Cleaning Door Locks
Paslode235
Paslode235 is offline
PostPosted: Sat Nov 17, 2007 8:48 pm    Post subject: Cleaning Door Locks Reply with quote
Hey a while back a saw someone a while back, gave a site for dismantling and cleaning door locks. I can't seem to find that site anymore. Can anyone help me out?!?!?!?
"We make a living by what we get, but we make a life by what we give." Sir Winston Churchill
Mint Green 1965 Beetle - "Misty"
White 1974 Westy - "The Fig Rig"
Yellow 1972 Super Beetle - "Jasper" RIP
Black 2001 Jetta wagon - "Gadget"
Red 2004 Jetta TDI - "Lucy"
Karl
Karl is offline
PostPosted: Sat Nov 17, 2007 8:55 pm    Post subject: Reply with quote
Go here: http://www.type2.com
On the left side, look for Ness-Tek about halfway down.
Click on Ness-Tek.
Scroll down in technical articles to the last one in body. Click on the latch picture.
pb24ss
Location: sitting around the fire with the bluegrass band - colorado
pb24ss is offline
PostPosted: Sat Nov 17, 2007 8:57 pm    Post subject: Reply with quote
http://pictures.radom.org/v/vw/projects/door_locks/
remove door panels
remove the locking mechanisms
clean
Buscuss
Buscuss is offline
PostPosted: Sat Nov 17, 2007 10:08 pm    Post subject: Cleaning Door Locks Reply with quote
Van Ness really doesn't tell you how to clean the locks.
Many, many years ago, when I was in basic training, a cook sgt. gave some of us a tip on how to clean the small spaces of an M-1 Garand trigger mechanism - boil it in soapy water. Rinse in clear boiling water and hang to dry, which it will, quickly as it's hot.
That isn't how I cleaned my door locks, though it's an option. I used, since it was on the shelf, carb cleaner. Spray. Let it sit a bit. Blow out with air. Repeat until clean. Mine took three cycles. Lubed per Van Ness. Works like buttah.
WTB swivel table hdwr.
'73 Safare poptop
A society is as lax as its language.
Paslode235
PostPosted: Sun Nov 18, 2007 1:27 pm    Post subject: Reply with quote
Thanks for the advise but I think I should be more specific. The site I am looking for talks about and shows how to remove the Key cylinder out of the door handles and how to clean them. Thats what I'm looking for. I have some sticky door locks and I want to know what is the best way to go about cleaning them with out losing parts of the cylinder. Thanks everyone!!
pb24ss
pb24ss is offline
PostPosted: Sun Nov 18, 2007 2:04 pm    Post subject: Reply with quote
sticky door locks are the result of gummed up locking mechanisms. see the pics above. it generally has nothing to do with the cylinder, but rather the 30 years of build up in the actual mechanism. the key and cylinder just rotate the nub that activates the mechanism.
mintonman
mintonman is offline
PostPosted: Sun Nov 18, 2007 2:06 pm    Post subject: Reply with quote
Just take them apart & remember how it goes back together, they are not hard to do, but be sure to make a note as to wich tumbler goes in wich slot or your key won't work. Here's a before & after of my 1959 treasure chest door lock. This has no screws holding it together, just metal posts with flattened ends wich I had to make by hand to reassemble correctly. Bay locks are very easy to do & the only thing to loose from the cylinders is a spring/springs or a tumbler. As you pull the tumbler out go slow cause the tumblers can shoot out along with their springs. Good luck Wink
My cylinder was all siezed up with years of dirt & had to soak it just to get the tumblers & springs out.
Cleaned
Hoockd on fonicks werkt for mee?
under the influance "DUH"
Paslode235
PostPosted: Sun Nov 18, 2007 4:11 pm    Post subject: Reply with quote
Okay what is the best solvent to clean the tumblers with? Could I use an ultra sonic cleaner (one used for jewelry) and clean them up? It seems that would work out the best since it would get all the little stuff off of it.
mintonman
PostPosted: Sun Nov 18, 2007 4:19 pm    Post subject: Reply with quote
Yeah, if you have access to one that would be great. A dab of dish soap will help as well, it will cut the grease if any is left on there Laughing
mintonman
PostPosted: Sun Nov 18, 2007 4:24 pm    Post subject: Reply with quote
I should also note that there are not as many tumblers in the cylinder as are shown in my pic above, they were spares for rekeying.
germansupplyscott
germansupplyscott is offline
PostPosted: Sun Nov 18, 2007 4:25 pm    Post subject: Reply with quote
i soak them in a jar of lacquer thinners. the ultrasonic bath will work beautifully.
