Say hi to Kermit - 76 Campmobile - and tell me what my EC needs!
virusdoc
virusdoc is offline
PostPosted: Sat Jun 28, 2025 6:14 am    Post subject: Say hi to Kermit - 76 Campmobile - and tell me what my EC needs! Reply with quote
Hi there. I have been a member for several years, as I rebuilt and updated my 76 Super convertible. I have decided to expand the 76 air-cooled fleet, and recently purchased Kermit. He is a French variant of the Helsinki SO-P24 model. I ordered him from the UK to the US from RestoHaus (Bojangles on our classifieds) and that process was remarkably straightforward. Happy to chat about that if anyone is considering similar.
I bought Kermit because I loved the color, the body was rust free, the camper interior was nearly 100% stock and in great shape, and it still has the 2.0L with fuel injection in runnable condition, with at least one rebuild that is documented.
When he rolled off the transport yesterday, he would not even turn over. Bummer. But a quick fix. Battery was at 100% reading nearly 14 V. Sure enough, the connections on the back of the starter were in a moderate state of corrosion, probably from sitting near the shore in Devon UK for too long. Wire brush cleared that up, and all of a sudden we're getting full cranking power.
However, he still would only fire, then immediately die a second or two later. I poked around the engine compartment and find two very sketchy vacuum lines (circled below). The one on the left I believe to be part of the brake boost assist, but it was split wide open. I'm going to blame this on rocking in the ship during a 10 day transatlantic, but the hose itself looked fairly new. I snugged what was left of it down tight to the vacuum plenum, and then cinched it on with a tight zip strip. Immediately fired up and idled nicely and was drivable. Drives, accelerates, and shifts beautifully. The other circled elbow looks to be in bad shape, and I'd appreciate help identifying that hose part number and a source.
Please take a glance at my EC pics and help me make a punch list for what needs to be done. There are two connectors on the far right that aren't attached to anything. And I know this isn't the correct distributor. I have a SparkWerx rebuilt SVDA 043 that I wonder if I can use with this engine.
I also need to address the fact that the oil pressure light doesn't come on in key position 1. Probably a connection or a bulb, but definitely not something I want to drive without.
Any and all suggestions are welcome! I'll send a later post on the undercarriage, which overall is in good shape but missing the entire passenger side of the heating ducts. And the CV boots are shot and there is oil leaking from that area and the nose cone area of the transmission.
1976 Convertible Super Beetle, "June Bug".
Self-rebuilt 1904
1976 Campmobile 2.0L FI, "Kermit"
virusdoc
virusdoc is offline
PostPosted: Sat Jun 28, 2025 6:41 am    Post subject: Re: Say hi to Kermit - 76 Campmobile - and tell me what my EC needs! Reply with quote
Some more pics of Kermit's interior.
Self-rebuilt 1904
Wildthings
Wildthings is offline
PostPosted: Sat Jun 28, 2025 7:25 am    Post subject: Re: Say hi to Kermit - 76 Campmobile - and tell me what my EC needs! Reply with quote
virusdoc wrote:
That is not the correct breather for a fuel injected engine. Not sure what problems it might cause, if any. The Vanagon waterboxer engines seem to run fine with a blown out breather which would operate pretty much the same as the incorrect on you have. The waterboxer engine has an O2 sensor that will correct for air leaks though.
As far as leaky hoses and boots, it's best to buy a complete set from a place like Bus Depot and get rid of all your vacuum leak now, versus fighting them one by one.
You are missing the mechanism for the thermostat flaps. Hopefully the left flap is still there and screwed down in the HOT position so that cool air is being forced through the oil cooler.
busdaddy
busdaddy is offline
PostPosted: Sat Jun 28, 2025 8:49 am    Post subject: Re: Say hi to Kermit - 76 Campmobile - and tell me what my EC needs! Reply with quote
Nice looking camper, it's been rusty in the past, hopefully the repairs were done well.
So many hose clamps on the vacuum hoses, not good if it ever backfires.
That cheapo 009 like distributor would be high on my list to get rid of, and the wires from the resistor pack are unsupported and carrying the weight of the harness, maybe turn the resistor pack over so there's some slack?
Слава Україні!
virusdoc
virusdoc is offline
PostPosted: Sat Jun 28, 2025 9:28 am    Post subject: Re: Say hi to Kermit - 76 Campmobile - and tell me what my EC needs! Reply with quote
I like the idea of a full vacuum hose/boot kit, but can't find one on bus depot. If you know of a company that sells one, can you post a link? Even google only turned up one, from a company called "German Supply" that I've never heard of.
I assumed the thermostatic flaps would have been modified or removed, as was the case on my Beetle. I'll address that in time and reinstall the system. T
Thanks your your reply!
Self-rebuilt 1904
Wildthings
PostPosted: Sat Jun 28, 2025 10:36 am    Post subject: Re: Say hi to Kermit - 76 Campmobile - and tell me what my EC needs! Reply with quote
Pick up the phone and give Bus Depot a call, the counters guys are experts, whereas the website is just a dumb convenience.
The left flap must be in place in the lowered position or you will not get sufficient air flow through the oil cooler. The Type 4 flap system is very different from the Type 1 setup.
virusdoc
virusdoc is offline
PostPosted: Sat Jun 28, 2025 10:40 am    Post subject: Re: Say hi to Kermit - 76 Campmobile - and tell me what my EC needs! Reply with quote
I will call them. Thanks!
Self-rebuilt 1904
dodger tom Premium Member
dodger tom is offline
PostPosted: Sat Jun 28, 2025 11:30 am    Post subject: Re: Say hi to Kermit - 76 Campmobile - and tell me what my EC needs! Reply with quote
scott at german supply is great. don’t be afraid of doing business with him.
Shonandb Premium Member
Shonandb is offline
PostPosted: Sat Jun 28, 2025 12:19 pm    Post subject: Re: Say hi to Kermit - 76 Campmobile - and tell me what my EC needs! Reply with quote
Nice looking Bus! I like the colour and the frog theme.
Previous 1973 Panel Bus:
Click to view image
borninabus
Samba R&D Dept.
borninabus is offline
PostPosted: Sat Jun 28, 2025 7:51 pm    Post subject: Re: Say hi to Kermit - 76 Campmobile - and tell me what my EC needs! Reply with quote
i'm about to put my hands on this kit for the first time tomorrow.
https://www.thesamba.com/vw/classifieds/detail.php?id=2677860
looking forward to it Smile
88 Van WBX, A/T - 93 Multivan 5cyl 5M/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport
Abscate
Abscate is offline
PostPosted: Sat Jun 28, 2025 9:39 pm    Post subject: Re: Say hi to Kermit - 76 Campmobile - and tell me what my EC needs! Reply with quote
Beautiful!
Stick a piece of cardboard between that white 12 vdc bus wire and the sharp edge of the wheel well to stop chafe there.
SGKent Premium Member
SGKent is offline
PostPosted: Sun Jun 29, 2025 1:00 am    Post subject: Re: Say hi to Kermit - 76 Campmobile - and tell me what my EC needs! Reply with quote
the elbow is 022-129-637. It may or may not be in GeeBee kit. There is a small metal pipe that fits into it to transition it to the hose going to the S Boot.
George Carlin:
Skills@EuroCarsPlus:
Abscate
Abscate is offline
PostPosted: Sun Jun 29, 2025 5:24 am    Post subject: Re: Say hi to Kermit - 76 Campmobile - and tell me what my EC needs! Reply with quote
FOrgot to add. The placement of the tea kettle in the water tank cutout brings me joy.
virusdoc
virusdoc is offline
PostPosted: Sun Jun 29, 2025 5:57 am    Post subject: Re: Say hi to Kermit - 76 Campmobile - and tell me what my EC needs! Reply with quote
Me too! Even more joyous was finding a copy of “The Camper Van Cookbook” under the side table of the fridge cabinet. I love to think of the former owners tooling around England in this thing.
Self-rebuilt 1904
virusdoc
virusdoc is offline
PostPosted: Thu Jul 03, 2025 8:11 am    Post subject: Re: Say hi to Kermit - 76 Campmobile - and tell me what my EC needs! Reply with quote
Took Kermit for his first decent drive--about 35 miles with mixed highway (55-60 mph) and stop and go traffic. I am really impressed with how well this engine is running. Very smooth torque curve, no sputtering or popping. Transmission shifts very well; synchronizers are all working properly and it's easy to find any gear up or down shifting. He's a bit bouncy, and probably needs shocks. It comes off load to a fast idle that take a long time to slow down. This may be related to the decal valve I think? After about 60-90 seconds it slows down to a respectable idle speed of around 800 (by ear--need to confirm with a tach meter).
At the end of the 45 minute drive, I took a thermal scan of the strainer plate. Oil was at ~225 degree F right after stopping. Given an ambient of 85 F this seems perfect, and suggests the air flap is locked in the HOT position. I do intend to replace the rest of the thermostat system in time.
Oil pressure light started working properly again just by fiddling with the bulb socket. Either it wasn't firmly locked or there was a bit of oxidation between the bulb and the board connections.
Now I'll dig in and start with the basics:
-Replace all the vacuum hoses
-Replace all fuel lines and filter
-Get an SVDA with points on there
-Valve adjustment ('76 CJ engine is not hydraulic, correct?)
-Set timing
-Compression and leak down tests
-Brake system check (seems fine--fluid level good and no evident leaks, but I need to check the pads).
Self-rebuilt 1904
airschooled
Air-Schooled
airschooled is offline
PostPosted: Thu Jul 03, 2025 8:50 am    Post subject: Re: Say hi to Kermit - 76 Campmobile - and tell me what my EC needs! Reply with quote
The high idle is almost certainly the 009’s doing. A proper VW distributor has more internal return springs for the mechanical advance.
If you’re new to late Westfalias, the best way to work on them is to lay out the bed and put a blanket down, so you can lay on your stomach and tinker with everything topside on the engine.
Robbie
www.airschooled.com
Road trip reports and tech blog:
