ataraxia Samba Member
Joined: March 19, 2010 Posts: 4507 Location: Illinois
Posted: Thu Mar 24, 2016 5:48 am Post subject: Re: Early T-3 transmission in a T-1 – Advantages/Disadvantages? |
I'm wondering if the missing "C" revision part is the link or if it simply didn't exist and the production range is incorrect in the parts book.
I've owned several 65's and never seen the adjustment holes on the back - including the photos of the backing plates I sent to you last night. Those are off of a 65 that was matching numbers original. |
bobnorman Samba Newfoundlander
Joined: August 09, 2010 Posts: 1397 Location: Newfoundland
Posted: Thu Mar 24, 2016 5:11 am Post subject: Re: Early T-3 transmission in a T-1 – Advantages/Disadvantages? |
ataraxia wrote: |
bobnorman wrote: |
The backing plates for 1964 model year (shown as Aug 1, 1963 - July 31, 1964) have an outside diameter of 265mm. A different plate is indicated for 1965 up, not sure why as the drums are the same so I would assume the plates would be as well. |
ataraxia wrote: |
There are at least four versions of the backing plate:
361 609 439 Back plate - Rear brake, left
to Ch. No. 76 299
311 609 439 A Back plate - Rear brake, left
from Ch. No. 76 300 to 221 974
311 609 439 B Back plate - Rear brake, left
from Ch. No. 221 975 to 483 592
311 609 439 D Back plate - Rear brake, left
from Ch. No. 315 000 001
(parts book shows this one as having the rear access holes for adjusting the shoe, which started on the 1966 model year so something doesn't jive) |
Right you are... Missed that. Still, strange though that 65 would be indicated as having adjustment holes. _________________ Air does not freeze. Air does not boil.
http://www.thesamba.com/vw/forum/viewtopic.php?t=289807 |
Posted: Wed Mar 23, 2016 8:55 pm Post subject: Re: Early T-3 transmission in a T-1 – Advantages/Disadvantages? |
bobnorman wrote: |
ataraxia wrote: |
to Ch. No. 76 299
Posted: Wed Mar 23, 2016 7:53 am Post subject: Re: Early T-3 transmission in a T-1 – Advantages/Disadvantages? |
Well I bought the drums, and saw what happened: The backing plates slipped right inside them. So, in case anyone has the same question. The plates up to end July '63 are a smaller diameter than August 1 '63 and up, and correspondingly the (pinwheel) drums for the 1963 model year (to July 31st '63), are the same diameter as the Type 1 drums, but are much deeper (45mm).
I'm sure most of you already know all this stuff, but for those who don't, I thought I'd include my findings here...maybe save someone some unnecessary purchases and/or parts clean up.
So, doing some rough measurements, and looking at information in the parts book, this is what I’ve learned:
The drums from start to mid-August 1962 (61-62 model year) have an inside diameter of 232mm, and accommodate 40mm wide shoes.
The drums from mid-August 1962 – July 31 1963 (1963 model year) have an inside diameter of 232mm, and accommodate 45mm wide shoes.
The drums from August 1 63-July 31 65 (64 & 65 model year) have an inside diameter of 248mm, and accommodate 45mm wide shoes.
Here’s my old 63 and new 64-65 drums side by side. Same width, different diameter.
The backing plates for 1963 model year (mid-Aug 1962 to July 31, 1963) have an outside diameter of 248mm.
I can't speak to the pre-63 stuff, but there is a different plate listed for 61-62 model year -from start of production to mid-Aug 1962.
The diameter of the wheel cylinder hole in both the 1963 plates and the later (64-up) plates is 28mm, indicating that early and late wheel cylinders would fit in either.
Rear Squareback wheel cylinders from Aug 1, 1963 to July 31, 1965 (64-65 model years) are listed as all being 23.8 mm cylinders, however there are two different part numbers for model year 64 and model year 65, so not sure what the difference was there, but the front Super Beetle cylinder (23.8 ) is listed as fitting for both. The early Square cylinders (1961 and 1962) are bigger – 25.4mm, again with a different part number for each year.