SL
AhnwS71
AhnwS71 is offline
PostPosted: Thu Jan 09, 2020 8:36 pm    Post subject: Re: Cleaning Door Locks Reply with quote
I was having trouble with a front door lock/open problem. I have taken it all apart and noticed there is no little spring. I have some ready for that, but i am cleaning everything before i put it all back together.
So i have the lock mechanism soaking in kerosene. per some other posts.
How can i clean the lock cylinder? do i have to take if out of the handle?
will spraying in carb cleaner or brake cleaner effect the silver color on the handle if i do not remove the cylinder first?
If so, how do you remove the cylinder without it all coming out in pieces?
Thank you for your input.
'71 Westy
Sometimes you eat the bar, and sometimes the bar eats you. the Stranger
ivwshane
ivwshane is offline
PostPosted: Thu Jan 09, 2020 9:35 pm    Post subject: Re: Cleaning Door Locks Reply with quote
Put and keep the key in the lock and then remove the screw in the back and then slide the tumbler out. So long as you keep the key in the lock it shouldn't come apart.
77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab
alman72
alman72 is offline
PostPosted: Fri Jan 10, 2020 4:12 am    Post subject: Re: Cleaning Door Locks Reply with quote
I am getting ready to dive into my passenger door. It "locks" with the key, or the lever inside by the opening handle (it is a 73) HOWEVER, when you grab the outer handle and try to open the locked door, it just opens!. I do have a thicker door card than stock on the door that I suspect, but the drivers door works just fine. any thought on what could be going on?
vwwestyman
vwwestyman is offline
PostPosted: Fri Jan 10, 2020 6:39 am    Post subject: Re: Cleaning Door Locks Reply with quote
On that '73 door: If you lock it from the inside, are you holding the outside door handle "trigger" as you shut the door? Or just shutting it?
If you don't hold the trigger as you close the door, it'll unlock itself. That's to help keep you from locking your keys in.
Dave Cook
1973 Wild Westerner
My Thing
AhnwS71
AhnwS71 is offline
PostPosted: Fri Jan 10, 2020 8:52 am    Post subject: Re: Cleaning Door Locks Reply with quote
Do you push the cylinder in and it come out from the side where the screw is?
I have taken that screw out
and put the key in. I pushed from the key side and nothing budges.
'71 Westy
alman72
alman72 is offline
PostPosted: Fri Jan 10, 2020 9:47 am    Post subject: Re: Cleaning Door Locks Reply with quote
even using a key on the outside it wont stay locked. the inside tab pulls in like its locked, but the door opens from the outside and the tab pops back out (lock the door tab, button, lever thing by the inside open latch)
kreemoweet
kreemoweet is offline
PostPosted: Fri Jan 10, 2020 10:38 am    Post subject: Re: Cleaning Door Locks Reply with quote
There's a tiny grub screw holding the lock cylinder in the body. M2.6x4 if I recall. After it's removed the cylinder
will just pull out with the key.
'67 bug: seized by the authorities
AhnwS71
AhnwS71 is offline
PostPosted: Fri Jan 10, 2020 6:15 pm    Post subject: Re: Cleaning Door Locks Reply with quote
[quote="kreemoweet
will just pull out with the key.[/quote]
You are correct sir. I had to hit it with a Dremel to find it.
Tiny bugger. thank you
'71 Westy
ivwshane
ivwshane is offline
PostPosted: Fri Jan 10, 2020 7:31 pm    Post subject: Re: Cleaning Door Locks Reply with quote
Interesting. I don't recall a grub screw on my handle (77).
77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab
