late reverse shift lever rail box
bigwormskidoo
bigwormskidoo is offline
PostPosted: Tue Jul 01, 2025 7:40 pm    Post subject: late reverse shift lever rail box Reply with quote
searching Weddle I see a shift lever box with a rotational stop on it is this a worthwhile upgrade?
Bruce
Bruce is offline
PostPosted: Sun Jul 13, 2025 8:09 pm    Post subject: Re: late reverse shift lever rail box Reply with quote
Upgrade from what?
They are selling a reproduction of a stock part. The extra tab to stop it from rotating isn't necessary because the lever in the rectangular hole stops the reverse shift rod from rotating.
jsturtlebuggy
jsturtlebuggy is offline
PostPosted: Mon Jul 14, 2025 7:41 am    Post subject: Re: late reverse shift lever rail box Reply with quote
VW must have decided it was needed on later type 1 Transaxle with the late 113 311 581D lever or the replacement 113 311 581F lever that has the pin that fits into groove on the reverse idle gear.
It also can be used when installing the 091 gear carrier conversion to a Type 2 Transaxle to use a type 1 shift housing (nosecone). It is what I used.
Joseph
Fair Oaks/Orangevale, CA
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960
