brake job on a '73 thing
Yarkle
Yarkle is offline
PostPosted: Fri Jun 28, 2013 2:18 pm    Post subject: Reply with quote
my actual question was how does the 11mm socket help, which i also PM'd solomon, he replied that if you use that, it keeps the small gear nut from fallign off.
Tilda the Mustard Tigress 1973 Squareback (o'''^'''o)
https://www.thesamba.com/vw/forum/viewtopic.php?t=771024&highlight=
guppysoup
guppysoup is offline
PostPosted: Fri Jun 28, 2013 10:40 am    Post subject: Reply with quote
A BIG pipe wrench with 5' cheater works in a pinch. It´s not the preferred method but after breaking my then 1/2 inch breaker bar it got me home. I now have a 3/4 bar.
1973 Thing/Safari
1985 Bug/Vocho wanna be class 11
2014 Amarok TDI 4x4
mondshine
mondshine is offline
PostPosted: Fri Jun 28, 2013 7:47 am    Post subject: Reply with quote
Solomon Grundy has it right; the torque tool is the way to go.
Whether you are removing a flywheel gland nut or a rear axle nut, you will probably want to put it back on, and to a specific torque. This is where the torque tool pays for itself. The 9:1 ratio allows you to use a torque wrench you probably already own to tighten these fasteners correctly with ease.
For the price of a tank of gas, it's a once-in-a-lifetime purchase you will be glad you made.
Good luck, Mondshine
DougD
DougD is offline
PostPosted: Thu Jun 27, 2013 6:56 am    Post subject: Reply with quote
I did the same thing. 6' chunk of steel pipe and it came loose pretty easy. Hopefully Mark got that nut off by now...
Rev. Scott
Rev. Scott is offline
PostPosted: Wed Jun 26, 2013 7:37 pm    Post subject: Reply with quote
Lube and let settle. A few cracks with a generous hammer will break the gum and rust. The correct 3/4" drive socket with the breaker bar and a four foot long cheater...and stand/bounce on it! works every time!
"I haven't seen one of those since I was shootin' at 'em!"
Yarkle
Yarkle is offline
PostPosted: Wed Jun 26, 2013 6:41 pm    Post subject: Reply with quote
Solomon Grundy wrote:
The torque meister is GOLD, buy it and keep it in the car. Cool
A deep 11mm socket compliments that set quite well.
how?
mtwrench540
mtwrench540 is offline
PostPosted: Sun Nov 20, 2011 5:50 pm    Post subject: 36mm Reply with quote
last count i had 36mm converted to 1"7/16!
Yarkle wrote:
Kubelmann,
on the M35 Wrench, its inch and a half..does that cause any problems with rounding off the 36mm nut, cuz its a little too big...like 8 hundredths..
87 wolfsberg,74 181w/1915 and lots of patina! learned to fix vw's from hot vw mag in 1964,VWOA instructor,DSM,69 to73,service mgr at different porsche-audi dealers etc,etc,now retired!!! first vw new 64,transplanted 356 eng in 65,400characters are not enough space!!
kubelmann
kubelmann is offline
PostPosted: Sun Nov 20, 2011 3:31 pm    Post subject: Reply with quote
Mine is the original lug wrench from my 38 Ford 1 1/2 ton flat bed truck. One end has a square socket about 7/8" and the other end is a 1 1/2" hex socket
This is around 38 mm but the shoulder of the 36 mm axle gland nuts are big enough that the 2 mm size does not deter its effectiveness. My is a big cast iron tool.
Yarkle
Yarkle is offline
PostPosted: Sun Nov 20, 2011 12:52 pm    Post subject: Reply with quote
K-Mann,
does your fit tight? Maybe the one i have is too big..its pretty loose..its inch and a half..is your sinch and 7/16?
CP
kubelmann
PostPosted: Sat Nov 19, 2011 4:21 pm    Post subject: Reply with quote
I have been using mine with a tanker bar on VWs since the 70's with no trouble with nut size over the decades.
Yarkle
Yarkle is offline
PostPosted: Sat Nov 19, 2011 2:54 pm    Post subject: Reply with quote
Kubelmann,
Yarkle
Yarkle is offline
PostPosted: Mon Nov 14, 2011 5:03 pm    Post subject: Reply with quote
like this:
http://www.ebay.com/itm/190598066043?ssPageName=ST..._500wt_939
(this will probably expire soon, but heres another http://www.ebay.com/itm/Budd-Lug-Nut-Wrench-Dodge-..._500wt_939
the hole on the end is where you put the narrow end of the "tanker bar"
Semper_Dad
Semper_Dad is offline
PostPosted: Sun Nov 13, 2011 9:35 am    Post subject: Reply with quote
kubelmann wrote:
Older big Ford truck and Military Duce and a half trucks use a lug wrench that works on 36 mm nuts perfectly. You can find one on ebay for under $20.
Sure would like to see what that looks like.
Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492
kubelmann
PostPosted: Sun Nov 13, 2011 6:51 am    Post subject: Reply with quote
I have had one since the late 60's. These lug wrenches have a large eyelet that allows a long spud bar or in my case a military track breaker bar and I simply attach the lug wrench to the 36 mm nut and move the track breaker bar toward the ground ( I use gravity as my friend) and since the 60's have never had any issue not only removing various highly torqued 36 mm nuts. But, I also have not had any trouble putting 330 ft/lbs on the nut during installation Since my track breaker bar is over 4' long, All my efforts are multiplied by a factor of 4. Added to that the breaker bar and lug wrench have a combined weight of around 30 lbs. This gives added force as you lower the bar to the ground while the lug wrench effortlessly loosens the nut.
SilverThing Premium Member
SilverThing is offline
PostPosted: Sun Nov 13, 2011 12:41 am    Post subject: Reply with quote
I broke two craftsman ratchets (the lifetime warranty replacements weren't as good of quality) and a cheater bar trying to get that nut off. I think a few unkind words were said as well. I finally bought a 500 ft lb air impact wrench, which made real quick work of the job. I also got a torque meister or whatever they are calling it now, but haven't needed to use it yet.
"I like how everyone likes talking about Zeke's Thing yet he's the only one that's ever seen it." - Katie
"I've seen pictures..." - Jeremy
Solomon Grundy
Solomon Grundy is offline
PostPosted: Sat Nov 12, 2011 7:53 pm    Post subject: Reply with quote
'Remove even the toughest flywheel gland nuts or frozen 36mm axle nuts with a 3/8 inch ratchet. Only 30 ft/lbs of torque applied to the CIP1 Torque Tool equals 270 ft/lbs. of torque at the gland nut. Kit includes Torque-tool & drum plate as well as both 6-volt & 12-volt flywheel gears.
This is what one of our customers had to say about this great tool....received 02/02/2003...
Hello- I just had to tell you people how happy I am after ordering the -torque meister- type tool that recently came up after a long absence. Such fast and accurate service after I ordered online. The price was the best since this tool had it all included. My 6v and 12v VW's are happier for it. I couldn't wait until I got home to try it out on a stubborn gland nut. I didn't want to bust my butt on this one- the future rebuild. I nearly teared up as I applied minimal force on the geared end. Uhhh! Instantly paid for itself!!! Dennis C.~ Mpls. MN
WORKS ON ALL 12-1600CC ENGINES WITH STOCK SIZE 36MM GLANDNUT & 36MM DRUM AXLE NUTS WITH 12MM BOLTS.
INSTRUCTIONS:
This tool is invaluable to anyone doing brake or engine work. The kit comes with all the parts needed to loosen the 12-1600cc engine flywheel 36mm gland nut or 36mm axle nuts on either 5 bolt 205mm or 4 bolt 130mm rear drums.
The ring gear section with the 4 holes in it is for attaching to the rear brake drum when loosening or tightening the rear axle nut. For wide 5 bolt pattern use the top set of holes and two stock lug nuts to attach the ring gear section to the drum. For 4 bolt pattern use the bottom holes and two stock lug nuts to attach to drum. Next attach the narrow toothed long gear shaft to the top of the 36mm lever shaft with shims on either side making sure, for drums, the gear is on the protruding side of the socket lever and secure with clip. Then slide the socket lever assembly onto the axle nut and mesh the gear shaft at the top to the ring gear section already attached to the drum. If loosening, any socket or wrench will work on the hex end of the gear shaft using the gear drive and the socket lever to loosen the nut. You may have to reapply the tool once you run out of teeth on the ring gear section.
For flywheels you have to reverse the drive shaft gear so the gear is on the flush side of the socket lever. Flywheels are either 12v or 6v so there are two different gears to accommodate this. The long gear with narrow teeth is 12v and the short gear with coarse teeth is for 6v.
**When tightening please use a proper torque wrench as this tool WILL over tighten bolts and breakage CAN and WILL occur**
25 ft lbs = 230 at the nut/bolt. 30ft lbs= 270 at the nut /bolt."
"Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind."
- Dr. Seuss
VW 181 Archive: https://sites.google.com/site/jeffgilleland/vw_archive
| _______
| |_______| '73 Thing "481"
| _\_\_|_/_/_
| |O||_4_||O|
http://vwthingregistry.com
https://doublecabshaka.wordpress.com
View user's profile Send private message Visit poster's website AIM Address Yahoo Messenger Gallery Classifieds Feedback
Banker
Banker is offline
PostPosted: Sat Nov 12, 2011 7:45 pm    Post subject: Reply with quote
used a breaker bar with 36mm socket
now add 5 feet of pipe and stand on it Smile not kidding
Brian
07 Charger Sublime
03 Goldwing
74 Thing
///Mink
///Mink is offline
PostPosted: Sat Nov 12, 2011 7:31 pm    Post subject: Reply with quote
A big impact gun or if you don't have access to that, a torque meister tool would probably work, too.
analogmax
analogmax is offline
I had the same problem. I broke two cheater bars trying to get mine off. I finally borrowed a 5' torque wrench and it took it off no problem. You could also try one of these http://www.vwparts.net/LR000133.html I have heard a lot of good things about them.
sixty9fasty
sixty9fasty is offline
PostPosted: Sat Nov 12, 2011 7:29 pm    Post subject: Reply with quote
Do yourselves a favor and buy a torquemeister/torquebuddy whatever they are calling them now a days.. You'll thank yourself.
