1432 Samba Member
Posted: Fri Jun 13, 2008 9:09 pm Post subject: |
Jimmy
Quote "Your coolant temp is the minimum temp of your motor. Everything else is warmer. That is the purpose of the coolant. To cool the motor. If you dont have any exterior oil cooler, How could you expect your oil to be cooler than the motor itself?? Just does not make much sense"
stands to reason for oil to be at a slightly lower temp since water cooled thru the radiator enters the block first then passes through the heads. |
Jimmy111 Samba Member
Joined: October 05, 2006 Posts: 2643 Location: Wyoming
Posted: Fri Jun 13, 2008 6:51 pm Post subject: |
nikita wrote: |
Jimmy111 wrote: |
The oil journal to water jacket is for water cooled motors . Not ACVW
Your gage was incorrect in your BMW or you had other problems. coolant temp should always be higer than boiling on all emission controlled cars. Oil temps in Water cooled motors are never lower than the coolant temp after the motor gets warmed up. There is usually about a 10 degree differance. |
Thanks for the explanation about alloys.
The last statement is simply untrue in my experience. The inverse is more like it. BMW put a 212F thermostat and 29PSI cap on that system. It is designed to run high coolant temps. Oil temps were in the 190-200F range. On the Ford, the thermostat was 195F, but it was hard to get the oil over 180F, being a slow-turning, roller cam, OHV engine. There is very little oil circulation near the coolant passages, so I am still puzzled by your statement. |
You must be talking about old motors. It is quite common Knowledge these days that minimum oil temp needs to exceed 212 degrees to evaporate the water that enters the oil from the combustion gasses. Most VW owners can testify what happens when the oil temps do not get hot enough. Sludge and a whipcream looking oil. Both will damage your motor. There are exceptions in some Diesel and Natural gas diesel style motors which run at about 180 degrees oil temp.
The opening temps on thermostats in water cooled cars is to provide a MINIMUM temp. Not a regulated maximum temp.
Ive done design work on various motors for some major motor manufactures. They always specify minimum areas of contact between oil and water passages to aid in cooling of the oil.
Your coolant temp is the minimum temp of your motor. Everything else is warmer. That is the purpose of the coolant. To cool the motor. If you dont have any exterior oil cooler, How could you expect your oil to be cooler than the motor itself?? Just does not make much sense. |
dog_jr911 Swamp Donkey Assistant
Posted: Fri Jun 13, 2008 6:04 pm Post subject: |
wait.... was the 0w-60 oil a joke? theres been alot of talk about using the 30mm oil pump and having to use thinner oil. right now, im using the same stuff there putting on the new vettes. 10w-something....
i read car and driver the other day, and the new nissan GTR uses 0w-60 oil. _________________ AKA Chris™
ROCKIN a ESP LTD F2E |
nikita Samba Member
Joined: September 16, 2007 Posts: 531 Location: California
Posted: Fri Jun 13, 2008 8:48 am Post subject: |
Jimmy111 wrote: |
1432 Samba Member
Posted: Fri Jun 13, 2008 7:31 am Post subject: |
Jimmy111, Art,
for decades myself and many of my group have run 2.3 - 2 .7 ltr type 1 & 4 engines for in our sand cars on methanol with no tin or oil coolers
whatsoever, ambient desert temps were 80 - 100*. Actual head temps (not at plug) rarely exceeded 230* oil temps were never higher than head temps. these engines were purposely tuned on the rich side as a lean condition would cause elevated temps in both areas. While these engines were never used at 100% duty cycle they were used in much the same manner as their gasoline, oil cooled fan shrouded counterparts. This, to me shows a direct relationship between head/cyl and oil temp, your thoughts? |
Art Thraen Samba Member
Posted: Thu Jun 12, 2008 9:19 pm Post subject: |
(Jimmy111) I have 1915's and 2332's on mining equipment that is completly unshrouded. They run at about 400 CHT and they are jetted a little rich but I have little problems with them. I just use 72 plate oil coolers with fans and have little problems.
.[/quote]
I would like to see PICs of this! Really! I love to see cool stuff.
