Robw_z Samba Member
Posted: Sat Jul 12, 2025 6:42 am Post subject: |
denwood wrote: |
Using a Digifant II AFM in my conversion. I could not discern a difference between the 1990 Vanagon AFM and Jetta Digi II ...and from this post I can see they are indeed interchangeable. |
Curious if there is any fuel mileage difference or the like. While they may be plug and play, I always had it in mind the inline 4 and flat 4 had different engine mapping in the ECU. No proof of that at all, I just got that impression from this page in the Digifant Pro Training manual.
-Rob |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 7208 Location: Honolulu,Hawaii and France
16CVs Samba Member
Joined: February 22, 2004 Posts: 4250 Location: Redwood City, California
Posted: Fri Jul 11, 2025 9:59 am Post subject: Re: Digifant AFM - Differences between Vanagon and Jetta units? |
Kam
Thank you ! _________________ 1987 Syncro Westfalia Triple knob (bastard)
Samba member # 14980
Don't let your van end up in an "abortions" thread. |
kamzcab86 Samba Moderator
Posted: Fri Jul 11, 2025 9:16 am Post subject: Re: Digifant AFM - Differences between Vanagon and Jetta units? |
16CVs wrote: |
So, thoughts that a Digifant Jetta coil will work with no issues on a Digifant Vanagon? |
Part #211-905-115D
Fits the following VW models:
Cabriolet - all
Fox - 1.8L
Vanagon - 1.9L, 2.1L
Scirocco II - 1.8L 8V
Quantum - 2.2L 5-cylinder
Jetta II - 1.8L 8V
Golf II - 1.8L 8V
Corrado - 1.8L G60 _________________ ~Kamz
2016 Golf GTI S
16CVs Samba Member
Posted: Fri Jul 11, 2025 8:21 am Post subject: Re: Digifant AFM - Differences between Vanagon and Jetta units? |
So the thoughts a that a Digifant Jetta coil will work with no issues on a Digifant Vanagon ?
Stacy _________________ 1987 Syncro Westfalia Triple knob (bastard)
Vanagon Nut Samba Member
Joined: February 08, 2008 Posts: 10497 Location: Sunshine Coast B.C.
Posted: Mon Jul 03, 2017 3:10 pm Post subject: Re: Digifant AFM - Differences between Vanagon and Jetta units? |
Has anyone tried a Jetta/Golf AFM on a 1.9 WBX?
Lucky me, found a spare AFM from a diesel Vanagon parts + I4 RV code set up I bought. Was able to move the PCB so wiper has new real estate.
_________________ 1981 Westy DIY 15º ABA
(VW Gas I4)
1988 Westy DIY 50º ABA
VE7TBN |
denwood Samba Member
Joined: July 29, 2012 Posts: 1047 Location: Thunder Bay, Ontario, Canada
Posted: Mon Jul 29, 2013 10:34 am Post subject: |
Using a Digifant II AFM in my conversion. I could not discern a difference between the 1990 Vanagon AFM and Jetta Digi II ...and from this post I can see they are indeed interchangeable. _________________ Cheers,
Dennis Wood
The Grape |
dave-1982 Samba Member
Posted: Mon Jul 29, 2013 9:06 am Post subject: |
Wow ! Glad to hear it worked, can you post the Bosch # of the Jetta AFM part?
Dave |
Dave.Arthur Samba Member
Joined: November 02, 2009 Posts: 55 Location: Yarmouth, Nova Scotia, Canada
Posted: Tue Jul 17, 2012 3:51 pm Post subject: |
I put a few Km's on the van today. The AFM worked well, I felt it had a bit more oomph in the upper RPM range (3-4K). I did readjust the idle mixture and TB idle bypass. I was getting a little hesitation between the idle and operation.
I'm attributing the better performance to the fact that I readjusted the pot in the AFM.
For my money they are interchangeable. |
nemobuscaptain Samba Member
MidwestDrifter Samba Member
Joined: June 13, 2012 Posts: 769 Location: Kicking Around Australia
Posted: Mon Jul 16, 2012 1:49 pm Post subject: |
Good to know. I have a digi2 I4 setup in my van, would be a real resource to be able to use vanagon parts on the road.
