togatony Samba Member
Joined: December 29, 2011 Posts: 42 Location: Kansas City, MO
Posted: Tue Jul 26, 2022 2:03 pm Post subject: Re: Evap tank replacement |
| I pulled my evap tanks out and they are still good but i can't get them to fit back in. Is there any trick to get them back in the recess of the body and over the stud? |
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15411 Location: Syracuse, NY
Posted: Wed Apr 20, 2022 9:02 am Post subject: Re: Evap tank replacement |
just looped/capped the lines/nipples at the tank.
I do still have the tank crossover from saddle to saddle. and the tank vent from top to the top of filler.. those are to facilitate filling.
then I have a small ~1/16" hole up at the top of the filler under the cap for 'breathing' as I don't have a charcoal canister either. it's essentially like having a vintage beetle tank.
very very rarely do I get a whiff of fuel near the cap from the vent hole.
guess for all my other 'green' methods I'm not that concerned over the minute evaporation of the gas in my tank out a 1/16th hole..
and I don't live in California anyways.
I also don't fill the gas till it's right at the very top of the filler neck..
a practice my other van friend does which is both odd & maddening to me (to observe).  _________________
| Abscate wrote: |
| These are the reasons we have words like “wanker” |
sanchius  Samba Member
Posted: Tue Apr 19, 2022 4:06 pm Post subject: Re: Evap tank replacement |
I eliminated mine a decade ago.  _________________
| Abscate wrote: |
SCM Samba Member
Joined: January 26, 2011 Posts: 3480 Location: Bozeman MT
Posted: Tue Apr 19, 2022 2:05 pm Post subject: Re: Evap tank replacement |
Please don't tell my wife. She footed the bill for the blingy VC version for our van.  _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
VdubVanner Samba Member
Joined: August 03, 2017 Posts: 734 Location: Cowtown AB
Posted: Tue Apr 19, 2022 1:48 pm Post subject: Re: Evap tank replacement |
| dobryan wrote: |
Those are a bargain! |
Indeed they are -- especially when you compare them to Van Cafe's aluminum versions: https://vancafe.com/left-and-right-fuel-expansion-tank-kit/ . $$$$$$$$$
If mine needed replacing (after 30+ years) I'd go with the new plastic ones. _________________ "Fritz", a temperamental and unforgiving 1989 Westy that proudly bears his German flags and status as a member of the exclusive GoWesty Belly Flop Club.
1989 Westy Makeover: GoWesty 2.3L Engine plus plus plus https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0 |
VanWagon Samba Member
Posted: Tue Apr 19, 2022 9:38 am Post subject: Re: Evap tank replacement |
| Thanks you all l. I've got it covered for now. I appreciate the responses. I'm still learning how to source parts for this new vehicle and appreciate how helpful everyone is here |
dobryan  Samba Member
Joined: March 24, 2006 Posts: 17325 Location: Brookeville, MD
mtnhome  Samba Member
Joined: July 17, 2010 Posts: 626 Location: Summit County, CO
Silverghost500 Samba Member
Joined: August 01, 2018 Posts: 1198 Location: Atlanta, GA
Posted: Tue Apr 19, 2022 5:36 am Post subject: Re: Evap tank replacement |
Ken at Vanagain has new plastic evaporation tanks available. I had to replace one of mine last year as it had cracked and lost the hose nipples. _________________ 1986 Volkswagen Vanagon Westfalia "Von Westy"
Honda K24A conversion
3-Speed Automatic
Von Westy YouTube Channel
https://www.youtube.com/channel/UCbhyZYxJEQrUuLnMbLleeIA |
VeeDubn Samba Member
Joined: May 31, 2019 Posts: 168 Location: Olympia, Washington
Posted: Mon Apr 18, 2022 9:34 pm Post subject: Re: Evap tank replacement |
| VanWagon - sent you a PM; we are in WA and just replaced our expansion tanks - old ones appear to be in good shape and are available. |
Posted: Mon Apr 18, 2022 8:33 pm Post subject: Re: Evap tank replacement |
| vanis13 wrote: |
| FWIW I used a $30 Amazon alum tank |
Picture? Link? |
vanis13 Samba Member
Joined: August 15, 2010 Posts: 4623 Location: ABQ NM USA.... Except when not
Posted: Mon Apr 18, 2022 3:37 pm Post subject: Re: Evap tank replacement |
FWIW I used a $30 Amazon alum tank _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
Posted: Mon Apr 18, 2022 3:16 pm Post subject: Re: Evap tank replacement |
Thanks for the replies. I live in WA so not close to you I'm MT
I will follow up with some of the postings on the classified section as suggested, but what are your thoughts on the expensive kit vs the value of a used part with 30+ years of oxidation and fuel wear?
I don't want to get in the habit of buying expensive unnecessary parts, but is this part of the fuel system worth a $400 update over a $100 used? |
SCM Samba Member
Posted: Mon Apr 18, 2022 10:23 am Post subject: Re: Evap tank replacement |
OP, where do you live?
If you live really close to me, I have a pair I could part with but I'm too busy to deal with all the stuff that the guys in the Classifieds are willing to do. _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
revolution337 Samba Member
Joined: May 23, 2009 Posts: 400 Location: Pennsylvania
Posted: Mon Apr 18, 2022 9:45 am Post subject: Evap tank replacement |
Recently bought an 87' weekender and starting to fix it up, beginning with the fuel system.
I ordered up fuel lines, sender, and tank seal kit. I need to replace the broken EVAP tanks, left definitely, right probably. The only ones I can find are the $400+ tig welded aluminum ones on vancafe. Are there any other options out there? I don't live near a wrecking yard that has old vanagons so online is my main option. Can anyone point me to one of these? I tried searching the forums, Google, and reading way too many posts. |