The rest of the Type Three cars used only 22.2 mm rear cylinders from the beginning of production at least through to August 1969 (publication date of parts book). _________________ Air does not freeze. Air does not boil.
NorSquare Samba Member
Posted: Sat Jul 25, 2015 8:52 pm Post subject: |
http://www.ebay.com/itm/VW-TYPE-3-1964-1965-REAR-B...5d565c75d5
Isp West got drums... _________________ 64 1500N Squareback M265 Rubinrot
12 Honda JAZZ 1.4i Red
17 Skoda Kodiaq 4x4
61 Renault Dauphine Light brown
62 Type 2 Crewcab pickup Army Green
72 1600 Squareback L95b |
Posted: Wed Jul 22, 2015 7:29 am Post subject: |
Thanks guys. With regards to the availability of the drums, I’m going with the later ones for a couple of reasons. I figure it’s more likely that I’ll be replacing the shoes or cylinders than the drums down the road, so I’d rather the ease of sourcing those parts, even if I have a bit of trouble getting the later drums now. As well the pattern on the 64/65 versus the pinwheels matches the front drums of the 66 Ghia (not that that matters too much). Plus the shoes as I understand it are wider on the 64/65s, so better braking.
Interesting about the Sebro drums, I wonder if I can find a place that carries them? Else, I’ll buy the Danish ones and see how they work.
As for the backing plate, I knew there were two types from 64-74, (the only difference being the adjuster holes added for 66-74), but didn’t realize there were two versions of early ones. Still have not ascertained why a plate from a 63 would slip inside a later W-5 drum though…
I think I’ll just buy the 64/65 drums and see what happens. If they don’t fit due to the plate, I’ll look at sourcing some later plates then. _________________ Air does not freeze. Air does not boil.
Posted: Tue Jul 21, 2015 6:28 pm Post subject: |
ataraxia wrote: |
NorSquare wrote: |
ataraxia wrote: |
For what it's worth: I can get NOS early pinwheel drums. I can't get NOS 64/65 drums - although there is/was a pair in the classifieds for $275. |
You can get new 64-65 rear drums. I recently bought two. The brand was Sebro (German).
http://www.sebro.eu/products/automotive-classics.html |
How much did they cost you - before shipping?
Anything can technically be had for a price.  |
Bought from an local guy here who had 2 (last one's) on the shelf. I paid approximately 200
USD. An very nice price I think. _________________ 64 1500N Squareback M265 Rubinrot
17 Skoda Kodiaq 4x4
Posted: Tue Jul 21, 2015 5:35 pm Post subject: |
NorSquare wrote: |
ataraxia wrote: |
Posted: Tue Jul 21, 2015 5:00 pm Post subject: |
ataraxia wrote: |
http://www.sebro.eu/products/automotive-classics.html _________________ 64 1500N Squareback M265 Rubinrot
17 Skoda Kodiaq 4x4
Posted: Tue Jul 21, 2015 3:23 pm Post subject: |
to Ch. No. 76 299
Erik G Samba Member
Joined: October 16, 2002 Posts: 13546 Location: Tejas!
Posted: Tue Jul 21, 2015 11:59 am Post subject: |
the only thing I could really see being an issue is bolting the 64-65 wheel cylinders to the 63 backing plates. I don't know that it will work. they are the same diameter inside, so you can buy them to pull apart and use in the earlier wheel cylinders. Thats what I'm doing
I will know if they are straight bolt on sooner or later - probably later as it's 100+ heat index in Houston + mosquitoes and I have zero motivation to do anything to my notchback at all
I wouldn't count on it working. I do know that you can use later 4 lug backing plates with 64-65 shoes, wheel cylinders, and drums, and the advantage there is you can adjust the brakes from the backing plate side instead of the drum side _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
Posted: Tue Jul 21, 2015 11:54 am Post subject: |
Posted: Tue Jul 21, 2015 11:51 am Post subject: |
ataraxia wrote: |
The one caution I'd put out there is that the repop drums for 64/65 brakes don't always fit the splines properly - you may have to do some light grinding to get them to fit.