Art @ ACE |
Posted: Thu Jun 12, 2008 9:46 am Post subject: |
AS41 has a maximum temperature rating of 300F But as you aproach this Creep accelerates. It is the main reason that the center journals get out of round in Type 1 type cases. It only takes one overheat to do this. It bacame a big problem when VW had to meet emissions and raise the exhaust gas and oil temps. That was the reason for the change to AS-21
nikita Samba Member
Posted: Thu Jun 12, 2008 9:30 am Post subject: |
Jimmy111 wrote: |
Oil IS cooled in water cooled cars. You might not think that there is a oil cooler but there is. It is built right into the castings of the Block. The oil journals pass thru the water jackets and that is where you get your cooling. Most water cooled cars run at much hotter oil temps tht VW's. Many are in the 220- 230 degree range. In VW's it is important to keep the oil temp lower than what is optimal due the the AS-41 case. |
Im afraid you lost me here. Please explain this oil journals to water jackets cooling thing again. And how is the AS-41 alloy damaged by slightly elevated oil temps?
The only liquid cooled vehicle ive owned with an external oil cooler was a pickup truck with tow package. Even the BMW, which ran extremely high coolant temps all the time seldom exceeded 200F oil temps, and that was a 24valve flat-tappet engine that ran at relatively high rpms. |
Posted: Thu Jun 12, 2008 7:53 am Post subject: |
1432 wrote: |
If cylinder head / cylinder wall temps have no little or no relationship to oil temps, think about why our basic water cooled cars need no added oil cooler to maintain oil temps no higher and usually lower than their corresponding water based coolants. |
1432 Samba Member
Posted: Thu Jun 12, 2008 7:16 am Post subject: |
Jake,
I guess you just don't see the basic relationship I'm pointing out. the one that's been relied on for over 100years by the automobile manufacturers |
Jake Raby Samba Member
Joined: August 23, 2003 Posts: 7433 Location: Aircooled Heaven USA
Posted: Thu Jun 12, 2008 6:52 am Post subject: |
The modern Porsche 986/987 and 996/997 engines do have a small external oil cooler fitted to them from the factory. Some other more modern engines also do, especially those that are use in sports cars that will see higher RPM. The Boxster and Cayman engines have this fitted right to the engine case and only air passes over it, it never comes into contact with the water used for engine cooling.
Water is also a much more stable cooling agent that has less spikes in temperature and takes longer to respond to these spikes than any air cooled engine.
People trying to compare "air to Water" and build from that are those who historically have the least success with an aircooled engine performance engine.. _________________ Jake Raby
Raby Engine Development
www.rabyenginedevelopment.com
"I've never given anyone Hell, I just told them the truth and they thought it was Hell" |
1432 Samba Member
Posted: Thu Jun 12, 2008 6:46 am Post subject: |
Posted: Wed Jun 11, 2008 7:27 pm Post subject: |
Quote: |
Here's my take on it from what i've experienced.
Head temps are related to engine load. That's about it. |
I could not agree more, and of course I have the data that illustrates this clearly.
Quote: |
Oil temps are slightly effected by head temps, but the majority seems to be effected by engine rpms |
Absolutely. Internal bearing clearances and surface finishes do matter, but RPM= Friction and friction= oil temp.
Quote: |
Heavy valvetrain/springs seems to increase this heat over light stock components. My theory there is the flat tappet cam and lifter setup has the oil taking a lot of the friction/heat abuse. The more load on this (via lifter to cam pressure, and an increase in rpms) the higher the oil temps get. |
Yes absolutely and if you saw the differences in oil temp that I saw the first time I did a back to back test with a flat tappet Vs roller cammed engine with the same CR, deck height and roughly the same lobe area and cam characteristics you'd really see the impacts this has. The roller engine had oil temps that were 30 degrees lower and WOULD NOT ever climb to the level of the flat tappet engine, even when revved higher for longer amounts of time under more load with higher head and cylinder temps.
All it takes is driving any aircooled car with a full compliment of gauges to see this, adding a 28 channel data logger helps you see it much faster and more clear...
And FWIW any gauge is better than no gauge, or a dipstick wired with some voodoo light that makes you wonder if your oil is hot, or if it has no pressure.. I never understood that: Gauges are bad, but its OK to confuse the hell out of the driver while worrying them half to death while not offering any clue as to why that idiot light is lit up.
If all else fails, just confuse the hell out out the driver and make them pull over... What Rocket Science! _________________ Jake Raby
Eaallred Samba Member
Joined: May 18, 2003 Posts: 5756 Location: West Valley City, Utah
Posted: Wed Jun 11, 2008 3:53 pm Post subject: |
Oil temps are slightly effected by head temps, but the majority seems to be effected by engine rpms. Heavy valvetrain/springs seems to increase this heat over light stock components. My theory there is the flat tappet cam and lifter setup has the oil taking a lot of the friction/heat abuse. The more load on this (via lifter to cam pressure, and an increase in rpms) the higher the oil temps get.
