race 1600 engine not making power over 3800rpm
bugguy1967
bugguy1967 is offline
PostPosted: Mon Aug 06, 2018 9:08 am    Post subject: Re: race 1600 engine not making power over 3800rpm Reply with quote
No need to yell Mark Laughing
"A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine"
mark tucker
mark tucker is offline
PostPosted: Mon Aug 06, 2018 8:51 am    Post subject: Re: race 1600 engine not making power over 3800rpm Reply with quote
JUST BECAUSE SPRINGS ARE "hd" OR NEW DOSENT MEAN THERE ANY GOOD.THE SAME GO'S FOR EVERYTHING ELSE....INCLUDING THE FUEL HOSE.AND THE LAMB THINGY. AND DONT FERGET ABOUT THE ASSEMBLEY GOO~ROO. AND THE 3 TEETH OFF CAMSHAFT THINGY OR MULTI PEICE LIFTER'S.
nsracing
nsracing is offline
PostPosted: Mon Aug 06, 2018 8:31 am    Post subject: Re: race 1600 engine not making power over 3800rpm Reply with quote
It was good on they dyno and not when installed? Hmmnn? You think something might be amiss?
If you build an engine for racing build it so. So what did you do to the motor? What kind of work went into the heads? Valves? springs?
Did you take a compression test before and after the dyno session?
Are the exhaust pipes HOT on all 4 cylinders?
bugguy1967
PostPosted: Sun Aug 05, 2018 6:36 am    Post subject: Re: race 1600 engine not making power over 3800rpm Reply with quote
The first thing I thought was springs too. Try another brand.
Btw, I have an engine with non HD stock single springs that is still alive lifting to .400" and occasional 6,000 rpm for over 85,000 miles.
If it's not your springs, look into either valvetrain (pushrod) flex or loss of ring seal at upper rpm.
modok
modok is offline
PostPosted: Fri Aug 03, 2018 8:20 pm    Post subject: Re: race 1600 engine not making power over 3800rpm Reply with quote
You think everything is the same both engines but clearly it isn't.
All you need to do is find out what the difference is.
DeathBySnuSnu
DeathBySnuSnu is offline
PostPosted: Fri Aug 03, 2018 6:33 pm    Post subject: Re: race 1600 engine not making power over 3800rpm Reply with quote
I dont directly know about what you are doing.
But a couple years ago when my girlie was racing a spec class of dirt track (non vw), we had to run spec springs and cams (among other things). Cam timing and valve springs were short lived and super critical when running continuous 6 to 6.5k the whole time.
Valve springs would do very similar to what you are saying, but would also start taking peak rpm off the top. A cam change had to be dialed back in, none were ever the exact same lobe center.
Very small things made all the difference running that spec class.
Not even all spec race valve springs ran the same.
And again....all this was non vw....it may not fully apply.
modok wrote:
And look at the SHAPE of the curves, just smooth, like gods own slingshot. .
[email protected]
john@aircooled.net is offline
PostPosted: Fri Aug 03, 2018 12:28 pm    Post subject: Re: race 1600 engine not making power over 3800rpm Reply with quote
"It's can't be *****, because they are new" has put more egg on face than anything in the Automotive Hobby.
It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net
mark tucker
PostPosted: Fri Aug 03, 2018 12:23 pm    Post subject: Re: race 1600 engine not making power over 3800rpm Reply with quote
delamarrr wrote:
I dont think anyone that replied actually read my first post besides capt. calzone and glasser.
Cant be fuel, it has a perfect lambda reading right across the rev range.
Why would it be a dead valve spring? The heads are brand new.
Why would it be a dead cam, the cam is brand new.....
It didnt run as it should on the dyno, it stopped making more power at 3800...
capt calzone + glasser: maybe, im in the process of making a new carb up for it so ill try that soon. however my lambda reading is spot on all the way to 5500 on the dyno. I should add that i serviced the carby after the first dyno run and before the second. The problem was still there on the second run. I think its going to be something internal, so its going back to the builder after my race this weekend.
ok you have a good point there so....my question is ...WHY WONT IT RUN!!!since everything is spot on..... possiably the dyno is on the fritz...and fritz is on vacation...
Dan Ruddock
Dan Ruddock is offline
PostPosted: Thu Aug 02, 2018 2:26 pm    Post subject: Re: race 1600 engine not making power over 3800rpm Reply with quote
Brian_e wrote:
Nope.
