deronmoped Samba Member
Joined: November 18, 2006 Posts: 386 Location: San Diego
Posted: Wed Nov 12, 2025 7:17 am Post subject: Brake Pedal/Master Cylinder goes mushy? |
I have been trying to figure out what is going on with not having enough "hard" stopping power with my Brakes in my 70 Bus with 73 brakes in it.
What I have right now is the whole shooting match out of a 73 in my 70 Bus. The brake booster and master cylinder are fairly new. The rest of the braking system is in good shape. Fairly new shoes and pads. New spring kits in the rears. New brake hoses. No leaks, recently bled. Rears are adjusted so as to be just on verge of dragging. Drums are original and are within wear specifications.
Driving around the brakes seem to operate normally. It's only when I try to make a hard stop that I seem to run out of travel with the brake pedal and I don't get the performance I should get out of hard stopping. It's feels like, while stopping hard the pedal goes mushy and goes to the floor. With the engine off, the brake pedal is rock hard after a inch of travel.
Could there be something Funky going on with the Master Cylinder? The Booster causing the Master to do something weird? I will disconnect the Booster and see how the pedal feels with a hard stop, see if goes mushy.
Thanks, Deron. |
Bobs67vwagen Samba Member
Joined: March 27, 2005 Posts: 950 Location: Eastern north carolina
Posted: Wed Nov 12, 2025 8:23 am Post subject: Re: Brake Pedal/Master Cylinder goes mushy? |
| This could be air still trapped in the system, leaky master, leaky booster, or leaky line to booster. I would bleed them again repeatedly to be sure no air is left in the system. I use a mitey-vac one person pistol grip bleeder that works well with no brake pedal pumping and is inexpensive. |
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 4149 Location: Seattle, WA
Posted: Wed Nov 12, 2025 12:12 pm Post subject: Re: Brake Pedal/Master Cylinder goes mushy? |
With no leaks and no air in the system, pedal going to floor can only mean a failed master cylinder. _________________ '67 bug: seized by the authorities
70bus  Samba Member
Posted: Wed Nov 12, 2025 7:13 pm Post subject: Re: Brake Pedal/Master Cylinder goes mushy? |
"whole shooting match"
do you have the proportioning valve? _________________ Craig K
70 Neunsitzer
65 Pritschenwagen
Raoul the 65 singlecab
Karl the 70 nine-seater |
timvw7476 Samba Member
Posted: Thu Nov 13, 2025 2:50 am Post subject: Re: Brake Pedal/Master Cylinder goes mushy? |
yeah the proportioning valve is tricky. As in with bleeding it prefers to be sitting FLAT on a slab of concrete. If the bus is tilted or up on a jack it is impossible to properly bleed all four corners & chase all the air out.
Can drive you nuts. Flat is where it's at. and gravity bleeding is a great reason to sit & sip something to pass the time...... |
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1797 Location: New Brunswick,Canada
Posted: Thu Nov 13, 2025 7:35 am Post subject: Re: Brake Pedal/Master Cylinder goes mushy? |
agreed with gravity bleeding,I put a clear plastic hose on the bleeders ,with a upward tilt ,so they hold any brake fluid comming from the bleeder and it shows bubbles ,when there are no more bubbles ,close the bleeders,the job is done,ensure that the resoirvoir stays full when bleeding. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=620186
1968 Dune Buggy sold dec 2024
1974 parts bus
A smart man learns from his mistakes,a very smart man learns from other's mistakes. |
Posted: Thu Nov 13, 2025 7:51 am Post subject: Re: Brake Pedal/Master Cylinder goes mushy? |
Yes I have the proportioning valve installed.
