CoastalBug Samba Member
Joined: June 15, 2025 Posts: 140 Location: TX Gulf Coast
Posted: Fri Jul 04, 2025 3:36 am Post subject: Which one is the correct steering wheel? |
My '68 came with a steering wheel from a '72 or '73 I believe, so it's one of the first things I'd like to change out. I'm just unsure as to which style would be the correct one. I've seen many peoples 1968's with the horn ring, and without the horn ring. Was there a determining factor when these were built? Mine was built in Oct of '67 for the '68 model year in Germany. _________________ Chris - 1968 Beetle Sedan, a book, and a lot of determination. |
baldessariclan Samba Member
Joined: October 14, 2016 Posts: 2147 Location: Wichita, KS
Posted: Fri Jul 04, 2025 8:51 am Post subject: Re: Which one is the correct steering wheel? |
You may want to review this thread for further information on which steering wheels were used on what years: https://www.thesamba.com/vw/forum/viewtopic.php?p=10175381 _________________ 1971 Standard Beetle — fairly stock / driver
baldessariclan -- often in error, never in doubt... |
Bobs67vwagen Samba Member
Joined: March 27, 2005 Posts: 683 Location: Eastern north carolina
Posted: Fri Jul 04, 2025 9:10 am Post subject: Re: Which one is the correct steering wheel? |
Hey your 68 being a US spec bug came with the black wheel and the horn ring and the black plastic center . The horn ring would have been chrome. |
Posted: Fri Jul 04, 2025 9:58 am Post subject: Re: Which one is the correct steering wheel? |
Bobs67vwagen wrote: |
Thanks Bob! _________________ Chris - 1968 Beetle Sedan, a book, and a lot of determination. |
my3bugs Samba Member
Joined: June 18, 2003 Posts: 926 Location: Moreno Valley
OldSchoolVW's  Samba Member
Joined: July 03, 2020 Posts: 1529 Location: San Diego
Posted: Fri Jul 04, 2025 10:19 am Post subject: Re: Which one is the correct steering wheel? |
CoastalBug wrote: |
My '68 came with a steering wheel from a '72 or '73 I believe, so it's one of the first things I'd like to change out. I'm just unsure as to which style would be the correct one. I've seen many peoples 1968's with the horn ring, and without the horn ring. Was there a determining factor when these were built? Mine was built in Oct of '67 for the '68 model year in Germany. |
This is what a '68 steering wheel would look like when new:
From '60 (I believe) - '66 they looked like this:
I've seen the earlier style horn ring used on later steering wheels and visa versa. That said, you will be unable to use either of these stock steering wheels on your bug because you have a '72 - later steering column ... which is a different animal. Personally I don't care for the appearance of the '72 - steering wheel and would want to change it out as well. Unfortunately you'd need to select an aftermarket style with an adapter. There are a variety of styles to choose from, but none look like the stock '68 wheel. _________________ Tom
"Following distance is proportional to IQ."
"It's okay to think."
"If you don't do it this year, you'll be one year older when you do." Warren Miller
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
'73 Type 3 Fastback |
Posted: Fri Jul 04, 2025 10:29 am Post subject: Re: Which one is the correct steering wheel? |
Or I guess if you wanted to put in the work( it's really not that hard) you could get a 68-71 locking column with key and swap it in so you could put the stock steering wheel back on it. |
Posted: Fri Jul 04, 2025 10:33 am Post subject: Re: Which one is the correct steering wheel? |
More steering wheel minutia available here :
https://www.wolfsburgwest.com/wired/wired_04_00/wired_04_00.htm _________________ Tom
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
Posted: Fri Jul 04, 2025 12:25 pm Post subject: Re: Which one is the correct steering wheel? |
OldSchoolVW's wrote: |
you will be unable to use either of these stock steering wheels on your bug because you have a '72 - later steering column .... |
I don’t think the seller swapped the steering column. Just the wheel. _________________ Chris - 1968 Beetle Sedan, a book, and a lot of determination. |
Posted: Fri Jul 04, 2025 2:00 pm Post subject: Re: Which one is the correct steering wheel? |
I may be wrong but I think the 72 and newer columns are different and the earlier wheel will not work with the later column. Someone else please weigh in on this to fact check me-thanks Bob |
Posted: Fri Jul 04, 2025 2:02 pm Post subject: Re: Which one is the correct steering wheel? |
I’ve sent him a text message to confirm.