Oh yea, John, the 'magic' number was about 53mph. As long as I kept it under that speed, the oil temps stayed under 220 in that 90 degree weather.
One more bit of useless blabbering from me. My drag motor running E85 runs cool as a cucumber on the cylinder heads. But just idling (to get the head temps up before I run) with those K-800 springs and big heavy stainless valves, my oil temp will get right up close to 200 degrees even before I make a pass down the track. When I ran gasoline, the heads warmed up so fast oil temp was never an issue, lol. _________________ Eric Allred
You have to remember something: Everybody pities the weak; Jealousy you have to earn. |
Posted: Wed Jun 11, 2008 12:00 pm Post subject: |
There are big hills around where I live. But I havent ever seen temps over 400.. The cylinders and heads are cooled mainly by the exhaust and incoming F/A mix. The blower is there mainly to provide circulation because it is in an enclosed space. The fan requires a lot of HP to overcone the pressure differances between the incomming negitive air pressure and the presurized area under the car. The freer flowing the exhaust and the higher the vaccum, the more cooling of the heads and cylinders that takes place.
I always thought that VW should have designed a draw thru cooling system that would pull the air from Below the car and exhaust it out the back. Take advantage of the 2 psi or so under the car and reduce the energy load on the motor.
I know that busses are much more prone to overheating the heads. I had 2 busses and never had CHT guages so I couldnt tell you the temps... But I never fried the heads either.
Just my experiences and views. I really need to look into the overheating problems with busses.
John. I have a good study on bearing oil clearances and heat generation if you are interested in it. It is not VW but it is good. |
Posted: Wed Jun 11, 2008 11:24 am Post subject: |
I could be wrong but I think I heard that the Berg's cam break in machine gets oil temps around 170F, and that is with NO COMBUSTION, just the valvetrain!
John
Aircooled.Net Inc. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
nikita Samba Member
Posted: Wed Jun 11, 2008 11:13 am Post subject: |
John, There you go again trying to inject facts and logic into a discussion.
Here is my take on this. CHT can change in seconds, where oil temps take several minutes to move significantly. Oil temp and pressure relates primarily to the bottom-end health of your engine where parts are pressure lubed, CHT and EGT the top end where combustion takes place. Ive repaired/replaced many valves and heads and never had to replace a crank in stock engines. |
Posted: Wed Jun 11, 2008 10:49 am Post subject: |
Head frying can happen climbing the "hills" we have around here. The oil temp will be fine but CHT thru the roof.
I suspect he didn't have a CHT gauge. We've all been there, usually some blow up leads to an increase in our knowledge.
I consider oil temp to be proportional to RPM, CHT to load. You can free rev a motor on a stand with no load and overheat the oil if you want to prove this to yourself. Especially with thick ass oil and oversized pumps. Most people just stare at me when I tell them their oil temps would drop if they'd use a thinner oil. OK, don't believe me? Use some Valvoline 60W and really cool it off.
John
Posted: Wed Jun 11, 2008 9:47 am Post subject: |
The cylinder head temp is mainly a factor of fuel load and mixture. The oil temp is a mainly a factor of bearing pressure and cylinder head temp. Cylinder temp contributes to this by the oil flow thru the head. On tests I did, the oilflow was much more important than the airllow when the motor was removed from the car. Many people who have had flaps and a thermostat in their shroud have seen that when the thermostat fails closed the car can still be driven around untill the oil gets too hot. This is a factor of the oil cooling the head.
The oil gains most of its heat thru the compression of the oil film thru the bearings. This heat rise of the oil can be as much as 80 degrees on a 1600 at a 45hp load at 3800 RPM.
Both are important. They just have different causes.
I dont know why eric fried his heads. Possibly the altitude change? |
Posted: Wed Jun 11, 2008 8:38 am Post subject: |
FWIW, several years ago when Eric Allred was McGyvering on his Bus, he drove around for a while with NO OIL COOLER AT ALL (not even the stock one in the shroud). And it did not run hot oil temps unless he was over 50mph or so. Crazy.
He knows a lot about oil, oil temps, and cooling, so listen to him.
John