What gets me wondering is the pedal is rock hard after a inch of travel with the engine off. This makes me believe the system has no air in it. Once the engine is running the brake feel with the booster working is it runs out of travel (trying to stop hard) and feels soft. I mean I could stand on the pedal with the engine off and it won't move after a inch of initial travel. |
Posted: Thu Nov 13, 2025 8:33 am Post subject: Re: Brake Pedal/Master Cylinder goes mushy? |
| So in another thread I find out that I probably do not have the correct slave cylinders in the rears, that work correctly without the residual pressure valve. I think I have the 1970 rear slaves without the spring in them. The spring replaces the purpose of the residual pressure valve that was deleted from the brake proportioning valve. |
Posted: Thu Nov 13, 2025 8:43 am Post subject: Re: Brake Pedal/Master Cylinder goes mushy? |
| One idea I have is, could the bite of the brake shoes and brake pads be compromised? Not broken in correctly, some sort of glaze on them that keeps them from working efficiently. It would be kinda like the feel of brakes that are overheated and even if you stand on them they do not provide adequate stopping power? |
Posted: Thu Nov 13, 2025 9:42 am Post subject: Re: Brake Pedal/Master Cylinder goes mushy? |
| deronmoped wrote: |
Wheel cylinders up to '71 are way different than 72-up cylinders, and could not possibly work with a '73 rear brake setup.
I think you are giving way too much importance to the spring that was in stock ATE 73-up cylinders. Some aftermarket parts omitted it, and
now even ATE has discontinued the springs in their newest production. The brakes work fine without the spring. The '72 rear brakes had that spring-containing wheel cylinder, and also a residual pressure valve. _________________ '67 bug: seized by the authorities
Posted: Fri Nov 14, 2025 7:11 am Post subject: Re: Brake Pedal/Master Cylinder goes mushy? |
I took a look at online pictures of the spring used in the rear brake wheel cylinders and it looks pretty wimpy. Doesn't look like it would do much in the way of effect in holding the shoes out closer to the drum after the brake pedal is released.
I did tighten up the adjustment of the rear brake shoes, as tight as you can get them without rubbing too much. Tightening them up more helped a little in the brake feel and stopping power. Still need to do more to get the brakes working correctly.
I'm thinking of adding a residual pressure valve, to see if that helps. If that does not work, I'm going to put new brake drums on the Bus. My drums are in tolerance, but not much wear left in them. |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 23512 Location: Oklahoma City
Posted: Fri Nov 14, 2025 8:39 am Post subject: Re: Brake Pedal/Master Cylinder goes mushy? |
| kreemoweet wrote: |
| deronmoped wrote: |
now even ATE has discontinued the springs in their newest production. The brakes work fine without the spring. The '72 rear brakes had that spring-containing wheel cylinder, and also a residual pressure valve. |
Yes. The missing spring does not affect operation. It CAN affect the difficulty of bleeding the system but that is about it.
I will say this though....and I just do not know for the bus if this will cause your problem....the only real affect not having the spring in the slave and not having a residual pressure valve is that not having either.....can affect pre-loading of the pistons which on some cars can cause the brake shoes adjustment to have too much slack.
In other words, without either 5-10 psi of fluid pressure keeping tension on the slave cylinder pistons (this is what the residual pressure valve does)....or.....having a spring doing the same thing.....the pistons make sit back somewhat from the normal position, making the shoe adjustment have too much travel to make contact and generate pressure.
If you know that you have this issue you can correct it during shoe adjustment. Ray |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 13628 Location: West Coast, USA
Posted: Fri Nov 14, 2025 9:51 am Post subject: Re: Brake Pedal/Master Cylinder goes mushy? |
The star adjustment keeps the shoes close to the drum. The internal spring/RPV keeps the wheel cylinder touching the shoes.
Both affect pedal feel.
Test something for me: after shutting down the engine, press the brake pedal hard over and over. Count how many presses from “problem feel” to stiff. On a properly working power brake setup, you should have a handful of presses before the pedal changes feel and the residual vacuum in the system stops boosting. After that, hold the pedal down hard and start the engine. Describe exactly how it feels over the first few seconds of engine.
Robbie _________________ One-on-one tech help for your vintage Volkswagen:
www.airschooled.com
Road trip reports and tech blog:
https://www.patreon.com/airschooled |
Posted: Fri Nov 14, 2025 8:20 pm Post subject: Re: Brake Pedal/Master Cylinder goes mushy? |
From what I'm learning, I decided to get new brake drums.
What made me decide to get the new drums was, they were 9.948 on the driver side and pretty much the same on the passenger side. I assume they are over fifty years old and on the verge (.032) of not meeting specifications. That I believe causes the brake shoes to be to far away (not ideal braking performance) from the drum at the wheel cylinder. You can adjust the shoes so at the adjustment end the shoes are in close contact, but that leaves cylinder end needing something to hold them out close to the drum or you end up with too much pedal travel. My problem, too much pedal travel. When I adjusted the shoes to be pretty much rubbing, that helped correct the problem I was having. With no residual pressure valve (VW got rid of) or springs (which probably did nothing) in the wheel cylinders to help hold the shoes out close to the drums, that leads to too much pedal travel. New drums will get the clearance tighter at the wheel cylinders.
