BOTH brake lights out 1982 Vanagon
Kylo Rich
Kylo Rich is offline
PostPosted: Thu May 19, 2016 5:37 pm    Post subject: Re: BOTH brake lights out 1982 Vanagon Reply with quote
RCB wrote:
Nice job Kylo.
Thanks a lot! Appreciate the input!
1982 Westy "Adeline" 2.3, Air-cooled, Dual Weber Carbs - Left my job of 10 years to hit the road full-time. Instagram @KyloRich
Kylo Rich
PostPosted: Thu May 19, 2016 5:36 pm    Post subject: Re: BOTH brake lights out 1982 Vanagon Reply with quote
djkeev wrote:
Glad you got it working! 👍
Dave
Thanks, my friend. You were incredibly helpful. Now to pay it forward - next time someone is in need of this issue, I got this. LOL
RCB
RCB is offline
PostPosted: Thu May 19, 2016 4:08 pm    Post subject: Re: BOTH brake lights out 1982 Vanagon Reply with quote
Nice job Kylo.
djkeev
djkeev is offline
PostPosted: Thu May 19, 2016 3:46 pm    Post subject: Re: BOTH brake lights out 1982 Vanagon Reply with quote
Dave
Ghia
Vanagon
Beetle
Kylo Rich
PostPosted: Thu May 19, 2016 2:06 pm    Post subject: Re: BOTH brake lights out 1982 Vanagon Reply with quote
Kylo Rich wrote:
I am going to dig this one up from the grave. I am currently having the same issue as previous users and have read the forums.
NO BRAKE LIGHTS on each side. I have done the following:
HELP!
I appreciate everyone who takes the time to read and reply. You are the real MVP!!
UPDATE!!!! GUESS WHO HAS WORKING BRAKE LIGHTS AND A NEW MASTER CYLINDER? THIS GUY!!! Thanks for all the help everyone. I learned a lot of electrical skills in this process even though it was not the issue. See pics.
RCB
RCB is offline
PostPosted: Thu May 19, 2016 6:29 am    Post subject: Re: Brake and Tail Lights BOTH out 1982 Vanagon Reply with quote
Kylo Rich wrote:
RCB wrote:
If you have questions about the Go Westy Brake Light Switches, you cant go wrong with the ATE Brand that Van Cafe has. The ATE parts I have now and have used on my 82 Westy have performed flawlessly.
I was mistaken, the Master Cylinder came with them and are actually from Van Cafe. They now carry FTE as well as Gowesty. I got 2 FTE switches from Van Cafe with the MC and bought two from Gowesty and all 4 are identical.
I called Van Cafe and he said that FTE and ATE are continually competing for the EOM brand and currently FTE is what they offer. Ideally, I would like ATE.
Oh well, now I have 2 spares (which ill likely need one day).
Cheers!
Nothing wrong with having spare parts. VW did use a few different manufacturers for their builds.
Kylo Rich
PostPosted: Wed May 18, 2016 5:16 pm    Post subject: Re: Brake and Tail Lights BOTH out 1982 Vanagon Reply with quote
Cheers!
Kylo Rich
PostPosted: Wed May 18, 2016 5:14 pm    Post subject: Re: Brake and Tail Lights BOTH out 1982 Vanagon Reply with quote
why cant i delete this text lol?
RCB
RCB is offline
PostPosted: Sun May 15, 2016 5:18 pm    Post subject: Re: Brake and Tail Lights BOTH out 1982 Vanagon Reply with quote
Kylo Rich wrote:
Kylo Rich wrote:
kamzcab86 wrote:
Kylo Rich wrote:
NO BRAKE OR TAIL LIGHTS on each side.
My running lights work when the lights are on.
Clarify please, since the tail lights are running lights: Are the tail lights working (remember they are separate bulbs from the brake light bulbs), or not working?
Not sure why this hasn't been suggested thus far, but when my VW's encounter brake light issues, the first thing I do is unplug the switch harness, jump (aka bypass) the connections, and turn the key to "on":
(^Borrowed pic)
Upon supplying direct/bypass power, do the brake lights shine (or is there 12V at the light harness)? Yes: Faulty switch(es). No: Fault in the wiring system somewhere (fuse, grounds, wires).
I performed this test just now and when jumping the switch, the brake lights ARE WORKING. It must be bad switches?
I have new ones from GW but am reading about how crappy they are. I also have a high quality German master cylinder that must be installed. I suppose I can install the new switches then and give them a whirl.
Thanks a ton. I wish I had jumped the wire sooner as instructed by the thread you referred, as I did read it.
NOTE - I also read on that thread (the guy who posted this pic) that when he did the jump test, the lights did in fact work. He replaced the brake light switches and continued to have the issue. When all was said and done, he was not pressing down on the brake hard enough.
Do you think because my brake fluid is low / leaking that the proper amount of pressure if not allowing the switches to effectively work? ____
Bumpin this up. So from here I would you suggest to go ahead and just install the new GW switches?
Does anyone have experience with the Gowesty Brake light switches? Are they crap like they used to be in previous threads from 2010 or so?