ETA: I just confirmed that the steering column is what the car had. FWIW, the steering wheel is held together with electrical tape at the moment. So unless the splines are completely different, it’s been rigged to work. _________________ Chris - 1968 Beetle Sedan, a book, and a lot of determination. |
Posted: Fri Jul 04, 2025 2:42 pm Post subject: Re: Which one is the correct steering wheel? |
I looked into this a few years ago with several sources. I was told that the splines were different and one could not put an earlier steering wheel on a '72 - later bug and that no adapters are made that would make one work either. The only option if you REALLY wanted the correct stock steering wheel was to change out the column. If that is the correct steering column for a '68, it would be interesting to see how the PO got the later steering wheel to work on it.
Did the car have the correct-for-'68 steering wheel on it before the later style stock one was put on ... or did the later stock one replace an aftermarket wheel?
BTW ... none of us are trying to rain on your parade. Just hate to see you go to the time and expense of trying to get the earlier stock wheel on that column if it is designed for the later wheel. _________________ Tom
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
viiking Samba Member
Joined: May 10, 2013 Posts: 3319 Location: Sydney Australia
Posted: Fri Jul 04, 2025 5:17 pm Post subject: Re: Which one is the correct steering wheel? |
This might help. May not.
Here are the photos of my original (been in the family since new) February 1968 German Euro beetle showing the wheel cancelling ring and the column assemblly. If you blow it up you may be able to count the number of splines etc.
Admittedly it is RHD but that shouldn't be an issue as the wheel and column were just moved from the LHS position to the RHS unmodified. That is, the indicator stalk for us in RHD world is on the wrong side i.e. the same side as the shifter.
I can confirm for certain what others have said. Black steering wheel with chrome D ring.
_________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Discharged: 1983 Vanagon, 1974 1800 Microbus,1968 Low Light,1968 Type 3 |
Posted: Fri Jul 04, 2025 7:50 pm Post subject: Re: Which one is the correct steering wheel? |
In the meantime, you could get one of these. Trust me, neither you nor anyone else will notice the late style steering wheel.
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
Posted: Sat Jul 05, 2025 5:03 am Post subject: Re: Which one is the correct steering wheel? |
Wow, I never cared much for steering wheel covers but that fluffy thing could be a game changer. I'll get one and put in on our riding lawn mower for my wife! Good stuff |
Posted: Sat Jul 05, 2025 7:40 am Post subject: Re: Which one is the correct steering wheel? |
Not sure what you feed it. Might want to take it to the vet for a rabies shot. _________________ Tom
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
Posted: Sat Jul 05, 2025 10:11 am Post subject: Re: Which one is the correct steering wheel? |
Hmmm…. Looks like I won’t be able to go back with the original.
Posted: Sat Jul 05, 2025 10:47 am Post subject: Re: Which one is the correct steering wheel? |
Try to get the correct column with a key. You can probably have the existing column out and the replacement installed in about 2 to 3 hours. I have seen them for sale in the samba classifieds. Or if there are any wrecking yards near you there may be a bug in there you could pull one from. 68 to 71 should work. There was a 70 in the pick and pull near me about 1 month ago but it's gone now. Good luck-Bob |
cletus_zuber Samba Member
Joined: January 08, 2010 Posts: 2479 Location: Gladstone, Ore
Posted: Sat Jul 05, 2025 6:05 pm Post subject: Re: Which one is the correct steering wheel? |
.I think you are getting some bogus information. The splines didn't change until 74. A 72 wheel will fit on your 68 just fine, a 68 wheel will fit on a 72, but it will hit the column mounted wiper switch. _________________ 1972 1302
HPMX 40's & 019 |