I already came across a couple of threads where guys were having similar problems and tried everything and it was finally corrected at the rear end by replacing the drums. I was confused by this, as I always though that the front brakes did 75% of the braking. And that the master cylinder would activate the fronts separate from the rears. But it seems to be turning out that poor performing rear brakes will affect how the fronts work. Well, I'm going to find out when I get my new drums on the rear. |
Posted: Fri Nov 14, 2025 8:45 pm Post subject: Re: Brake Pedal/Master Cylinder goes mushy? |
As far as the residual pressure valve, 10 PSI to counteract the return springs on the shoes does not seem like enough. And how do they know 10 PSI (what they are selling out there) is going to work on all vehicles. Maybe VW designed the factory RPV to work on a Bus optimally, but then again, why did they delete it.
That and, does the RPV hold pressure when you need it? When you hit the brakes for the first time, did the RPV hold the pressure overnight, over the weekend? Sure on a good newer one it might work correctly. But one that has some years on it, does it bleed off the 10 PSI before the next time you use the brakes?
The springs in the wheel cylinders seemed like a better idea as you don't have to worry about a RPV holding pressure.
Of course these are just fixes to make shoes and drums last longer. |
Posted: Sat Nov 15, 2025 8:13 am Post subject: Re: Brake Pedal/Master Cylinder goes mushy? |
| deronmoped wrote: |
A couple things:
The residual pressure valve is nothing but a one way ball check valve with a 10 psi "unseating" pressure. When you let off the brake pedal....and the MC pistons are brought back to idle/rest position.....all the pressure drops off right? Well....all but 10 psi because the ball check in the residual pressure valve cuts off at 10 psi leaving 10 psi on the lines.
This is a hydraulic system. Basic stopping is commonly around 250-350 psi with hard stopping at 500- 600 psi or more. Do you think that your foot and the short brake pedal generates straight up 600 psi?
No.....its pressure multiplied by piston area and stroke volume in the MC and then multiplied by piston area and stroke in the slave. So 10 psi of line pressure would have little problem overcoming the spring pressure on your shoes.
The object is to keep all the parts....piston to shoe.... in contact and not allow the slave pistons to retract all the way to 0 and come out of contact with the tab on the shoe.
But that is not all residual pressure valves do.
1. They keep a very slight level of spread/inflation on the cups in the wheel cylinder.
2. This same issue with cups collapsing very slightly in the MC also causes there to be a very slight time and piston travel lag in a master cylinder before you get full seal and begin to build pressure. It's not really a total pressure problem....its a response time problem.
The residual pressure valve does not keep 10 psi of pressure on the master cylinder pistons. It's only line pressure on the lines and slave pistons. But without that 10 psi of residual pressure or if you also do not have a basic piston spreader spring inside of the wheel cylinders....you have two instances of "lag". This is a lot of response time loss. Residual pressure valve takes away one of these two lag points. The spreader spring can do largely the same job.
You can find systems that have neither residual pressure valve or piston spreader spring. They usually have design changes to the MC to make them unnecessary (different orifice sizes on outlet ports or MC pistons). Four wheel discs usually do not require the residual pressure valve and have their own retraction system.
The biggest reason though for having residual pressure valves is to make complete bleeding easier and more reliable.
I am not a fan on many vehicles of a "gravity bleed". While its a very good tool to get out the vast majority of air and allow more successful standard "pump the pedal bleeding"....there are too many cars with high spots in the lines where unpressurized fluid can bypass bubbles stuck to the wall of the brake lines by surface tension.
Also, when bleeding from a bone dry and refilled system, the ability to build initial pressure is so poor until you get a lot of air out of the system....stroking the pedal just moves air back and forth because there is not enough pressure to operate the flap valves yet. Hydraulic clutch systems are notorious for this and its why many of the early ones all had residual pressure valves.
So I would say find out what your system has and then find out what it was supposed to have and replace anything missing.
Ray |
