Throw Out Bearing Clip Safety Wire
Zundfolge1432 Premium Member
Zundfolge1432 is offline
PostPosted: Sun Jan 22, 2023 8:52 am    Post subject: Re: Throw Out Bearing Clip Safety Wire Reply with quote
nsracing wrote:
Geezus Christians! Why do you need all the wires in there? Laughing
You people are overthingking this. I have never had one fall out of the groove.
Because it hasn’t happened to you therefore it’s not a problem?
Fact is it does happen, I’ve seen it more than once and VW quietly changed the design.
Dauz
Dauz is offline
PostPosted: Wed Mar 06, 2019 6:45 am    Post subject: Re: Throw Out Bearing Clip Safety Wire Reply with quote
I’ve broken a throw out bearing shaft with a 2300lb pressure plate. I’m sure the arm was worn. Never had a clip fall out under normal circumstance.
Casting Timmy
Casting Timmy is offline
PostPosted: Tue Mar 05, 2019 5:12 am    Post subject: Re: Throw Out Bearing Clip Safety Wire Reply with quote
I don't like the Empi style throw out bearings on the early (or late), but especially the early as they have shallow pockets for the clips. If you get a Sachs throw out bearing it has the plastic insert that the clip sits in, but the clips sit in there all the way.
Empi or anyone selling the metal lugs on the side I'd say away from as it doesn't leave any install room for that leg of the clip.
FreeBug
FreeBug is offline
PostPosted: Mon Mar 04, 2019 9:23 am    Post subject: Re: Throw Out Bearing Clip Safety Wire Reply with quote
I think it's a bit of a placebo, but if that's what he needs to be able to sleep at night , so be it.
I'm pretty sure we all have one bit of our car that was modified strictly out of fear...or a bad previous experience. Different folks, different phobias...
And I have seen one fail, it's usually because the arm is very worn where the bearing rests, esp. if it's just one side... but you would have spotted that. I've also seen well-maintained stuff that was still running on it's original graphite T.O. bearing. So grease that surface!!! (copper is good for heat).
nsracing
nsracing is offline
PostPosted: Mon Mar 04, 2019 8:40 am    Post subject: Re: Throw Out Bearing Clip Safety Wire Reply with quote
rugblaster
rugblaster is offline
PostPosted: Sun Mar 03, 2019 10:11 pm    Post subject: Re: Throw Out Bearing Clip Safety Wire Reply with quote
The reason the early style clips started falling out is because the saddles the TO bearing rides in are worn out from 70 years of use. Add to that some shitty built Chinese junk and spring steel clips that aren't that springy and it is what it is. I don't know if I have ever seen a loopy one fail if properly installed.
The later model TO bearings and diaphragm clutch plates were a game changer.
'69 Karmy, '69 Camper, Meyers clone, '65 drag bug, 10.78 @ 128 (sold it) '51 Dodge farm truck,
'09 MB E350 '18 MB E400, '65 Plymouth Valiant convertible and a '19 Ford F250 King Ranch (nicer, but dirty, farm truck)
VWoA factory trained line tech 75 till 90 or so
ASE Master Certification
VWoA Assoc. of Quality Technicians inductee (One of 25 in the five state southwest region)
La Confrerie des Chevaliers du Tastevin (San Angelo Chapter)
TCU ......GO FROGS!!!!!!
sufidancer
sufidancer is offline
PostPosted: Sun Mar 03, 2019 5:57 am    Post subject: Re: Throw Out Bearing Clip Safety Wire Reply with quote
I have a 67 trans with the early "U" shaped clips , are the clips that have a closed loop better or safer? Do they even work on early split trans or should I stay with factory U shaped clips?
I have the trans out and have and have a chance to put new clips in since these are probably original.
Thoughts?
mcmscott
mcmscott is offline
PostPosted: Tue Dec 20, 2011 9:19 am    Post subject: Reply with quote
As Volkswagen spent more time and effort coming up with the irs trans in 68-69( sooner than the late tob) you are also saying that all swing cars are junk and you would never work on one? VW used the early design tob for more than 30 years with no real problems, that is a fact, didn't mean to create an arguement just to state facts, not oppinions
Bruce
Bruce is offline
PostPosted: Tue Dec 20, 2011 1:38 am    Post subject: Reply with quote
mcmscott wrote:
I have used hundreds if not thousands of early tob's and never had a single failure due to clips falling off.
