Engine Oil Leaking from Muffler
?Waldo?
?Waldo? is offline
PostPosted: Tue Sep 20, 2022 7:24 am    Post subject: Re: Engine Oil Leaking from Muffler Reply with quote
If you rolled the van, then copious amounts of oil likely leaked into the exhaust through the turbo seals which are not designed to prevent that. It may just be a matter of running it through several heat cycles to get any residual oil in the exhaust to burn off.
Zephyr_shreds
Zephyr_shreds is offline
PostPosted: Mon Sep 19, 2022 10:55 pm    Post subject: Re: Engine Oil Leaking from Muffler Reply with quote
1.9 1y engine is shooting out oil and white smoke from the exhaust after I rev it. Why. I did roll the van 3 times before I transplanted the unit in another van but it still started up like nothing happened before I transplanted it with installing a turbo.
jimf909
jimf909 is offline
PostPosted: Mon Sep 19, 2022 10:18 pm    Post subject: Re: Engine Oil Leaking from Muffler Reply with quote
You'll get a much better response if you link to a video showing the smoke & oil. A video of the 3x rollover will go viral.
- Jim
Butcher wrote:
Guilty as charged.
Zephyr_shreds
PostPosted: Mon Sep 19, 2022 9:01 pm    Post subject: Re: Engine Oil Leaking from Muffler Reply with quote
I just put a turbo on my 1.9 1y diesel. There’s white smoke and oil coming out the exhaust. Wtf. But I also rolled my van 3 times but she started up like nothing happened before I transplanted it into another van. Wtf
dhaavers
dhaavers is offline
PostPosted: Fri May 07, 2021 5:39 am    Post subject: Re: Engine Oil Leaking from Muffler Reply with quote
I clicked. I'll give you a dollar if it's NOT just water. Wink
I bet it doesn't drip after 20 minutes on the highway, running good & hot...
<shrug>
- Dave
"The WonderVan"
Abscate
Abscate is offline
PostPosted: Fri May 07, 2021 5:35 am    Post subject: Re: Engine Oil Leaking from Muffler Reply with quote
MarkWard wrote:
I’m not afraid, just not into being herded to someone’s site to drive up numbers. Idea
It’s $5 to get me to clink the link and get my comment.
Thank you
dabaron
dabaron is offline
PostPosted: Fri May 07, 2021 5:00 am    Post subject: Re: Engine Oil Leaking from Muffler Reply with quote
4Gears4Tires wrote:
Is that a diesel?
Touch it. Is it watery or is it oily? Only you can truly tell us.
1991 Vanagon GL Camper
4Gears4Tires
4Gears4Tires is offline
PostPosted: Thu May 06, 2021 5:44 pm    Post subject: Re: Engine Oil Leaking from Muffler Reply with quote
Is that a diesel?
MarkWard
MarkWard is offline
PostPosted: Thu May 06, 2021 3:49 pm    Post subject: Re: Engine Oil Leaking from Muffler Reply with quote
SCM
SCM is offline
PostPosted: Thu May 06, 2021 3:23 pm    Post subject: Re: Engine Oil Leaking from Muffler Reply with quote
I'm not afraid of no link!!!
But, yeah, impossible to tell what the single drop shown in the video actually is. It seemed pretty watery so I'm in the same boat with Mark and Dave.
'91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine
djkeev
djkeev is offline
PostPosted: Thu May 06, 2021 3:14 pm    Post subject: Re: Engine Oil Leaking from Muffler Reply with quote
I too rarely if ever click on links, video links are often poor and annoying, just post a photo of what you have.
I doubt its oil. If you had enough oil in there to drip out the smoke behind you would be a sight to behold!
Collect some on a white paper towel, I bet it is as mentioned...... water black with carbon.
Dave
Ghia
Vanagon
Beetle
MarkWard
MarkWard is offline
PostPosted: Thu May 06, 2021 2:56 pm    Post subject: Re: Engine Oil Leaking from Muffler Reply with quote
Sorry, don’t click on links, but are you sure it’s oil and not moisture mixed with carbon? For oil to be accumulating in the muffler, it’s getting past the rings or valves. How’s the oil consumption? How do the spark plugs look? Water and carbon are present when fuel combusts.
Dtfox
Dtfox is offline
PostPosted: Thu May 06, 2021 1:53 pm    Post subject: Engine Oil Leaking from Muffler Reply with quote
Howdy,
Just noticed engine oil leaking from my muffler. It is not present in the tail pipe and I am not seeing any sign of smoke.
Good compression on all cylinders.
Anyone ever experience this before?
PO said engine was rebuilt in 2018 and has an estimated 20k miles on it.
Thanks for any input!
“Pearl” 86' Manual 2.1L Westy
