Torque tube bolt?
Max Welton
Max Welton is offline
PostPosted: Fri Oct 22, 2021 7:31 pm    Post subject: Re: Torque tube bolt? Reply with quote
Cool. Thanks muchly.
Max
1967 Type-3 Fastback
ataraxia
ataraxia is offline
PostPosted: Fri Oct 22, 2021 7:27 pm    Post subject: Re: Torque tube bolt? Reply with quote
The washer is 4mm thick and 23.5mm OD in case you need to go looking for one.
Max Welton
PostPosted: Fri Oct 22, 2021 2:38 pm    Post subject: Re: Torque tube bolt? Reply with quote
ataraxia wrote:
N 10 390 1
Bolt, hex hd. BM 8 x 95
If you're using the Parts Book from this site - it's on page 122, Illustration A12, 1-90. Part #4 in the diagram.
https://www.thesamba.com/vw/archives/manuals/type3_parts_book/Type_3_Parts_Book_Group_1_Engine.pdf
In the event you've also lost the washer - it's a relatively thick washer. I probably have one if you need it - just let me know.
-Josh
Thanks! I was just at ACE HW and picked up a 90mm. It will be a little short.
Next time I'm in town I'll get a 95 and suitable washer.
Max
Bobnotch
Bobnotch is offline
PostPosted: Fri Oct 22, 2021 2:14 pm    Post subject: Re: Torque tube bolt? Reply with quote
ataraxia wrote:
N 10 390 1
-Josh
That's what, almost 3.5 inches long? Just thinking it might make it easier to search the bolt bin for. Wink
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
ataraxia
ataraxia is offline
PostPosted: Fri Oct 22, 2021 1:29 pm    Post subject: Re: Torque tube bolt? Reply with quote
N 10 390 1
-Josh
Max Welton
PostPosted: Fri Oct 22, 2021 12:06 pm    Post subject: Torque tube bolt? Reply with quote
I've lost the bolt that secures the torque tube to the shroud. Can someone tell me what size it is?
The parts manual (Group 1 Engine, Illustration 5, page 1-32) doesn't show it. Clearly I'm looking in the wrong place.
Max
