Won't start after points & cond. replaced
whc03grady
whc03grady is offline
PostPosted: Fri Jan 07, 2011 2:37 pm    Post subject: Won't start after points & cond. replaced Reply with quote
Gertie's starts were getting progressively harder, often requiring a second (or third) turn of the key to finally kick the engine over, so I suspected the points.
I adjusted the valves first since they were overdue anyway; nothing was amiss.
I inspected the rotor and cleaned it up a bit by lightly brushing it with an emery board. The contacts in the cap didn't look so hot, but not terrible. I ordered a new cap and rotor anyway, which will arrive tomorrow.
I removed the old points and sure enough one point had a crater and the other a mountain.
I replaced them and the condenser, got them to about 0.016" in anticipation of doing the timing, and now it won't start. Crankedy-crankedy-crankedy-crankedy, nice and even but obviously no spark. Plug wires are on in order, everything's back together correctly. There is plenty of gas.
Frustrating.
1974 Westfalia "Ludwig"
1971 Squareback "Gertie"
Read about their adventures
blankmange wrote:
The Bentley assumes that the car is complete.
Woreign
Woreign is offline
PostPosted: Fri Jan 07, 2011 3:22 pm    Post subject: Reply with quote
Did the ground wire inside the distributor happen to come loose? It's a small braided wire that grounds the advance plate to the dist. case.
Or it could be a bad condenser?
whc03grady
PostPosted: Fri Jan 07, 2011 3:51 pm    Post subject: Reply with quote
Though I got it from someone whom I think I can trust, the new condensor didn't look exactly the same as the old one. The old one was the style where the metal strap that straps the condensor to the dizzy has a fork (for lack of a better term) on it where you push the gray plastic plug onto. The new one didn't.
On a whim, I put the old condensor back on. I should've done just that and no more, but since I'm not appropriately scientific I also hit the contacts in the distributor cap with an emery board to clean them up.
The car fired right up.
I don't know if it was the cleaning of the contacts, or the replacement of the condensor that did the trick.
Russ Wolfe
Russ Wolfe is offline
PostPosted: Fri Jan 07, 2011 3:57 pm    Post subject: Reply with quote
The new condenser could have been grounding out, since it was not the right one.
Rarely, do condensers go bad. In my experience, I think I have found 1 bad one.
Gary: OK. Ima poop.
Max Welton
Max Welton is offline
PostPosted: Fri Jan 07, 2011 4:00 pm    Post subject: Reply with quote
Why are we focused on the ignition? Have you ruled out compression yet?
Max
1967 Type-3 Fastback
whc03grady
PostPosted: Fri Jan 07, 2011 5:27 pm    Post subject: Reply with quote
Max
I focused on ignition because it was the only system I'd really messed with. Aside from the hard starting (cured by the new points), the car ran fine before I replaced the condenser. Now that I put the old one back, it runs fine again.
supaninja
supaninja is offline
PostPosted: Fri Jan 07, 2011 7:14 pm    Post subject: Reply with quote
whc03grady wrote:
Max
excellent troubleshooting right there. it ran before you messed with the ign, didn't run afterwards. could only be bad ign parts or operator error. Damn thats 2 new condensors in two days on here, in the business world that would indicate a trend.
http://i5.photobucket.com/albums/y163/chucky1974/ninja.gif
Nick
Megasquirted Type 4 powered Notch http://www.thesamba.com/vw/forum/viewtopic.php?t=427890&postdays=0&postorder=asc&start=0
Blog of Doom http://supaninjanick.wordpress.com/
View user's profile Send private message Send e-mail Yahoo Messenger Facebook Classifieds Feedback
