Nokian WRC3
Page: 1, 2, 3, 4, 5  Next
jimf909
jimf909 is offline
PostPosted: Sat Oct 03, 2020 4:33 pm    Post subject: Re: Nokian WRC3 Reply with quote
For folks reading along, a C load range tire = 6 ply, D = 8 ply. A D/8 ply tire no longer means that the tires have 8 plies, they're just roughly equivalent to a tire made with 8 plies back in the olden days. As CVWVM points out, it's important to know the differences. It's helped me to consume a few different resources to get up to speed. Here's one...
https://m.tirerack.com/tires/tiretech/techpage.jsp...lsrc=aw.ds
- Jim
Butcher wrote:
Guilty as charged.
crazyvwvanman
crazyvwvanman is offline
PostPosted: Sat Oct 03, 2020 4:11 pm    Post subject: Re: Nokian WRC3 Reply with quote
Stock 14" tires are about 815 revs/mile
Entyre 205/70R15 are about 790 revs/mile according to Nokian.
815-790=25
25/815 = 3%
I'm running that tire and size on my tintop Syncro.
On my second set. I'm happy with them for my use.
These tires are XL, meaning Extra Load
They carry more weight and are rated at more pressure than an SL tire of the same size.
A set of 4 could carry nearly 7000 according to their specs.
Their max pressure is 51 psi.
They are not C or D tires.
They are not 6PR or 8PR tires.
Mark
Timwhy
Timwhy is offline
PostPosted: Sat Oct 03, 2020 3:42 pm    Post subject: Re: Nokian WRC3 Reply with quote
I am running the Entyres on my Westy 205/70/15 and they give you an 8% increase which makes the speedo and mileage lower than actual.
On my Tintop I run Grabber AT2's 205/75/15 and they give you a 10% increase and lower mileage and speed.
'15 Audi A3 Quattro
'09 VW Tiguan (dead)
'87 VW Westy
'91 Tin Top
'90 Cabby
VikingWagen
VikingWagen is offline
PostPosted: Sat Oct 03, 2020 12:35 pm    Post subject: Re: Nokian WRC3 Reply with quote
crazyvwvanman wrote:
205/65R15 is the closest 15" size to stock 14" diameter.
I run 205/70R15 XL for a little more height and Load Index 100.
Mark
Thanks for the feedback, Mark. Is that on a tin top syncro with 2.1 WBX’r? How does your speedo compare to gps? It seems like the tire size you have would be a better fit and also have 8 ply instead of 6 ply, right?
crazyvwvanman
PostPosted: Sat Oct 03, 2020 11:20 am    Post subject: Re: Nokian WRC3 Reply with quote
Mark
VikingWagen
PostPosted: Sat Oct 03, 2020 9:42 am    Post subject: Re: Nokian WRC3 Reply with quote
Thought I would chime in and offer feedback on the Nokian tires. Here is my experience.
During a 1400 mile trip recently, running WRC 205/65/15 tires with 25k miles on them, the left front tire suffered from a delamination. This happened after a 25 mile climb up over a mountain on very rough and rocky forest road at low speed. The tread on the other 3 tires is pretty well worn so its time for a new set. The Nokian’s have been a fine tire other than being a bit too small in diameter which makes the speedo read about 4 mph too high. The spare is unused so I’m thinking of getting 3 new tires and stick with the same brand and size until I figure out whether to convert or keep stock engine, gear ratio, larger tires, etc. in the near future. I used to run Michelin LTX 215/75/15 tires which lasted a long time and worked well other than the poor gear ratio match and speedo reading too low. I did not like the constant shifting and high load with this size tire and stock engine/gearing. Otherwise, great clearance and handling, longevity. No noticeable fuel economy difference.
Anyone running a slightly taller tire thats closer to stock?