Kylo Rich
PostPosted: Sun May 15, 2016 4:59 pm    Post subject: Re: Brake and Tail Lights BOTH out 1982 Vanagon Reply with quote
(^Borrowed pic)
Kylo Rich
PostPosted: Thu May 12, 2016 2:47 pm    Post subject: Re: Brake and Tail Lights BOTH out 1982 Vanagon Reply with quote
(^Borrowed pic)
kamzcab86
kamzcab86 is offline
PostPosted: Wed May 11, 2016 3:46 pm    Post subject: Re: Brake and Tail Lights BOTH out 1982 Vanagon Reply with quote
(^Borrowed pic)
2016 Golf GTI S
Kylo Rich
PostPosted: Wed May 11, 2016 1:32 pm    Post subject: Re: Brake and Tail Lights BOTH out 1982 Vanagon Reply with quote
Abscate wrote:
You are looking for 12 VDc at the load ( the brake light). If you don't find it, you follow the wire trace back until you find the break.
Those scotch lock connectors can break the supply Wíre and leave the splice hot, do look carefully at those.
As stated, those wire nuts should be removed. The person who did this had no automotive wiring skill, actually, little wiring skill of any kind.
If both the taillights and brake lights stop working, it's usually bad grounds
Another small question - Do I have to press down on the brake to address whether or not the load is getting power (I dont think so)? I know I had to do this to test the brake light relay switch under the master cylinder.
Kylo Rich
PostPosted: Tue May 10, 2016 7:13 pm    Post subject: Re: Brake and Tail Lights BOTH out 1982 Vanagon Reply with quote
I will go ahead and cut the ground wire, place a new wire terminal, and get a new fresh ground screw.
Do you think I should get rid of that wire splice? Is there a more effective way to do this? This is not stock - correct? I wonder why it is even spliced.
Where is the "load" located? Do you mean the wire harness that attaches to the actual brake light assembly?
Thanks for the help!!
Abscate
Abscate is offline
PostPosted: Tue May 10, 2016 3:48 am    Post subject: Re: Brake and Tail Lights BOTH out 1982 Vanagon Reply with quote
Kylo Rich
PostPosted: Mon May 09, 2016 9:06 pm    Post subject: Re: Brake and Tail Lights BOTH out 1982 Vanagon Reply with quote
Terry Kay wrote:
Rather than using a continuity meter, get yourself an ice pick circuit tester as pictured and connected to the grounds you're using, check the power feed at the bulb sockets, wiring , to the lamps etc.
If your seeing no power, get onto a better ground and check the power again.
Work yourself up forward till you find the area of loss.
This tool will save you a bunch of time and headaches locating the problem.
OK, great. I have a 12 V test light thing but not sure if it is the same as this. Is this simply a test light?
So I would connect it to the ground source and then poke around each wiring to see where the connection is lost? It just seems like everything has had power so far and I cannot seem to isolate the issue.
Thanks again, buddy!
Terry Kay
Banned
Terry Kay is offline
PostPosted: Thu May 05, 2016 10:09 pm    Post subject: Re: Brake and Tail Lights BOTH out 1982 Vanagon Reply with quote
T.K.
pathao
pathao is offline
PostPosted: Thu May 05, 2016 7:32 pm    Post subject: Re: Brake and Tail Lights BOTH out 1982 Vanagon Reply with quote
If it were me, to troubleshoot, I would look at the connector in the black plastic box in the engine bay left hand side (near you coil, near the ground you just found). In there, there is a few connectors. The wire color (stock) is
BK/W : turn left
BK/G : turn right
BK/BL : backup light
GY/BK : tail left
GY/R : tail right
GY/G : licence plate
R/BK : brake lights
I would check if there is juice coming from the dash.
And I would jump +12 volts down stream to see if the lights working
edit : sorry. re-read your first post, you've already check that power coming to the harness.
1982 AC P27 - 2.0 FI FED - 091 - BA6
English is a second language to me
Kylo Rich
PostPosted: Thu May 05, 2016 7:00 pm    Post subject: Re: Brake and Tail Lights BOTH out 1982 Vanagon Reply with quote
dhaavers wrote:
I'd also be sceptical of that blue plastic "Scotch-Loc" connector on the ground wire...possibly/probably
corroded & giving a bad connection. Do you have continuity through all the ground connections?
You've definitely got a batch of non-stock wiring going on there.
The orange wire nuts in pic #3 have NO place in automotive wiring... Rolling Eyes
From my basic automotive electrical skills, I would say yes, the ground wire is getting continuity.
If I probe 1 prong onto the ground wire terminal and the other to any ground on the van, this would be a sufficient way to test continuity? Or do I literally need to touch each side of the ground wire (who knows where that comes from).
I also checked the fuses and both also have continuity. Same with the brake light switches. All seem functional.
About the blue "Scotch-Loc" -- I did a continuity test on all sides of the blue connector by touching one prong inside to the wire and the other touching a ground point in the van. All sides beeped and had solid readings. I also sprayed it out with contact cleaner! So dirty...
Definitely some non stock wiring here in the back and unfortunately some under the dash. I am going to simply cut and tape the blue wire as it currently serves no purpose. Maybe it was for the reverse light for rear hatch lol. What a mess.
I cannot thank you enough, my friend. Still hunting...
dhaavers
dhaavers is offline
PostPosted: Thu May 05, 2016 3:47 pm    Post subject: Re: Brake and Tail Lights BOTH out 1982 Vanagon Reply with quote
"The WonderVan"