Also, I can look up if someone is interested, but several models of BMWs from the 80s use the same AFM as the I4 digifant setup. Some have a slightly larger sized one which can be made to work by adjusting the spring tension. _________________ 2004 Dodge/Mercedes Sprinter (Custom Camper)
2000 Jetta TDI
1982 Diesel Westy W/ ABA I4 hybrid (Sold)
Epic Road Tripping since 08/05/12 | http://VagariesAbound.blogspot.com/
My Current Build | http://sprinter-source.com/forum/showthread.php?t=41215 |
Posted: Mon Jul 16, 2012 1:32 pm Post subject: |
I rebuilt the Jetta AFM. Moved the pot wiper to a new track and cleaned the unit.
I confirmed my 2.1 timing, idle, TPS etc. and then swapped in the Jetta AFM. Other than setting the idle bypass mixture, it was a direct install.
Van works fine, as expected. My conclusion is that there is little difference, if any between the AFM units. Closed loop operation depends upon the lambda sensor for mixture... All theory, I will be doing a good road trip in a few days and will report back. |
Captain Pike Samba Member
Joined: December 30, 2003 Posts: 3437 Location: Talos IV, Piedmont Arizona
Posted: Mon Jul 16, 2012 8:33 am Post subject: |
'Fant 2 has no spark. Nuff said _________________ LEARN TO SELF RESCUE
....Bad Sneakers.... |
Posted: Mon Jul 16, 2012 6:34 am Post subject: |
There is a chance that the spring tension maybe be set differently. If that is the case, it would yield different output voltages for the same flow rate. Regardless, I see no reason why it wouldn't at least run, though maybe very poorly. _________________ 2004 Dodge/Mercedes Sprinter (Custom Camper)
2000 Jetta TDI
Posted: Mon Jul 16, 2012 4:32 am Post subject: |
I wasn't able to find much in the archives. The unit is plug compatible, sensors (TEMP 1) have the same slope. The only differences I can see are the part numbers (both BOSCH and VW).
Since the unit measures the amount of air coming into the engine and yields a signal proportional to it, since the target AF mixture would be the same on any normal engine and that they are inputting to a similar ECU, I'm guessing that it will work.
However working and working well may be different issues
Surely someone has tried... |
Posted: Sun Jul 15, 2012 8:07 pm Post subject: |
I've wondered too. I"m sure it's been discussed no?
Search here for Tencentlife video of measuring voltage range of Vanagon AVM, (edit: AFM) ignition on.
If it were me, I would:
- supply 12V, test and compare voltage range of Jetta AFM to Vanagon AFM. (IIRC Vanagon AFM is like ~ 0.25v "closed" to 4.5v wide open)
- no power supplied, measure resistances on each as shown in Bentley.
- measure air intake temp sensors, compare. (does Jetta AFM have this part?)
If all is the same, or even close, can't see why it wouldn't work. I mean, the O2 system + ECU might compensate for any subtle differences?
Edit: and compare wiring to be sure they're the same!
(VW Gas I4)
VE7TBN |
xoo00oox Samba Member
Joined: February 11, 2010 Posts: 2725 Location: East Nassau, NY
Posted: Sun Jul 15, 2012 5:26 pm Post subject: |
Some things that are the same-
Temp sensor
Hall sensor (not complete Dist, sensor only)
Coil
Cap + rotor
Idle stabilizer
Oxygen sensor can interchange
Some things that are not the same-
Idle control is built into jetta ECM
Knock sensor used on jetta
ECM
This is just a quick list off the top of my head. I know I tried swapping a jetta air flow sensor into a van, I don't think it worked. |
Posted: Sun Jul 15, 2012 4:45 pm Post subject: Digifant AFM - Differences between Vanagon and Jetta units? |
Looking through my parts bin, I found an AFM from a Jetta. Similar in appearance to the Vanagon unit (2.1l).
Of course there must be some differences with the setting, electronics or both. Has anyone investigated what those differences would be? |