I built an engine that was on the edge of single or dual springs. I used what I thought were decent HD singles shimmed .100" to bind. After one summer of use it started cutting out about 4000rpm. It ran awesome and pulled hard till just over 4000rpm, then it was like someone pulled 2 plug wires.
The owner chased his tail swapping fuel pumps, complete ignition systems, adjusting valves, etc. Everything was tried. I had a hunch, and pulled a spring to find they had less pressure then new stock springs. Almost all of them were shot.
Being you have Empi springs I would be changing them regardless. A dropped valve makes a pretty big mess of nice new parts.
This would be a really good application for Dan's beehive spring kit.
Brian
Thanks for the vote of confidence but my beehives would be overkill for a stock cam with 1.25 rockers. I would not trust any Empi springs, most likely made in china and are a hit or miss. I would get some Berg HD singles which would be all you need for your app and you can trust the quality control. This might not be your problem but springs are too important to use crap.
I would never run more than .430" lift with HD singles, they just have harmonic problems and too much lift makes it worse resulting in a very short spring life. I have a beehive customer who runs a FK7 with 1.4 rockers and new HD singles broke in just 17k miles. He got tired of having to change his springs every 15k and went beehive. Stock cam with 1.25 rockers is only .380" lift.
Dan
Brian_e Premium Member
Brian_e is offline
PostPosted: Thu Aug 02, 2018 12:37 pm    Post subject: Re: race 1600 engine not making power over 3800rpm Reply with quote
Nope.
Brian
chrisflstf
chrisflstf is offline
PostPosted: Thu Aug 02, 2018 11:24 am    Post subject: Re: race 1600 engine not making power over 3800rpm Reply with quote
If it was a " dead" spring, would not it make noise or racket, or rough running at higher rpm? Seems you should be able to hear it, if that was the case
vwracerdave
vwracerdave is offline
PostPosted: Thu Aug 02, 2018 11:10 am    Post subject: Re: race 1600 engine not making power over 3800rpm Reply with quote
The cam could have been advanced or retarded 1 or 2 degrees when ground and that could make a big difference when dyno'ing a race engine. Just because any part is new DOES NOT mean it is correct. EMPI has been know for shitty quality control, and you are trusting their accuracy.
[email protected]
PostPosted: Thu Aug 02, 2018 10:26 am    Post subject: Re: race 1600 engine not making power over 3800rpm Reply with quote
because some heads are shipped with $#!^ valve springs. Check them.
The cam could have gone flat too, the most common time for it to happen is during break in, when it's "new".
Brian_e is offline
PostPosted: Thu Aug 02, 2018 10:18 am    Post subject: Re: race 1600 engine not making power over 3800rpm Reply with quote
I am with John. Check the valve springs.
Stock springs are OK for 4000rpm on a stock cam. The second you add ratio rockers, ask it to rev higher, more lift, or add heavier valves, you need at least HD single springs.
Just cause they are new doesn't mean they are good or correct.
Brian
Bugsy61
Bugsy61 is offline
PostPosted: Thu Aug 02, 2018 9:55 am    Post subject: Re: race 1600 engine not making power over 3800rpm Reply with quote
Cam off one tooth?
delamarrr
delamarrr is offline
PostPosted: Thu Aug 02, 2018 4:44 am    Post subject: Re: race 1600 engine not making power over 3800rpm Reply with quote
67rustavenger
67rustavenger is offline
PostPosted: Wed Aug 01, 2018 8:32 pm    Post subject: Re: race 1600 engine not making power over 3800rpm Reply with quote
mark tucker wrote:
also air cleaner tops too close to the stacks. air jet rong size...but probably fuel delevery issue.
This comment just rang a bell in my head.
I have been having issues wit a set of 36's that ran great before. But once I installed a new engine (that failed do to a failed part) and reinstalled the old engine.
I have been having popping issues with correct running.
I just realized that I have put the tall stacks on the 36's. Rather than the shorter Dellorto stacks. That might be my problem.
Thank you for posting this Mark. It got me thinking.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
[email protected]
PostPosted: Wed Aug 01, 2018 4:42 pm    Post subject: Re: race 1600 engine not making power over 3800rpm Reply with quote
First thing I'd check are dead valve springs.
mark tucker
PostPosted: Wed Aug 01, 2018 4:37 pm    Post subject: Re: race 1600 engine not making power over 3800rpm Reply with quote
dead valve sppringy thingys can also affect things like this.
vwracerdave
PostPosted: Wed Aug 01, 2018 9:49 am    Post subject: Re: race 1600 engine not making power over 3800rpm Reply with quote
It's the new EMPI cam or the new EMPI heads.
