djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32987 Location: Reading Pennsylvania
Abscate  Samba Member
Joined: October 05, 2014 Posts: 23826 Location: NYC/Upstate/ROW
Posted: Wed Jan 14, 2015 4:54 am Post subject: |
I can tell you from experience that Dexron VI flows at about 50 ml per minute at 10 F. I rigged a jug with a spout that could hang like an IV bag rather than sit in the cold with a funnel in my hand.
Hyoid oil will flow even slower. If you are in cold country, warm it carefully in the engine bay or put it near the heater blower first.
I've successfully used a kerosene filler pump (2 bucks) to transfer gear oil, also you can get a transfer pump from a marine store, designed for filling out drives on outboards with quart bottle of hypoid oil too. _________________ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ π π π |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10355 Location: N. Idaho
Posted: Tue Jan 13, 2015 9:58 pm Post subject: |
Good call. I use a 7 foot or so clear hose duct taped to a funnel at drip rail. Funnel held up with duct tape. Hose goes in wheel well to trans filler. If hose has no flat spots, it will all drain into trans. I pour a quart in and go do something else for 5 minutes. Repeat. Squeeze bottle with hose is a great idea. Did not know there was room. Mine was a Syncro - mebbe that's why I didn't see room for it with the skidplates in the way. _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1993 Toyota LandCruiser, 2002 BMW 325iX, 1982 Toyota Sunrader |
1vw4x4 Banned
Posted: Tue Jan 13, 2015 9:57 pm Post subject: |
Check the gear oil before you go and forget about it for the next
10,000 miles. I've seen several vanagon in my shop with NO gear oil.
DRY, nothing in them. Drove 1/2 hour to my place without a problem.
One even drove in from across the country. I had to fix several leak and refill, but none of them needed replaced. |
jslew Samba Member
Joined: March 03, 2008 Posts: 55 Location: Trinidad, CO
Posted: Tue Jan 13, 2015 9:51 pm Post subject: |
I topped it off. Forgot how much fun it is squeezing under there and using the pump on the jug! I checked to see if a quart bottle with a hose on the tip would fit up in there and flow downhill... it does. _________________ Current Garage:
'67 Cal Look Bug
'70 Westy
'73 Baja
'74 Spec Ed Love Bug - my first car bought in '86!
'89 Vanagon GL
'92 Corrado SLC |
joseph928 Samba Member
Joined: September 22, 2011 Posts: 2114 Location: flagstaff az.
Posted: Tue Jan 13, 2015 9:20 pm Post subject: trans oil |
bluefirefly wrote: |
X2, you should be good to go.
I would check the oil level in the trans for peace of mind.... |
X-3. We will be at BBB oil,pump,and tools.  _________________ 1987 syncro westy tin top sun roof , GW2.3, rear locker, decoupler, Gary Lee tire rack & winch mount, lift, south african grill, big brakes , rhein alloy ,15 BFG AT, Fiamma 10 foot awning ,140 watt rear 85 watt front solar , mppt, truckfridge, automatic fire extinguishing system, tencent oil cooler, And a RMW SS exhaust! - 1971 bug convertible 1776 engine- 2010 Subaru turbo - 1993 Toyota 4x4 truck - 1999 Harley 95 CI, big bore, Andrews cams . Also 80-84- vans. Stock 65 sunroof bug. |
dobryan Samba Member
Joined: March 24, 2006 Posts: 17136 Location: Brookeville, MD
Posted: Tue Jan 13, 2015 7:07 pm Post subject: |
Agree, I'd drive and monitor.
More important than having gear oil aboard would be a way to get it in the transaxle. If you have never filled a Vanagon, it can be quite a pain. I'd also clean off the filler area and crack the filler plug loose while you are home with tools if it fights you. Then carry the huge allen tool to do it on the road.
One of those hand pumps would do in a pinch, but you'll find two things. 1 - the hand pump won't fit the gear oil bottle screw top. 2 - there is no vertical room under there to pump up and down atop a tall gear oil bottle even if it did happen to fit (it wont). So familiarize yourself with the tedious process by topping it off successfully before leaving, then tossing the oily mess into a large tupperware box to carry with you. You'll need to have a hose on the pickup end of the pump, one on the output end, a buddy to lay under there and hold the hoses while you use both hands to hold the pump and pump it. Then you will have a half pint of oil in the hoses and the pump when you get it full. So, don't do it where you'll cause a mess. About a roll of papertowels should do it....!!
DougM _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1993 Toyota LandCruiser, 2002 BMW 325iX, 1982 Toyota Sunrader |
jslew Samba Member
Posted: Tue Jan 13, 2015 6:14 pm Post subject: |
Thanks guys. We're going for it. AAA card and several quarts of gear oil close at hand! _________________ Current Garage:
'67 Cal Look Bug
'70 Westy
'73 Baja
'89 Vanagon GL
'92 Corrado SLC |
gears Samba Member
Joined: October 28, 2002 Posts: 4411 Location: Tamarack, Bend, Kailua
Posted: Tue Jan 13, 2015 5:34 pm Post subject: |
The shift shaft bushing is possibly the slowest leaker there is. Barely any splash up there. _________________ aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com |
newfisher Samba Member
Joined: January 05, 2012 Posts: 1764 Location: The wet spot--Oregon
Posted: Tue Jan 13, 2015 5:32 pm Post subject: |
AAA and a cell phone. Have fun |
bluefirefly Samba Member
Joined: March 16, 2011 Posts: 438 Location: Calgary, Ab
Posted: Tue Jan 13, 2015 4:29 pm Post subject: |
I would check the oil level in the trans for peace of mind.... _________________ 86 Syncro Tintop G60
work in progress ...as always! |
MacLeod Willy Samba Member
Joined: February 18, 2014 Posts: 933 Location: Ontario Canada
Posted: Tue Jan 13, 2015 4:25 pm Post subject: |
As long as it is full your good to go. Im sure you will be checking for leaks often. |
jslew Samba Member
Posted: Tue Jan 13, 2015 4:20 pm Post subject: would you drive 2k miles with leaky shift shaft seal? |
89 manual GL. Getting ready to head out to Buses by the bridge. Noticed a couple of drops of oil on garage floor this morning coming from shift shaft seal. Transaxle is the only part of the van I haven't rebuilt yet - unknown miles. I drove it this morning and it leaked a couple of drops within 2 hours of parking it.
I found the thread on the breather hole... mine was completely clogged. Cleaned it out & went for a drive... no leak in the last 2 hours.
Just wanted to get a consensus on if this is a big deal or not. Reading threads, it seems like a common issue. Am I probably good for a 2000mi round trip, or if I keep driving will it most likely become a gusher? _________________ Current Garage:
'67 Cal Look Bug
'70 Westy
'73 Baja
'89 Vanagon GL
'92 Corrado SLC |
