modok Samba Member
Joined: October 30, 2009 Posts: 27655 Location: Colorado Springs
Max Welton Samba Member
Joined: May 19, 2003 Posts: 11028 Location: Black Forest, CO
modok Samba Member
Posted: Tue Jul 15, 2025 10:35 pm Post subject: Re: Transmission Input Shaft Tube |
I'd say weld all thread to it and use a slide hammer.
The newer improved version of this part has a few holes drilled in it so you can make a puller, and a drain hole so as to..... not channel all leaked oil directly into the clutch.
You can buy a new one, or just put a lot of holes in yours while you can. |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79430 Location: Sneaking up behind you
Posted: Tue Jul 15, 2025 1:05 pm Post subject: Re: Transmission Input Shaft Tube |
Agreed its a retrofit that's pressed in. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
EVfun  Samba Member
Posted: Tue Jul 15, 2025 1:01 pm Post subject: Re: Transmission Input Shaft Tube |
The right size shaft collar and a puller perhaps? I kinda hate the wiggle it out idea because it needs to fit snug when it's put back in. _________________
Wildthings wrote: |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20800 Location: Just a tiny bit west of Yosemite Valley
Posted: Tue Jul 15, 2025 10:46 am Post subject: Re: Transmission Input Shaft Tube |
Aftermarket press in (pound in with hammer) tube..... Wiggle it up and down and sideways till it comes out....
It's so you can use late TO bearing on early trans... _________________ “Fear The Government That Wants To Take Your Guns"
Bobs67vwagen Samba Member
Joined: March 27, 2005 Posts: 263 Location: Eastern north carolina
Posted: Tue Jul 15, 2025 10:45 am Post subject: Re: Transmission Input Shaft Tube |
I have never seen that before either. Is that a late type 2 trans? |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 11015 Location: Oregon
Posted: Tue Jul 15, 2025 10:17 am Post subject: Re: Transmission Input Shaft Tube |
That's a first for me. All the TO tubes I have seen are three bolted.
I'm spit balling here. Perhaps if you heat the tans case a little around the seal area, the metal will expand a bit and release it's grip on the tube.
Kind of the reverse of installing a crank timing gear, just much cooler temp. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
2003 Astrovan? GFYS again, Xevin!  |
