darg Samba Member
Posted: Tue Jul 15, 2014 1:53 pm Post subject: upper cyl cooling tin |
I have two small pieces of tin about 2X3 with a notch ( slit) on both tabs. They were left off by the previous owner. Can someone tell me where they might go. and how to get them in place with removing any engine parts. I understand it goes above the push rod tubes. I thank you for needed help
Mr.Duncan Samba Member
Joined: May 12, 2012 Posts: 3543 Location: Houston, TX
Posted: Tue Jul 15, 2014 2:09 pm Post subject: |
left off? thats bad.
You have to install them (they snap to the cylinder studs) when the heads are off and the pushrods/tubes are out. (while the motor is out)
See the black square on each side of the engine above the pushrod tubes in on the cylinder fins. my photo below-
_________________ (Owner) www.vintagecarleds.com
Red 1971 Squareback Thread
Red 1966 Beetle Thread
1971 Green Super Beetle (sold)
1966 Ghia (sold)
1971 Blue Super Beetle (sold)
1966 Java Green Std Beetle (sold)
1971 Red Squareback (sold)
1966 Red Beetle |
TheAmazingDave Samba Member
Joined: April 11, 2013 Posts: 789 Location: San Jose, CA
Posted: Tue Jul 15, 2014 2:13 pm Post subject: |
If you have time and patience, you may be able to finagle them in place with the engine assembled.
Try not to run the engine without them, you'll end up toasting your cylinders. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33155 Location: Hot Arizona
Posted: Tue Jul 15, 2014 2:35 pm Post subject: Re: upper cyl cooling tin |
| darg wrote: |
| I have two small pieces of tin about 2X3 with a notch ( slit) on both tabs. They were left off by the previous owner. |
I can't believe someone left those off.
Yes, I can believe it. Don't run the engine without those !!!! Or you won't have much engine left !!!! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
darg Samba Member
Posted: Tue Jul 15, 2014 3:08 pm Post subject: cyl tin |
The blk pieces are they next to the block?
How is the best way to install them without taking the head off? The body of the bug is off the pan,
thanks |
talljordan Samba Member
Joined: January 10, 2012 Posts: 1122 Location: San Francisco, CA
Posted: Tue Jul 15, 2014 3:30 pm Post subject: Re: upper cyl cooling tin |
| Cusser wrote: |
| darg wrote: |
Yes, I can believe it. Don't run the engine without those !!!! Or you won't have much engine left !!!! |
If you have a hard time believing that wait till you hear this. After rebuilt my motor I had my VW mechanic do the timing and carb and install all at once (I was on a time crunch, give me a break ). He said he was impressed I didn't screw it up, when I asked what he meant he relayed some home rebuild horror stories. The best by far was a guy who put the tins on the bottom of the tins like he should but also added an extra set on the TOP! He was very confused as to why his engine was toast apparently... _________________ 1972 Super Beetle, Parked until adequate restoration funding is acquired in restoration!
Wanted: Male computer diagnostic plug end |
darg Samba Member
Posted: Tue Jul 15, 2014 4:01 pm Post subject: cyl tin |
I guess some people just forget to install them or to lazy.
Mr Duncan. Can you please tell me exactly where the tin goes. I can,t quite figure the picture out.
XBIG DX 408X. Can you please tell me what I have to do to install the tin without removing the head and pushrod tubes?
More idea would be helpful from the members
Posted: Tue Jul 15, 2014 4:22 pm Post subject: Re: cyl tin |
| darg wrote: |
Just call me Big D.
I'm reminded of the time the starter packed its bags on my Toyota MR2. The BGB (Toyota equivalent of the Bentley manual) stated that complete removal of the exhaust system, manifold and all, was necessary to replace it. Time and patience proved otherwise.
The tabs on those little plates aren't so long IIRC. I think you'd be able to get them in by removing the sled tins to give you some room, and then slipping them in place between the tubes and jugs, and snapping them in over the head studs. I haven't had to test this theory, but it's worth a shot. |
darg Samba Member
Posted: Tue Jul 15, 2014 4:39 pm Post subject: cyl tin |
OK BIG D, thanks
Do you know exactly where they go?  |
Posted: Tue Jul 15, 2014 4:39 pm Post subject: Re: cyl tin |
| darg wrote: |
You literally just push them between the cylinders, on the bottom side, the tabs click onto the head bolts. The tabs are asymmetrical so there is a correct orientation but it is pretty easy to figure out which way is right by looking at it. _________________ 1972 Super Beetle, Parked until adequate restoration funding is acquired in restoration!
Posted: Tue Jul 15, 2014 4:42 pm Post subject: Re: cyl tin |
| darg wrote: |
OK BIG D, thanks
Directly between, and up against, the bottoms of the cylinders. |
sb001 Samba Member
Joined: May 19, 2011 Posts: 10463 Location: NW Arkansas
Posted: Tue Jul 15, 2014 4:49 pm Post subject: Re: cyl tin |
| darg wrote: |
OK BIG D, thanks
Circled from Mr. Duncan's photo above (behind the pushrod tubes):
_________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
Joel Samba Member
Joined: September 04, 2006 Posts: 11099 Location: NSW Australia
Posted: Tue Jul 15, 2014 5:39 pm Post subject: Re: upper cyl cooling tin |
| Cusser wrote: |
Yes, I can believe it. |
Spend long enough working at a VW garage and it almost becomes surprising when you see an engine that still has them.
Engines worked on by non VW mechanics they often get the heads and pushrods on then realise shit I forgot those, meh to much work to fit customer wont notice  _________________ Quick little bug, you got a Porsche motor in that?
1974 Germanlook 1303 2.5 Suba-Beetle |
darg Samba Member
Posted: Wed Jul 16, 2014 2:47 am Post subject: cyl tin |
Thanks for all of the help.
I see the one now that are circled .
I hope the tabs go in without bending them to slide in.
You are right about people leaving things off that they forgot, hoping the customer would not catch it.
Posted: Wed Jul 16, 2014 2:14 pm Post subject: |
another photo
1966 Ghia (sold)
1966 Red Beetle |
ach60  Samba Member
Joined: May 14, 2001 Posts: 4137 Location: Santa Maria
Posted: Wed Jul 16, 2014 3:36 pm Post subject: |
| Mr.Duncan wrote: |
another photo
A long time ago in a galaxy far away I had a buddy I was helping with the same problem.
I cut the verticle parts off that "Clip" to the cylinder studs, and safey wired
the defectors in place.
It was a fresh rebuild of unkown value, but my friend wanted it "fixed" quickly without pulling the motor, or pulling the heads. _________________ Good Luck
Al |
VWCOOL Samba Member
Joined: June 02, 2006 Posts: 1821 Location: Down under
Posted: Wed Jul 16, 2014 3:42 pm Post subject: |
| Yes I too have seen the tins "abbreviated" and wired into place |
Brian Samba Moderator
Posted: Wed Jul 16, 2014 11:52 pm Post subject: |
My thought on head tins:
"Without them, your engine will explode and you will die"
its not true, but helps me remember. They are important, every piece of tin is important expect the pulley cover. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
