Are Westys artificially overpriced?
nemobuscaptain
nemobuscaptain is offline
PostPosted: Sun Aug 07, 2022 6:05 pm    Post subject: Re: Are Westys artificially overpriced? Reply with quote
xoo00oox wrote:
That is a nice setup you have there and from the little bit I can see in the pictures, it looks like you've got a very nice spot there.
Here's my generator- I made it remote start so I can just push a button from inside the house to turn it on. You can barely hear it run.
That is fantastic.
But did you consider lowering it and adding a turbo?
Ohio Valley Tribe, Full Moon Bus Club https://www.facebook.com/groups/294422277314227/
https://www.facebook.com/groups/FullMoonBusClub
RIP Bob Hoover https://www.thesamba.com/vw/forum/viewtopic.php?t=427791
Hoover Sermons: https://www.vwsage.com/images/vwsage/Bob%20Hoovers%20Sermons.pdf
GoEverywhere
GoEverywhere is offline
PostPosted: Sun Aug 07, 2022 11:59 am    Post subject: Re: Are Westys artificially overpriced? Reply with quote
xoo00oox wrote:
Phishman068 wrote:
xoo00oox of course you have a custom generator running a VW engine. Is that a turbo engine?!?
Nope- Just an inline 2.0 4cyl from a 2012-15 Jetta. You can buy them for about $300 with low miles. It is the same engine they used in the MK4's from '99-2005, they brought them back into production. It was probably the most reliable engine I've seen from VW.[/quote]
Not too often you see a fuel injected generator. I love it!
xoo00oox
xoo00oox is offline
PostPosted: Fri Aug 05, 2022 1:00 pm    Post subject: Re: Are Westys artificially overpriced? Reply with quote
[/quote]
Phishman068
Phishman068 is offline
PostPosted: Fri Aug 05, 2022 12:38 pm    Post subject: Re: Are Westys artificially overpriced? Reply with quote
xoo00oox of course you have a custom generator running a VW engine. Is that a turbo engine?!?[/quote]
http://www.thesamba.com/vw/forum/viewtopic.php?t=559766&highlight=winter+rust
http://www.thesamba.com/vw/forum/viewtopic.php?t=482402&highlight=sunroof+syncro
http://www.thesamba.com/vw/forum/viewtopic.php?t=569774
http://www.thesamba.com/vw/forum/viewtopic.php?p=6864936#6864936
"Along with the ability to go fast, one looses the desire to hurry."
xoo00oox
xoo00oox is offline
PostPosted: Fri Aug 05, 2022 11:57 am    Post subject: Re: Are Westys artificially overpriced? Reply with quote
heimlich wrote:
That right there is awesome. Did you have to do major modifications to the engine or does it output everything you need?
Thanks Heimlich, the engine is not modified at all. It just turns a high power alternator to charge my battery bank up. It only runs at about 900 rpm to keep the noise down. I have a moped muffler on it to help keep it quiet as well.
heimlich Premium Member
VWNOS.com
heimlich is online now
PostPosted: Fri Aug 05, 2022 10:14 am    Post subject: Re: Are Westys artificially overpriced? Reply with quote
xoo00oox
xoo00oox is offline
PostPosted: Fri Aug 05, 2022 9:58 am    Post subject: Re: Are Westys artificially overpriced? Reply with quote
jimf909 wrote:
xoo00oox wrote:
jimf909 wrote:
xoo00oox wrote:
jimf909 wrote:
fxr wrote:
If you go off-grid (and I don't believe you can't!) then $6,000 will buy you a DIY 15kW solar setup complete with 12kWh of LiFePO4 battery back-up.
No good if you want to still have access to the grid of course, as permits etc would be prohibitive.
Can you share more details on how all that is purchased for $6K?
I have been living totally off-grid for years and only have about half that invested including my backup whole house generator.
4 100 watt panels, Victron controller and battery monitor, 6 6v deep cycle batteries in an outside storage enclosure, 2015 VW Jetta 2.0 engine for my generator. I can go a full 9 months without using the generator at all. In the winter when the days are short, I usually will need to key it run about an hour or hour and a half each day to charge up the batteries. No inverter, the entire house is 12v DC.
That sounds like a cool system. Do you have a propane fridge to keep electric needs down? I don't doubt that living off-grid can be done with a modest, inexpensive system. I'm 100% off-grid with 1700 watts of panels, 12 FLA, 390 ah batteries, 2008 Outback controller and inverter and an old 7kw diesel generator. I'm just not clear on how to get to a balanced system that supports 12kWh of LiFePo for than $6K. Regardless, we're not talking about systems that will support Skillz 800 acre farm.
How do you charge your battery bank with the generator? Just by using a car battery charger?
