluxe ceramic
D447R
Rear
Rotor
1991 Audi 200 Quattro
Zimmermann 447-615-601A
Pad
PBR Deluxe ceramic
D363R
1988 Westfalia automatic Subaru OBD1
1986 syncro tintop wbx
ALIKA T3
ALIKA T3 is offline
PostPosted: Fri Jun 13, 2025 11:09 am    Post subject: Re: Help!? What pads & rotors for SCP 1st gen Brake kits? Reply with quote
I usually remove the dashes between the part numbers, fu search.
