S4VAGE Samba Member
Posted: Sun Apr 13, 2025 9:20 am Post subject: Re: TerraPodz: Vanagon Projektzwo auxiliary light repros |
MsTaboo  Samba Member
Joined: June 02, 2006 Posts: 4548 Location: East Kootenay, British Columbia
Posted: Thu Jul 04, 2024 3:05 pm Post subject: Re: TerraPodz: Vanagon Projektzwo auxiliary light repros |
We should probably keep this thread for TerraPodz info and use the thread for original Projektzwo stuff here:
https://www.thesamba.com/vw/forum/viewtopic.php?t=...;start=100 _________________ Currently:
All that's needed for evil to prevail is for good people to do nothing.
Resist Kleptocratic Oligarchy (and Idiocracy)! |
Sodo Samba Member
Joined: July 06, 2007 Posts: 10627 Location: Western WA
Posted: Thu Jul 04, 2024 1:18 pm Post subject: Re: TerraPodz: Vanagon Projektzwo auxiliary light repros |
I like the look of the rectangular headlights with the lower ProjektZwo grille extension.
I have these lamps. They were installed when I bought my van in 2008.
Are these the originals?
They have a thick clear vinyl “protection” stuck to the glass. _________________
....KTMs, GasGas, SPOT mtb |
ZsZ Samba Member
Joined: December 11, 2010 Posts: 1733 Location: Budapest Hungary, Europe
Posted: Wed Jul 03, 2024 11:02 pm Post subject: Re: TerraPodz: Vanagon Projektzwo auxiliary light repros |
MsTaboo wrote: |
It's too bad Projektzwo didn't use a more widely available lens.
The depth was the limit IMO for the specific lens.
The style and size was kinda common in the 80s here in europe, but did not make it into the 90s.
Plastic bumpers killed the market of aftermarket lenses
There are repros of the specific lens available, but they do not have E or DOT marks so they are not street legal. _________________ Zoltan
1.9 MTdi 2wd Multivan (ex Caravelle)
Van since 2006, engine since 2008 |
Posted: Wed Jul 03, 2024 3:16 pm Post subject: Re: TerraPodz: Vanagon Projektzwo auxiliary light repros |
Tristar Eric wrote: |
I think this should get you guys excited. We are working on a glass lens TerraPodz V2. Using a Hella 550 lamp. Easy to find replacements if ever you should need one. Uses an H1 bulb or LED equivalent.
This is our proto test fitting right now. We've got a little tweaking to do then hopefully live in a month or two. Best part is that we manufacture our parts and have 100% control on quality and availability.
Good idea using an off the shelf lens, only drawback I can see is how fragile those 550's seem to be. At least in my experience, I have a box of cracked / fogged lenses.
I have a set of original Projektzwo$ I only mount occasionally when I want to show off, otherwise they stay in a box covered in bubblewrap . _________________ Currently:
VicVan Samba Member
Joined: July 01, 2015 Posts: 1936 Location: Vancouver Island, BC
Posted: Wed Jul 03, 2024 2:33 pm Post subject: Re: TerraPodz: Vanagon Projektzwo auxiliary light repros |
Looks great. Using off-the-shelf light source is awesome too. Especially given that the hella 550 is available in fog, driving, white, amber... _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12295 Location: Santa Cruz, CA
Posted: Wed Jul 03, 2024 2:21 pm Post subject: Re: TerraPodz: Vanagon Projektzwo auxiliary light repros |
I like the new design.