The only way your claim can be true is if you've kept in contact with all those thousands of gearbox buyers over their car's whole lifetime. If the clips fell off a TO bearing on one of your gearboxes 5 years after you built it, why would the owner bother to call you up and whine about it? They'll just fix it and get on with life.
mcmscott wrote:
. I'm not saying the later bearing is not supperior,
There must've been a reason VW went to all the trouble to do the redesign if the original design was so reliable.
mcmscott wrote:
there is nothing wrong with an early if set up correct
And yet they do fall off.
Dale M.
Dale M. is offline
PostPosted: Mon Dec 19, 2011 11:55 am    Post subject: Reply with quote
RailBoy wrote:
Dale M., just to cover it in a Bug you are suppost to have 1/2" to 1" of Pedal movement with your clutch pedal before ingagement? Been a while since I have seen the book on this, but this approach impliments what you are getting at.... Just making sure my measurement is not off.... RB
My Haynes manual states 1/2 to 3/4 inch .... But then again when you think of length of clutch pedal and all the ratios involved (hook at pedal pivot and length of arm(s) in trans axle), if TB drops off pins, you can not be within adjustment tolerances because movement at actual TB is probably about 1/16- 3/32 at MOST (to contact) when free play is correct... The concept is to keep TB really close to, but not touching clutch cover springs (or ring) when not depressed...
Dale
RailBoy
RailBoy is offline
PostPosted: Mon Dec 19, 2011 9:55 am    Post subject: Reply with quote
clonebug
clonebug is offline
PostPosted: Mon Dec 19, 2011 9:40 am    Post subject: Reply with quote
Dale M. wrote:
IF throw out bearings loose clips and falls off throwout arms and lands on input shaft, your clutch free pay is adjusted incorrectly.... IF adjusted correctly there is not enough clearance (room) for it to fall off throwout forks...
Dale
I agree!!!1
Clonebug
Dale M.
Dale M. is offline
PostPosted: Mon Dec 19, 2011 9:31 am    Post subject: Reply with quote
IF throw out bearings loose clips and falls off throwout arms and lands on input shaft, your clutch free play is adjusted incorrectly.... IF adjusted correctly there is not enough clearance (room) for it to fall off throwout forks...
Dale
mcmscott
mcmscott is offline
PostPosted: Mon Dec 19, 2011 8:47 am    Post subject: Reply with quote
I have used hundreds if not thousands of early tob's and never had a single failure due to clips falling off. I'm not saying the later bearing is not supperior, just there is nothing wrong with an early if set up correct
lostinbaja
lostinbaja is offline
PostPosted: Mon Dec 19, 2011 8:41 am    Post subject: Reply with quote
I have been driving and racing VW's since 1972 and I have never had a TO bearing clip fall off. I never used safety wire on them.
Jerry...
If it's being towed, it must be a trailer!
"Vee Grow Too Soon Oldt Und Too Late Schmardt"
RIP Morgan
My photos
http://www.manxgallery.org/gallery/album92
Bruce
Bruce is offline
PostPosted: Mon Dec 19, 2011 1:32 am    Post subject: Reply with quote
clonebug wrote:
Where would the bearing go if the clips DID fall out????
Unneeded as far as I can see.
The TO bearing falls off and lands on the input shaft. Then when you push the clutch pedal, it doesn't work right. Usually some parts are damaged in the process.
Unneeded for you now, but wait until it happens to you. Spending 5 min with some wire is certainly less work than pulling your engine when it happens. Stick around this board for a while, it happens much more than you think. It is part of the reason I NEVER use the early crappy type TO bearing.
bartman
bartman is offline
PostPosted: Sun Dec 18, 2011 6:56 pm    Post subject: Reply with quote
I've had this happen. My bearing came off of one of the forks which rendered the clutch ineffective (and ruined the bearing). The pedal feel was such that I thought I'd broken the cable.
The clip got wedged behind the flat clutch springs, requiring me to construct a lever apparatus to compress the clutch while I fished out the clip with a magnet-on-a-stick.
Remember, kids------> KCR Transmissions SUCKS
clonebug
clonebug is offline
PostPosted: Sun Dec 18, 2011 6:31 pm    Post subject: Reply with quote
Clonebug
Dale M.
Dale M. is offline
PostPosted: Sun Dec 18, 2011 5:43 pm    Post subject: Reply with quote
It will work... Time to move on ...
Dale
Bruce
Bruce is offline
PostPosted: Sun Dec 18, 2011 5:37 pm    Post subject: Reply with quote
I would have drilled the holes lower on the arms. You want to hold the clips in, not up.