1990 Syncro Westy, stock engine, decoupler, rear locker, lift springs, T3 bushings & anti sway bar, OME shocks
Slimvest
Slimvest is offline
PostPosted: Tue Feb 04, 2020 1:23 pm    Post subject: Re: Nokian WRC3 Reply with quote
It looks the size availability of these tires in a D/8 ply has increased since the thread was created. Tires-easy currently appears to be carrying 205/65R16 (26.5 inch diameter) and 215/60R16 (26.1 diameter). For a stock 2.1 westy (no lift), is there a downside to going with the wider tires? As I see it, the wider tires might be assumed to corner and accelerate a bit better at the cost of less cushion on rough terrain and aesthetically would not fill the wheel well as well.
I would consider tire weight and rolling resistance too. I'm on 205/70R15s and my mileage and acceleration are both lower/slower when compared to the 3-season tire I had formerly (Nokian Entyre) in the same size.
'87 GL w/ Reimo top (sold Aug '21)
SeacoastRed
SeacoastRed is offline
PostPosted: Tue Feb 04, 2020 7:40 am    Post subject: Re: Nokian WRC3 Reply with quote
For reference on my stock 2.1/MT Westy I'm currently rolling with the Hankook RA18 195R14 (D ply, diameter 26.2). I'm content with the acceleration of these tires around town and I feel reasonably safe on the slow lane of the highways around here. However, I am looking for better traction for gravel roads and would also like to take the van out in the winter months from time to time, hence my interest in the WRC3.
Thanks for the knowledge.
jimf909
jimf909 is offline
PostPosted: Sat Jan 04, 2020 7:07 am    Post subject: Re: Nokian WRC3 Reply with quote
I run 215/65 R16 tires and keep an original size spare (replaced it two years ago so it's fresh) in the clamshell. I basically treat it as a doughnut and only expect to use it until I repair or replace the flat tire.
- Jim
Butcher wrote:
Guilty as charged.
Slimvest
Slimvest is offline
PostPosted: Fri Jan 03, 2020 12:35 pm    Post subject: Re: Nokian WRC3 Reply with quote
peffleyjeanne wrote:
I just ordered Nokian WRC3 205/70r15 tires to replace the Nokains WRG3s I've had for four years. So far I have the origional 14" alloy wheel with the origional Michelin 205/70r14 tire for a spare. It's old now. Wondering what people are using for a spare with the WRC3s since they are directional? Would still love to store the spare in the clamshell. Thank you!
I bought a generic load rated tire off Tire Easy (I think) and have it on the 14" rim. I can't recall the size at the moment, but I tried to get as close to the Nokian 205/70r15 dims I could. I did still have to alter my carrier tray hinges with u-bolts to drop it a bit though. The tire was pinching a coolant hose just enough to make the van run hotter.
termuehlen Premium Member
termuehlen is offline
PostPosted: Fri Jan 03, 2020 12:10 pm    Post subject: Re: Nokian WRC3 Reply with quote
I have a 205/65-15 WRC3 on a steel wheel in an original clam shell. I also have a 205/65-16 WRC3 on an alloy wheel in a modified clam shell (retaining bars removed and replaced with bolts). Since they are directional, there is a 50/50 chance they will be running in the wrong direction when installed in an emergency. I don't intend to drive more than a few hundred miles with the tire running in the wrong direction, if the spare is needed.
1988 Westfalia automatic Subaru OBD1
1986 syncro tintop wbx
Schuylersister
Schuylersister is offline
PostPosted: Fri Jan 03, 2020 9:06 am    Post subject: Re: Nokian WRC3 Reply with quote
Slimvest
Slimvest is offline
PostPosted: Mon Jan 21, 2019 12:02 pm    Post subject: Re: Nokian WRC3 Reply with quote
Corwyn wrote:
I had a set of WRC3s installed before a trip to Baja California. Great ride, great sidewall confidence, but by the time I got back to Washington, 1/3 of the tread was gone. As an "all-weather" tire, the rubber is softer and wears faster. I am running Yokohama Geolandars (all-terrain) three years old and still have plenty of tread.