I have those lights mounted above the bumper on a bracket but don't like the look of them just hanging out there. |
Tristar Eric Samba Member
Joined: July 25, 2004 Posts: 1262 Location: Portland, Or
Posted: Wed Jul 03, 2024 2:04 pm Post subject: Re: TerraPodz: Vanagon Projektzwo auxiliary light repros |
_________________ Vanagon/Transporter flares here: www.terrawagen.com
[email protected] |
Italjohn Samba Member
Joined: October 29, 2016 Posts: 205 Location: Molde, Norway
otiswesty Samba Member
Joined: November 21, 2006 Posts: 1768 Location: Portland
Posted: Thu Sep 07, 2023 9:44 pm Post subject: Re: TerraPodz: Vanagon Projektzwo auxiliary light repros |
What type of bulb does the MMT3 Fog lights use? _________________ 1978 Sage Green P22 Westfalia
1988 T3 Syncro Single cab
Just a regular guy |
Honuak Samba Member
Posted: Fri Jun 23, 2023 3:01 pm Post subject: Re: TerraPodz: Vanagon Projektzwo auxiliary light repros |
1988M5 wrote: |
Heads up, the stock while ones were only 5 watts, the amber you linked are a whopping 40 watts! I doubt there is enough space to dissipate all that heat. |
Ooops
wrong link
fixed it |
1988M5 Samba Member
Joined: January 23, 2016 Posts: 843 Location: Tucson, AZ
Posted: Fri Jun 23, 2023 2:59 pm Post subject: Re: TerraPodz: Vanagon Projektzwo auxiliary light repros |
Heads up, the stock while ones were only 5 watts, the amber you linked are a whopping 40 watts! I doubt there is enough space to dissipate all that heat. _________________ 1991 tin top GL
Some BMWs. |
Honuak Samba Member
Timwhy Samba Member
maco70 Samba Member
Joined: March 16, 2011 Posts: 488 Location: Montréal, Québec
Posted: Wed Jun 08, 2022 4:24 am Post subject: Re: TerraPodz: Vanagon Projektzwo auxiliary light repros |
Hi to all,
Is someones know Where can I buy a replacement LED for my repros of Projektzwo, which as one side burnt
Thanks in advance ! _________________ Martin from Montréal
1986 Vanagon GL full camper westfalia
(brown/tan interior) |
tarandusVDub Samba Member
Joined: August 27, 2010 Posts: 1683 Location: Between Here and There
Posted: Mon Nov 29, 2021 8:25 am Post subject: Re: TerraPodz: Vanagon Projektzwo auxiliary light repros |
My TP are still working fine after probably 6 or 7 years (bought them when they first came out), but the driver's side lens has a wicked cataract. Guess the lens quality was different between the two lights. Too bad because they look pretty trashed now. All the LEDs are still working tho. _________________ 1990 Syncro 16" DoppleKabine 2.1 DJ 112i
________________________
Sold: 1972 Bay Campmobile; 1984 Westy, base model, 2WD. |
Team WorldTour Samba Member
Joined: September 02, 2010 Posts: 2427 Location: Der Vaterland
Posted: Fri Nov 26, 2021 2:08 am Post subject: Re: TerraPodz: Vanagon Projektzwo auxiliary light repros |
I don't, sorry.
I'm not personally involved with them, I'm just a satisfied customer. _________________ 1990 Feldjäger Syncro AAZ
Click to view image
H6 Subaru Engine Swap Thread
WV2ZZZ25ZFH094138(x)/ WV2YB0257LH057308(x)/ WV2ZZZ25ZLG113270/
"Where am I going? And what am I doing in this handbasket?" -Nicodemus Jordan
When All Else Fails: Lather, Rinse, Repeat! |
tsrhines Samba Member
Joined: September 03, 2021 Posts: 13 Location: Arkansas
Posted: Fri Nov 26, 2021 12:22 am Post subject: Re: TerraPodz: Vanagon Projektzwo auxiliary light repros |
Team WorldTour wrote: |
I don't have a clue what is happening over on Facistbook.
I am also unaware of actual current prices.
What I can say, is that I've owned both. The originals sucked as far as build quality. The TPs are leaps and bounds better.
The TPs have polycarbonate lenses and ABS housing.
The originals don't. Also, impossible to find replacement parts for.
Which is exactly why, I suspect, the TPs were created. |
Any idea where I can find new lenses? Mine are kinda rough… |
Posted: Thu Nov 25, 2021 2:42 pm Post subject: Re: TerraPodz: Vanagon Projektzwo auxiliary light repros |
I agree 100% it's an appearance thing.
They also do a fair job of DRL. I love mine. _________________ 1990 Feldjäger Syncro AAZ
Click to view image
