BOSCH 6-Volt Horn Fried?
brookmp
brookmp is offline
PostPosted: Mon Mar 10, 2025 11:15 pm    Post subject: Re: BOSCH 6-Volt Horn Fried? Reply with quote
sctbrd wrote:
Check the resistance of the coil. If it is not an open circuit, the internal contact might just be burnt and need cleaning and/or adjustment.
The wires are pretty robust so I doubt the coil wire itself burnt up. Maybe...
Some helpful info- look toward the bottom of page 1 for photos and general procedure:
https://www.thesamba.com/vw/forum/viewtopic.php?p=4819237
Thanks, I'll check it out. I appreciate the reply.
1968 Westfalia Campmobile
1971 Double Cab Pick-up
1974 Standard Beetle
sctbrd
sctbrd is offline
PostPosted: Mon Mar 10, 2025 10:50 pm    Post subject: Re: BOSCH 6-Volt Horn Fried? Reply with quote
brookmp
brookmp is offline
PostPosted: Mon Mar 10, 2025 6:12 pm    Post subject: BOSCH 6-Volt Horn Fried? Reply with quote
Hello,
I acquired a 6-volt BOSCH horn that was mistakenly installed in a 12-volt 912 and the horn got fried.
My question is this: can this horn be brought back from the dead or is it a lost cause?
Thanks
