Driveshaft play
eetrapnoel
eetrapnoel is offline
PostPosted: Sun Apr 09, 2006 2:47 pm    Post subject: Reply with quote
OK. Whats the trick to getting that seal out without destroying the surface?
Amskeptic
Amskeptic is offline
PostPosted: Sun Apr 09, 2006 10:01 am    Post subject: Reply with quote
You're talking about the input shaft? Play is normal. It is secure when the pilot bearing supports it.
Colin
www.itinerant-air-cooled.com
www.facebook.com/groups/324780910972038/
eetrapnoel
PostPosted: Sun Apr 09, 2006 9:48 am    Post subject: Driveshaft play Reply with quote
While replacing the seal on the trans driveshaft, I noticed it moves around quite a bit (with old seal in). How loose is too loose?