A 2008 Outback VFX3524 inverter/battery charger (black box close to the middle of the photo). The battery bank and generator are connected to the inverter/charger and it will invert the 24V battery bank to 120 AC to the house. When the generator is running it will step-down the 120 AC from the generator to charge the batteries while also passing the 120 AC from the generator to the house, i.e. when the generator is running it charges the batteries and provides the AC power to the house.
The Outback inverter: 4/0 (I believe) cables from the battery bank, the grey conduit brings AC from the generator, the steel conduit carries AC to the house.
The set-up was created by the previous owner in 2008 and the batteries were new in 2014. Our daily consumption is in the 3.5 - 5.0 kWh range with the electric fridge being the pig using 1.75 kWh per day. I hate that fridge but that's what was in the house when we bought it. The well pump, internet, appliances and lighting (LED) are other consumers of electricity.
VWNOS.com
PostPosted: Fri Aug 05, 2022 9:17 am    Post subject: Re: Are Westys artificially overpriced? Reply with quote
steve244 wrote:
https://www.texastribune.org/2022/07/05/texas-energy-bills-natural-gas-export/
https://www.cbsnews.com/news/texas-electric-bills-29-million-forgiven/
https://www.cbsnews.com/feature/texas-winter-storm/
Those news sources are biased. If you read the headline only it's misleading. Texas can do nothing about exporting gas. This is controlled by the federal government as they are responsible for the permitting and control of it. The price of natural gas is on a global market and when someone else such as Europe is willing to pay more they export it. The federal government can stop this by banning exports but they will not.
The electricity bill payments is a quite complicated matter as well. Texas has something called wholesale power. The retail electricity providers buy this wholesale power from the generators and sell it to the consumer. When electricity demand is high the price for this power goes up. When it is low the price is low. When you purchase retail electricity which is how most consumers do it the retail providers factory this in and amortize the price across the year. Wholesale is buying straight from the generators who make it. A few companies stepped in and were selling wholesale power direct to the consumers. The problem is when there is high demand the price of wholesale power jumps to $9,0000/kWh. So the consumer rate became the $9,0000/kWh. The best analogy to this is mortgage fixed rates and ARMS. As long as the federal interest rate doesn't move an ARM is a good deal. But as soon as the federal rate goes up the consumer is left paying a huge mortgage. It's real easy to see a large number on a publication about electricity prices for one day or week when something happened. Texas sells millions and millions of dollars of electricity every day. 29 million in that article is a drop in the bucket. Most likely some regulation will come about that will fix the issue to keep a consumer from doing a stupid thing.
Sodo
Sodo is offline
PostPosted: Fri Aug 05, 2022 8:31 am    Post subject: Re: Are Westys artificially overpriced? Reply with quote
Abscate wrote:
i don't blame companies/corporations for taking every tax break they can find. I do the same thing. everyone should. i don't make the rules but am forced to play the game.
The difference is the corporations do make the rules. They even became people recently.
Yeah that was an alarming change.
Groups of people are becoming corporations too now.
If power is there, someoneโ€™s gonna figure out how to wield it.
But back to the subject of overpriced Westys, if they outlaw Solar panels, only outlaws will have Solar panels.
....KTMs, GasGas, SPOT mtb
steve244
steve244 is offline
PostPosted: Fri Aug 05, 2022 8:29 am    Post subject: Re: Are Westys artificially overpriced? Reply with quote
82 AC vanagon approx 200K miles (3K are mine).
DD is a 2015 Leaf Twisted Evil
Road Trip to Hell (FL 2023)
The Vanagon's drivetrain and chassis restomod thread. Best sung to the tune of I Did It My Way...
VWNOS.com
PostPosted: Fri Aug 05, 2022 8:24 am    Post subject: Re: Are Westys artificially overpriced? Reply with quote
Companies only make the rules when the government allows them to. The larger the company grows the more rules they want made. These same companies want regulation. Regulation gives them more power. It keeps other companies from participating. The best company to have is a government backed company that allows you to operate as a monopoly.
Abscate Premium Member
Abscate is offline
PostPosted: Fri Aug 05, 2022 3:38 am    Post subject: Re: Are Westys artificially overpriced? Reply with quote
skills@eurocarsplus
Samba Peckerhead
PostPosted: Thu Aug 04, 2022 11:31 pm    Post subject: Re: Are Westys artificially overpriced? Reply with quote
MsTaboo wrote:
How about the all the corporate welfare? Like the subsidies that fossil fuel/pharma/milatary industries are still receiving despite their record profits?
lot to unpack here...
i'm fine with what you call "corporate welfare" as long as me, you, my family and neighbors can afford, live and thrive on what they are selling.