I put the Geolanders in the same category as the Grabber AT2. Load rated too low for me in the 205/70R15 size. Not sure what size you're running. I only drive 5k/year so even if I only get 25k out of the tires, I'll be ready to try something new by then.
And as I said, it's only money! Wink
Corwyn Premium Member
Corwyn is offline
PostPosted: Fri Jan 18, 2019 8:04 pm    Post subject: Re: Nokian WRC3 Reply with quote
'90 White Westy ("White Lightning")
FAS Gen V 2.0
The Annual Baja Rally
~ Captain Ron ~
Slimvest
Slimvest is offline
PostPosted: Fri Jan 18, 2019 4:05 pm    Post subject: Re: Nokian WRC3 Reply with quote
Joined the WRC3 club today with a set 205/70R15. Definitely more crisp than my old General Grabber AT2, but time will tell. It's just money... Laughing
jimf909
jimf909 is offline
PostPosted: Wed Sep 05, 2018 4:10 am    Post subject: Re: Nokian WRC3 Reply with quote
My WRC3s are 215/65 R16. I won't say the noise is intrusive but it is an added sound under certain confitions that I didn't get with the WRG3s (60 aspect ratio). It's most notable when changing direction and when decelerating and the engine noise subsides.
40 psi front/46 psi rear has been working out well.
- Jim
Butcher wrote:
Guilty as charged.
ThankYouJerry
ThankYouJerry is offline
PostPosted: Tue Sep 04, 2018 9:42 pm    Post subject: Re: Nokian WRC3 Reply with quote
Hmmm... Several thousand miles into my set of WRC3 205-70-15, I find them delightfully quiet compared to my old set of WRG2 215-65-15 tires. Do you have 205/70/15s Jim? If so, what tire pressure are you running? I'm running 42 in the front and 48 in back.
1990 Multivan - "Ohana"
1.8T, Auto w/3.27 R&P + Peloquin TBD
jimf909
jimf909 is offline
PostPosted: Mon Sep 03, 2018 10:23 pm    Post subject: Re: Nokian WRC3 Reply with quote
The increased noise of the WRC3 compared to the WRG3 is becoming obvious after 10K with them. It hasn't made me write them off yet even though I'm sensitive to noise. I still like them.
- Jim
Butcher wrote:
Guilty as charged.
atomatom
atomatom is offline
PostPosted: Mon Sep 03, 2018 9:35 pm    Post subject: Re: Nokian WRC3 Reply with quote
some feedback after some long drives on my set of wrcs (195/60R16)
overall; pretty darn good. only downside is they are somewhat noisy. price of the treads i spose. very solid on corners. and maybe it is just the balancing, but van never felt so solid when going 120kmh (down hills, with wind behind, etc)
i'll update when the snow is here.
84 Vanagon Westy, 1.9L, California raised but defected to Canada.
Jon_slider
Jon_slider is offline
PostPosted: Sat Jun 23, 2018 1:11 pm    Post subject: Re: Nokian WRC3 Reply with quote
Slimvest wrote:
Moving from General Grabber AT2 205/75/15 to Nokian WRC3 205/70/15
the grabber is a passenger tire, that is not a match for a Vanagon, it is also 6% taller than stock
the Nokian is a Light Truck tire, much more correct for a Vanagon, and it is only 3% taller than stock, so it will have an acceleration advantage over the grabber
the Nokian is by far the better load rated tire for a vanagon..
If the Nokian sidewall says, 2094 lbs @ 65 psi, then stock equivalent would be to inflate to 40 psi front, 48 psi rear as a starting point.
Its a big advantage, for crosswind stability, to use 20% more psi in rear than front, per the doorjamb inflations.
My Soapboxes: Inflation; Handling; Gearing; Decoupling; Swepco
Page 1 of 5
