Rookie flywheel removal question
75smith
75smith is offline
PostPosted: Fri Feb 22, 2013 5:32 pm    Post subject: Reply with quote
First time I removed a gland nut, tried a 1/2" impact(100 gal tank), tried for a couple minutes, nothing, my marks hadn't moved, so tried a 5 ft angle iron bolted up with a 6 ft 3/4" breaker, nothing had my whole weight on it(I weigh 220), tried the impact again, nothing, came back the next morning, shop had cooled down quite a bit, tried the impact again-came right off, didn't even take 2 seconds....still can't explain it, but sometimes it just takes time
by the way Glenn, nice one, you use the starter gear off a starter?
My 1975 Beetle Build Updated 8-21-12
My engine build
therealfrogman
Samba Guitar Hero
therealfrogman is offline
PostPosted: Fri Feb 22, 2013 4:29 pm    Post subject: Reply with quote
The inpact did it! I did have to heat it up a bit but it came right off. I did not think my 1/2 driver would do it (26 gallon tank) 150 psi.... Yipee!
73 Camper Tin Top/Type 4 1.8 engine, Single progressive EMPI carb, electronic ignition SVDA W/ Vacuum.
Really appreciate what Everett has done here. Almost like he hand picked some of you. I am very thankful for all the help I get here.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Fri Feb 22, 2013 11:17 am    Post subject: Reply with quote
Home made one.... 9:1 factor.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
SBD
SBD is offline
PostPosted: Fri Feb 22, 2013 11:07 am    Post subject: Reply with quote
tattooed_pariah wrote:
The "torque-meister" or torque multiplier, is worth every penny.. I bought one for about $50 last year and I love it, you get EXACT torque instead of what I used to do.. (hmmm.. I weight about 150 pounds, so if I have a 3 foot jack handle on my breaker bar, and I hold it about this far away and put my body weight on it.... Rolling Eyes )
plus, if you have stock rear brakes, it works for those nuts too.
Yeah, I finally broke down & bought one of those too. Only way to go.
Mr. 010
Glenn is offline
PostPosted: Fri Feb 22, 2013 11:04 am    Post subject: Re: Rookie flywheel removal question Reply with quote
therealfrogman wrote:
Any ideas for a guy working solo to stabalize the case while I take the flywheel nut off?
Use a impact gun, you barely need to hold it.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
tattooed_pariah
tattooed_pariah is offline
PostPosted: Fri Feb 22, 2013 11:02 am    Post subject: Reply with quote
-pariah
'72 Volksrod
SBD
SBD is offline
PostPosted: Fri Feb 22, 2013 9:55 am    Post subject: Reply with quote
Be careful when using that tool in the middle in Dale M's post. A friend gave his to me when he was through with it. He bought it new and used it while rebuilding one engine. The first time I used it the welds gave up and the handle came off. ABSOLUTELY NO WELD PENETRATION. It might as well been glued on with JB Weld. And this was well over 20 years ago, before the amount of offshore stuff was as bad as it is now. Just sayin'.....
Not sure where he bought it. Rolling Eyes
modok
modok is offline
PostPosted: Thu Feb 21, 2013 10:03 pm    Post subject: Reply with quote
I have seen those clamps too, not sure what they are supposed to do.......
Another vote for "bolt a long thingy to it"
therealfrogman
Samba Guitar Hero
PostPosted: Thu Feb 21, 2013 9:14 pm    Post subject: Reply with quote
BTW, you guys are great! I made the clamps based on some of the pics I saw of what I guess is the actual tool, I think they will work but I will be careful not to destroy any thing. Going to be doing a 12volt conversion with my rebuild.
therealfrogman
Samba Guitar Hero
PostPosted: Thu Feb 21, 2013 9:07 pm    Post subject: Reply with quote
Thank you!
runchman
runchman is offline
PostPosted: Thu Feb 21, 2013 8:55 pm    Post subject: Reply with quote
big ass bar bolted thru a couple holes, and mine came off *really* easy. I think my bar is about 4 feet long:
runchman
runchman is offline
PostPosted: Thu Feb 21, 2013 8:54 pm    Post subject: Reply with quote
skills@eurocarsplus
Samba Peckerhead
PostPosted: Thu Feb 21, 2013 8:42 pm    Post subject: Reply with quote
ahem....
if you are going to get all john muir on that, please be careful
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
Joel
Joel is offline
PostPosted: Thu Feb 21, 2013 8:38 pm    Post subject: Reply with quote
chrisflstf wrote:
Now you need an impact or get a long piece of angle iron that you can bolt to 2 holes in the flywheel. Get a helper also to stabilize it
That;s all I;ve ever done but I wouldnt use a rattle gun, a breaker bar is much more controlled.
Dale M.
Dale M. is offline
PostPosted: Thu Feb 21, 2013 8:24 pm    Post subject: Reply with quote
chrisflstf wrote:
Its easier to loosen the nut before you remove the heads/cylinders.
This is what I use.....
And there is proper tool for locking flywheel.... Be real careful with home made tool, if it fails you can be on a impact course with objects in shop....
http://www.mamotorworkstv.com/vw/product/engine-flywheel-lock-tool_111476/
IF you can not budge flywheel (its torques to 276 ft-lbs) take it to commercial tire shop (services truck tires) and have them hit it with 3/4 or 1 inch air impact... Takes about 3 seconds....
Then there are these tools....
http://www.mamotorworkstv.com/vw/product/air-coole...ol_376122/
http://www.mamotorworkstv.com/vw/product/torque-multiplier-kit-for-gland-and-axle-nuts/
Dale
chrisflstf
chrisflstf is offline
PostPosted: Thu Feb 21, 2013 7:13 pm    Post subject: Reply with quote
therealfrogman
Samba Guitar Hero
PostPosted: Thu Feb 21, 2013 6:59 pm    Post subject: Rookie flywheel removal question Reply with quote