this is a bigger problem than many realize. take those on a fixed income that are elderly and can't swing the 50/mo lawn service because the guy doing it is now 95/mo
say said tradesman is forced to scrap his equipment and buy all electric stuff. he has a choice... close shop or invest 100k+ to keep his biz going and now charge 130/mo to the same folks that were paying 50/mo
the labor didn't change...cost of doing business did
and you know, i don't blame companies/corporations for taking every tax break they can find. I do the same thing. everyone should. i don't make the rules but am forced to play the game.
the big problem that djkeev brought up was deregulation, and the simple fact ONE company has a goddam monopoly on the grid here.
this is why a free market works. i don't like gas prices in Mystic so i will go to another town and save .15/ gallon
I can call around for home heating oil and save .25/gallon
don't like the price of a 2x4 at ACE? home depot, here i come
I can't go buy a bucket of electrons anywhere else other than Eversource.
i applaud those who want to homestead but i don't. i grew up poor and as a kid remember the milk in a bowl of cereal i had for dinner one night being almost frozen on the kitchen table the following morning. i've worked too fucking hard to go back to that lifestyle
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
jimf909
jimf909 is offline
PostPosted: Thu Aug 04, 2022 9:09 pm    Post subject: Re: Are Westys artificially overpriced? Reply with quote
GoEverywhere wrote:
Dang, thats a pretty low power consumption there! Looking at my solar controller stats, I'm over 10kWh today with no heat or AC running at all. Though I've generated almost 30kWh so I'm still well into the positive.
We're just two people living in the country. We do have a washer/propane drier and dishwasher used once or twice a week. No television, no furnace, no a/c, no fans. The well pump has it easy with a 25' lift so that leaves the fridge, wfh pcs, satellite internet, LED light bulbs, two slices of toast and 30 seconds of coffee grinding each day, etc. Have I mentioned I'd love to take the 28 cu ft fridge w/ice maker the previous owner left us to the dump?
- Jim
Butcher wrote:
Guilty as charged.
GoEverywhere
PostPosted: Thu Aug 04, 2022 8:39 pm    Post subject: Re: Are Westys artificially overpriced? Reply with quote
A 2008 Outback VFX3524 inverter/battery charger (black box close to the middle of the photo). The battery bank and generator are connected to the inverter/charger and it will invert the 24V battery bank to 120 AC to the house or step-down the 120 AC from the generator to charge the batteries if the generator is running while also passing the 120 AC from the generator to the house, i.e. when the generator is running is charges the batteries and provides the AC power to the house.
Solar array about 100' from the battery bank:
7kw Gen-set with a three-cylinder Perkins diesel
jimf909
jimf909 is offline
PostPosted: Thu Aug 04, 2022 8:31 pm    Post subject: Re: Are Westys artificially overpriced? Reply with quote
- Jim
Butcher wrote:
Guilty as charged.
DuncanS
DuncanS is offline
PostPosted: Thu Aug 04, 2022 7:03 pm    Post subject: Re: Are Westys artificially overpriced? Reply with quote
Maybe off topic, but at 27 k is a fully spiffed up '91 Westy over priced? Oh by the way it has a 175 foot pound torque electric motor with a 270 mile range. Plug it into my windmill.
Duncan
VWNOS.com
PostPosted: Thu Aug 04, 2022 4:18 pm    Post subject: Re: Are Westys artificially overpriced? Reply with quote
Abscate wrote:
he federal government just takes your money and then gives it back. I don't call that helping but it's the system we have now.
They take it from 7 blue states , 2 red states and hand it out to the other 41 States that boast low taxes. It turns out Ronnieโ€™s welfare queens were his Republican friends after all
Now they just print it and make our kids pay for it. We were paying 500 billion in interest a few years ago at close to 0 percent interest. Those rates are now rising. We are all to blame, you, me, and everyone that votes.
https://fiscaldata.treasury.gov/datasets/interest-...utstanding
Abscate is offline
PostPosted: Thu Aug 04, 2022 4:03 pm    Post subject: Re: Are Westys artificially overpriced? Reply with quote
VWNOS.com
PostPosted: Thu Aug 04, 2022 3:47 pm    Post subject: Re: Are Westys artificially overpriced? Reply with quote
djkeev wrote:
MsTaboo wrote:
Hmmm....I seem to remember an almost complete failure of the Texas power grid just recently due to the lack of infrastructure maintenance by power companies. Think
Fortunately for Texas the Federal gov has offered help.
https://comptroller.texas.gov/economy/resources/funding.php
Funny thing - when you think Texas you think oil right? But Texas leads the nation in wind production and is making great strides in solar.
https://comptroller.texas.gov/economy/fiscal-notes/2020/august/ercot.php
Surprisingly they are also one of the leading States in fully Electric vehicle sales!
Lot's of Tesla's here. They are great if you are wealthy.
Page 1 of 9
