EverettB  Administrator
Joined: April 11, 2000 Posts: 71931 Location: Phoenix 602
70bus  Samba Member
Joined: April 27, 2002 Posts: 6866 Location: Pentwater, Michigan
Posted: Sat Dec 06, 2025 12:36 pm Post subject: Re: Horn button wiring? |
I don’t know the size but I do know that the part # is N130751. Wolfsburg West stocks them.
My original low mileage 1957 Kombi had a steel wire sheath that the brown ground wire runs through from the steering box to just short of the horn contacts. That would offer a measure of protection. I’ve never seen it on another Bus but can’t see why one couldn’t added to a later Bus. _________________ Roads Scholar
Member# 2059 |
Stocknazi Samba Member
Posted: Fri Dec 05, 2025 5:03 pm Post subject: Re: Horn button wiring? |
Anyone know the horn button wire grub screw size? _________________ WANTED:
Thomas Jefferson |
oodeftone Samba Member
Joined: November 08, 2004 Posts: 65 Location: Carlsbad, CA
Posted: Thu Jun 16, 2016 12:15 am Post subject: Re: Horn button wiring? |
| Here's another random horn wire question. Who repops the little metal wire holder tab that bolts to the bottom of the steering box and holds the horn wire in place? I saw a picture on here recently were someone had a nice shiny new one installed. |
Posted: Thu Jun 26, 2014 1:09 pm Post subject: |
| Thanks guys! |
BarryL  Samba Member
Joined: November 01, 2004 Posts: 15477 Location: Casa de Oro, California
Posted: Thu Jun 26, 2014 8:38 am Post subject: |
My guess is it might be as light as #18 or it might be #16. It could be thinner than both but what is important is it's a fine fine multi strand with a soldered ferrule to screw down with the horn button setscrew. It must be able to wind and unwind almost infinitely as you steer back and forth.
On the wiring diagram somewhere on this site is the metric wire size of it printed next to the wire. |
Posted: Wed Jun 25, 2014 10:10 pm Post subject: |
| Kelly wrote: |
is the old wire still in the steeringbox?
either way, you just run a wire through the steeringbox up to the steeringwheel. If the old wire is still in the shaft, splice the new wire to the old and pull the new wire up through the shaft, then cut the splice off. Another way is to use .32 safety wire (or similar) and run it down the shaft and attach the wire to the wire and pull it up through the shaft. No need to take the box apart.
easy money. |
What gauge is the wire that runs up the steering box column? |
grey60 Samba Member
Posted: Thu Feb 20, 2014 11:24 am Post subject: |
Thanks, y'all. I'd been looking at it wrong -- thinking the aluminum tabs were the back side of plastic tabs, like you see on small electronics, e.g., for battery access panels.
Which they are not
And what I thought was a tab visible under the top edge of the button is actually the ONE aluminum tab now holding everything together -- the other two were already open/bent-back  _________________ 1960 grey panel |
BarryL  Samba Member
Posted: Thu Feb 20, 2014 8:44 am Post subject: |
| novetti wrote: |
| That is a risky job to do but with some precaution you might not damage any of the parts. |
True that ^^^^ what he said.
Be really vigilant of the clearance all the way around the chrome ring to the bakelite center before bending the final-vinyl as the center will perpetually stick "on" if it's not sweet before assembly. Just go around the ring and fix any little imperfections that occurred with needle nose pliers with blue tape on the tips. |
novetti Samba Member
Posted: Wed Feb 19, 2014 9:44 pm Post subject: |
The metal (Al rim) has 3 tabs folded securing the rim to the outer plastic rim.
Get the thinnest screwdriver you have at your toolbox and carefully try to unbent the Al tab. Pressing the centre button at the same time might help.
After you finished cleaning etc, put it back together folding the tabs in place.
I just done that last week because the centre metal circle was too dirty and with some corrosion where it makes contact with the spring which grounds into the Steering Wheel hub. |
grey60 Samba Member
Posted: Wed Feb 19, 2014 7:01 pm Post subject: |
A few folks mention taking the button completely apart in this thread… However? Nothing provided in the way of a description (or pics) as to how that actually gets done.
Mine is the early 60s commercial bus variety which sits at the end of long ground wire coming up through the steering column… so --
Once you remove the button from the steering wheel and back-out the tiny grub screw that holds the wire in the back of the button, then what?
How do you get the plastic pieces apart so you can clean-up in there?
I see a single small slot in the lower lip of the chrome-ish trim ring between the moving 'button' and the upward-facing part of the base… and seems like there are some locking tabs holding the spring/base assembly together…
How to open it up without breaking (theoretically) 50+ year-old plastic? _________________ 1960 grey panel |
Major Woody Samba Enigma
Joined: December 04, 2002 Posts: 9016 Location: Portland, OR
Posted: Wed Jul 01, 2009 9:28 am Post subject: |
| JacsWagen wrote: |
easy money. |
The old wire is still completely intact, just has a crack in the insulation right where it comes out. I am concerned about it grounding the the box and sounding the horn intermittently.
I was assuming there was some sort of special oil seal or connection where the wire comes out the bottom. Guess not. Thanks |
johny__utah Samba Member
Joined: September 02, 2008 Posts: 440 Location: Arizona/California
Posted: Tue Jun 30, 2009 10:18 pm Post subject: |
| Put a new 12volt German horn in last week. Tapped into the fuse box were there is spark only when key is turned. Left side if faceing the horn. Right side ground wire up the steering colum to the small screw behing the horn buttom. I had to remove the horn button spring and round flat plate. Tap the center flap a bit for better ground contact.. Horn beeps with a light touch sounds great and super loud. $13 bucks.. |
Kelly Samba Member
Joined: November 25, 2003 Posts: 2437 Location: Olympia, WA
Posted: Tue Jun 30, 2009 9:40 pm Post subject: |
easy money. _________________ It's not how wide your hatch is, it's what you do with it.
Eriba Puck Sticky |
Posted: Tue Jun 30, 2009 9:33 pm Post subject: |
Pulled the steering box out of the 67 today to clean it and noticed that the insulation is cracked on the horn wire where it exits the box. I'd like to replace that wire and I don't have access to my Bentley as it is in the bus, and the bus is up on a lift at my friend's house. I haven't taken the box apart and I don't want to only has 58k on it and is nice and tight--just clean, paint, adjust, re-lube and replace the wire. What is involved in replacing the horn wire?
Thanks all! |
6D2 SBS Hit Squad
Joined: August 04, 2004 Posts: 1039 Location: Tampa, Floriduh
Posted: Fri Aug 05, 2005 6:58 pm Post subject: |
I took the horn apart again.. made sure everything was tight and dry... still all I get is the cluck when I hit the button. I know how the horn wires up... but how does it make the noise? what part causes the noise itself? Im sure it is but is it possible for the hore to just be plan old burned up? thanks again _________________ Chris
The SBS #62
Red Hot Ad Specialties & Stuff...
Shirts and hoodies for shows or clubs.. we ship world wide...
www.pottymouthpromos.com |
6D2 SBS Hit Squad
Posted: Wed Aug 03, 2005 8:14 pm Post subject: |
ok pulled the horn tonight and took it apart... everything is clean and I think I put it back together correctly. I hear the contacts close when I push the hornbutton but it just makes a sound like I am dropping marbels in a tin can... maybe I reversed something when I took it apart? I saw an adjustment screw on the back that touches a bent peice of metal coming off the 12v side. any help would be great thanks... is there a tutorial on rebuilding or fixing a horn? _________________ Chris
The SBS #62
davebuckholts Samba Member
Joined: February 06, 2004 Posts: 2173 Location: South GA
