Westy lean and cutting board mod - specs & details?
MrPolak
MrPolak is offline
PostPosted: Thu Oct 08, 2009 6:14 pm    Post subject: Reply with quote
I put all the pictures and the write up here for a more permanent solution:
http://www.thesamba.com/vw/forum/viewtopic.php?p=4116136#4116136
shorepig
shorepig is offline
PostPosted: Thu Aug 13, 2009 7:24 am    Post subject: Reply with quote
I had an 85 with the saggy butt lean too. Both back springs were saggy by about 1 inch. Instead of the spacer idea, I inserted some spring helpers into the springs. Now it sits level, it cost me $20, and it took me 5 minutes to install them. I've heard people say that the spring helpers aren't a great solution because they can effect your spring rate. I think my springs became slightly stiffer in the rear making for better handling.
snoop
snoop is offline
PostPosted: Wed Aug 12, 2009 7:57 pm    Post subject: Reply with quote
What's a Weekender doing leanin'?
In any case, specs are:
front: OD: 5 5/8", ID: 3 1/4"
rear: OD: 6" (5 7/8" or pretty much anything down to about 3"), ID: 2 1/16"
Do good things...and post about 'em.
Mike
87 Westy Camper
82WestyMan
82WestyMan is offline
PostPosted: Wed Aug 12, 2009 12:56 pm    Post subject: Reply with quote
I did the fronts only on my westy awhile back after I went the H&R springs and the front was down about an 1"
It's its mosty a cut and fit job but not hard with a jigsaw, awood rasp and a little patience
maybe this will be of some help
http://www.thesamba.com/vw/forum/viewtopic.php?t=261751&highlight=lean+cutting+board
ps - personally that 'rotate the springs' from side to side sounds very insprired ... couldn't hurt to try and your only investment would be time
"The floggings will continue until morale improves"
"I never did give anybody hell. I just told the truth and they thought it was hell" - Harry S. Truman
82 Westfalia - w/ a Raby 'Camper Special' engine
riceye
riceye is offline
PostPosted: Wed Aug 12, 2009 12:47 pm    Post subject: Re: Westy lean and cutting board mod - specs & details? Reply with quote
tclark wrote:
riceye wrote:
I'd like to rid my rig of the 3/4" Westy lean.
Ric
I thought you were the original guy to use the monroe coil overs
http://www.thesamba.com/vw/forum/viewtopic.php?t=151963
'The vehicle leveled out nicely, and the ride improved dramatically.'
'raised the ride height just a bit, and leveled out the driver's side sag a little, as well.'
did they not compensate enuff?
That was a couple of years ago. The Westy lean was at a little less than 3/4" - up 'til about two hours ago.
An hour and a half and two 3/8" HDPE donuts later, and it's now sitting about 3/16" proud on the left side. From what I've read, that will drop a bit in time.
The lean seemed to get a bit worse when I replaced the 10+ year old coilovers earlier this year. Not quite sure why - perhaps Monroe is using softer springs now.
And, if you notice in my quote, I offered that they "leveled out the driver's side sag a little", which they did. The lean was worse before I installed them.
You have a good memory, Tim! I have a hard time remembering what day it is.
'87 Westy Weekender - daily driver on salt-free roads
There's gonna be some changes made.
“I find that things usually go well right up until the moment they don't.” - Ahwahnee
"Quality isn't method. It's the goal toward which the method is aimed." - Socrates, later quoted by R.M. Pirsig
tclark
tclark is offline
PostPosted: Wed Aug 12, 2009 11:29 am    Post subject: Re: Westy lean and cutting board mod - specs & details? Reply with quote
Ric
89 Westy with TDI AHU 1.9 manual lots of mods
85 GL 1.9, auto (for sold)
madmax25
madmax25 is offline
PostPosted: Wed Aug 12, 2009 10:05 am    Post subject: Reply with quote
So stupid question, would just rotating the springs left to right fix the lean at all? Seems like in theory it might help a bit, like rotating tires...
-Elliot
'88 Vanagon GL "Big Red"
'90 Westy
Franklinstower
Franklinstower is offline
PostPosted: Wed Aug 12, 2009 9:00 am    Post subject: Reply with quote
I used UHMW (ultra high molecular weight plastic): measured the diameter to fit in the spring cup, cut it out using a bandsaw, then used a hole cutter for the center cut out necessary for the bump stop. I need to search to find the measurements I used. I thought I documented it somewhere with in a post....
if you're leaning 3/4", then use that size to level it out.
'89 Westy - EJ25/22 Frank 4.44 5mt
'75 Miami Blue Sunroof FI Standard Bug
YITB
riceye
riceye is offline
PostPosted: Wed Aug 12, 2009 8:52 am    Post subject: Reply with quote
richardlbennett wrote:
Use the wayback machine
Golly!!! Thanks Mr. Peabody!
AFZ272
AFZ272 is offline
PostPosted: Wed Aug 12, 2009 8:35 am    Post subject: Reply with quote
Use the wayback machine:
http://web.archive.org/web/20050215232351/www.knology.net/~vw/vanagon/sag/
I've been looking into this recently as well.
Westfaila
riceye
riceye is offline
PostPosted: Wed Aug 12, 2009 8:29 am    Post subject: Westy lean and cutting board mod - specs & details? Reply with quote
I'd like to rid my rig of the 3/4" Westy lean. I've searched and searched for the thread describing the procedure, and they all end up referring to a page at knology.com that no longer exists.
Does anyone have details and size specs to help me (and others!) that they would like to share? I've got a polyethylene cutting board just waiting to be hacked up.
Thanks!
Ric