The rear wheel cylinders and shoes for 64/65 drums are very easy to find. |
Thanks, I'd heard that there maybe some fitment issues. As for the availability of shoes and cylinders that is the primary reason I'm converting from 63-down.
Still am not certain though if I need to change out the backing plates as well. _________________ Air does not freeze. Air does not boil.
Posted: Tue Jul 21, 2015 11:45 am Post subject: |
Posted: Tue Jul 21, 2015 10:13 am Post subject: |
So, been doing a bit more reading on my brakes. I plan on converting the 63 brake set up that’s on it now to 64-65.
I was looking at the T-3 drums from CIP 1 they are listed as fitting 62 - 65, but someone on here indicated that when they went to install them on their earlier car the backing plates slipped inside of them. Someone else said that they were mislabeled and that they would only fit 64 and 65, ie would not replace the early pin wheels (to 63).
So questions:
1. Is there a size difference between the 61-63 backing plates and the 64-65 (and up) plates?
2. If not can I just bolt the 64-up drum and shoes on to the 63 plates, or do I need to swap out the 63 plates for 64 & up plates? _________________ Air does not freeze. Air does not boil.
Erik G Samba Member
Posted: Tue May 19, 2015 10:29 am Post subject: |
bobnorman wrote: |
Thanks for the reply. Planning on stock rims with 185 65s. The car had no clearance issues with the 6.00 15s on it before, hoping there won’t be a problem with the radials. As for the engine, I’m going to be running a DP 1600, with dual Kadrons. So, I’ll have a longer 4th gear, but will I also have reduced acceleration off the start?
Also, as for brakes, I’m wondering if I could use the 64 and later T-3 wide five stuff on the existing backing plate, as it seems to be (marginally) easier to come by than the earlier stuff. |
Yes on the brakes. SuperBeetle front 22.2mm wheel cylinders work nicely, and 64-65 shoes seem to be easier to get. New drums are available as well, the bus guys use them _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
Posted: Tue May 19, 2015 9:29 am Post subject: |
Also, as for brakes, I’m wondering if I could use the 64 and later T-3 wide five stuff on the existing backing plate, as it seems to be (marginally) easier to come by than the earlier stuff. _________________ Air does not freeze. Air does not boil.
t3kg Samba Member
Joined: June 14, 2006 Posts: 2712 Location: Los Angeles
Posted: Tue May 19, 2015 7:43 am Post subject: Early T-3 transmission in a T-1 – Advantages/Disadvantages? |
So I realized last night that the transmission in my 66 Type 14 Ghia is actually from an early Type Three. A June ‘63 model to be exact, possibly from a T-34. I had always wondered why it had long axles; I tried to look up the number but couldn’t find it in the Beetle or Ghia section. Some time ago I noticed the pinwheel drums, but never really thought too much about it, until I pulled the drum last night: “Ah-ha! Perhaps this is a T-3 tranny”… checked the number and bingo! Yes, I’m a bit slow to connect things sometimes - my wife calls me the dumbest smart person she knows. Anyway, now that the mystery is solved, my question is what to do about it?
I’ll likely ask this in the Ghia forum as well, but thought someone here might be able to school me on the advantages/disadvantages of the T-3 Swing axle transmission over the one my car was born with. Should I keep it? I’m pretty sure I have another swing from a 67 or 68 beetle.
Straight away I know that brake parts will be an issue. I recall from looking for parts for my 64 Square that some things are hard to find…pre ‘64 stuff even moreso. Drums look in good shape, and I can see that they are much wider, so in my mind that would be a plus - if I can find the shoes/cylinders. If parts are too hard to find, anyone know if it would it be possible to swap the whole brake setup from a later wide 5 Beetle/Ghia?
I terms of performance, I gather that the gearing is such that the T-3 will be a little slower off the line but better top end. Is this correct? Also, I’m thinking that the wider track of the Type Three would improve stability over the short axle/short tube unit. Pretty sure this is why they switched the T-1s to long/long in later years.
As mentioned this may have come from a T-34, is there a difference between the transmission in a ‘63 notch/square and a T-34?
Any thoughts/advice on this would be welcome. _________________ Air does not freeze. Air does not boil.
