SyncroGhia Samba Member
Joined: August 21, 2009 Posts: 2458 Location: Highnam, UK
Posted: Mon Jul 28, 2014 1:56 am Post subject: T3 Syncro (Vanagon) Rear Shock Absorber Alternative |
As usual, when I find something that works, I try to let people know and here is another.
An easy swap over for the rear of the T3 Syncro is from the LandRover Discovery 2 (1998-2004).
The standard rear shock absorber is almost identical to the standard rear sock absorbers fitted to the T3 Syncro.
They both have the same overall length, compressed and open.
They both have a similar outer diameters.
They both use M12 bolts to fit although the Disco 2 mounting tube is 1mm longer than the T3 Syncro so you have to open the mounting flange a little, not hard to do.
I've been running the Pedders 9503 on Limey for a while now as have other Syncro owners. Other friends have bought stock length cheap Disco 2 rear shocks from eBay (these can be as cheap as £40 for a pair!) and had very good results.
Another very good bit of news is that you can buy +2 (that's 2 inches longer than stock) off the shelf as well. Terra Firma offer these for as little as £35 each new) so you can see that the cost is vastly different from what is available within the Syncro market at present.
There is more! If you're going all out, you can buy +3, +4 and +5 rear shocks for the Disco 2 again off the shelf!!
The damping rate is very similar to the T3 and with such a large range of rear shock absorbers on the market for the Disco 2, you're sure to find something that you're happy with.
As people cotton on to this info, I hope that you will report back with your findings as to what is good/bad etc.
Oh, just in case someone asks, the damping rates were compared by the technical boffins at Pedders R&D in Australia to a stock Syncro rear shock absorber that I sent over for testing... so it's not just me saying 'yeah they'll fit mate!'
One word of warning...
If you put longer rear shock absorbers on, your rear CV joints will be able to move further than they were designed to by VW. I would suggest that if you want to go +2, you fit Porsche 944 CV joints (which have more travel but may not be any stronger than standard) or upgrade to 108mm CV joints as fitted to the Syncro 16.
I know that the Disco 2 is not a very common vehicle in the States but over here... they're all over 'de place
Have fun out there
MG _________________ T3 Syncro 16 S6 Westfalia Limey SOLD
T3 Syncro 6x6 SOLD
T3 RS6 Bluestar
T3 Tristar Syncro 16 SOLD
T3 Tristar Syncro RHD SOLD
luckystu Samba Member
Joined: September 20, 2011 Posts: 70 Location: Tasmania, Australia
Posted: Mon Jul 28, 2014 3:09 am Post subject: |
Great work. Thank you! _________________ 1990 Syncro Camper : 2.1wbx : Rear Locker : Decoupler : Camperize pop top conversion ; 2" lift and 16" CLK rims (215/70r16} |
BenT Syncro Samba Member
Joined: January 07, 2005 Posts: 1088 Location: San Francisco
Posted: Mon Jul 28, 2014 4:45 am Post subject: Re: T3 Syncro (Vanagon) Rear Shock Absorber Alternative |
| SyncroGhia wrote: |
They both use M14 bolts to fit although the Disco 2 mounting tube is 1mm longer than the T3 Syncro so you have to open the mounting flange a little, not hard to do. |
Is there any chance that you have a pic of this mod? Is it the tube at the bottom of the shock bushing that's is too long?
| SyncroGhia wrote: |
I know that the Disco 2 is not a very common vehicle in the States but over here... they're all over 'de place  |
There are quite a few in my part of the country. Perhaps not as much as the UK but broken ones litter the landscape here. Once anything major stops functioning, they end up in a breaker yards.
Just curious. What's the difference between the Disco 1 vs. Disco 2 rear dampers? I have a Bowler Tomcat sitting in storage which I'm told is based on Disco 1 suspension. Saw the Bilstein reservoir shocks on there and got some funny ideas about borrowing them.😉
I'm installing one of those lift kits from Finland and would rather use longer shocks than the shock extenders the vendor provided. My Syncro is a 16" so CV's shouldn't be a major issue. _________________ BenT |
VWCOOL Samba Member
Joined: June 02, 2006 Posts: 1821 Location: Down under
Posted: Mon Jul 28, 2014 4:50 am Post subject: |
Goed info  |
Posted: Mon Jul 28, 2014 6:27 am Post subject: Re: T3 Syncro (Vanagon) Rear Shock Absorber Alternative |
| BenT Syncro wrote: |
| SyncroGhia wrote: |
They both use M12 bolts to fit although the Disco 2 mounting tube is 1mm longer than the T3 Syncro so you have to open the mounting flange a little, not hard to do. |
It's both top and bottom tubes that are 1mm longer. There is enough 'give' in both top and bottom brackets to be able to accommodate this 1mm, in fact you'll probably find that some of the replacements available in the market place are already 0.5mm away from standard. There's no photo to show as it's not a modification, you push the shock absorber in if you get me. You wouldn't know about it looking if I hadn't told you and you would also dismiss it as 'oh it's a bit tighter' when you fitted it.
| SyncroGhia wrote: |
The Disco 1 rear has pin fittings top and bottom. The Disco 2 rear has eyelet fittings top and bottom, the same as the T3.
I'm installing one of those lift kits from Finland and would rather use longer shocks than the shock extenders the vendor provided. My Syncro is a 16" so CV's shouldn't be a major issue. |
T3 Syncro 6x6 SOLD
T3 RS6 Bluestar
Posted: Mon Jul 28, 2014 6:42 am Post subject: |
Got it. Thanks! _________________ BenT |
ragnarhairybreeks Samba Member
Joined: October 26, 2009 Posts: 1945 Location: Sidney B.C. Canada
Posted: Mon Jul 28, 2014 9:12 am Post subject: |
Hi,
Just a clarification request. You wrote m14 for shock bolt, I thought it was m12.
Cheers
Alistair _________________ '86 7 passenger syncro, converted to westy pop top, project still in progress
https://shufti.blog/
Old address still works...
http://shufti.wordpress.com |
Posted: Mon Jul 28, 2014 9:30 am Post subject: |
| ragnarhairybreeks wrote: |
Hi,
Cheers
Alistair |
Sorry, I meant M12.
Amended. Obviously a muppetry moment
T3 Syncro 6x6 SOLD
T3 RS6 Bluestar
T3 Tristar Syncro RHD SOLD |
WLD*WSTY Samba Member
Joined: November 04, 2009 Posts: 438 Location: Arizona
Posted: Sat Aug 02, 2014 12:33 am Post subject: Re: T3 Syncro (Vanagon) Rear Shock Absorber Alternative |
| SyncroGhia wrote: |
MG |
How about the front struts? _________________ '82 SyncroWesty, the first ever conversion.'06 Subaru 2.5L |
Posted: Sat Aug 02, 2014 1:22 am Post subject: |
I'm still working on the front.
The spring is an odd size diameter so there are very few out there and similar to find a strut which has close enough dimensions to accept the Syncro spring so I'm now looking at complete struts with smaller diameter springs to try.
If I find something, I'll let you know...
T3 Syncro 6x6 SOLD
T3 RS6 Bluestar
Posted: Sat Aug 02, 2014 1:24 am Post subject: |
The spring is an odd size diameter so there are very few out there and similar t to find strut which has close enough dimensions to accept the Syncro spring so I'm now looking at complete struts with smaller diameter springs to try.
T3 Syncro 6x6 SOLD
T3 RS6 Bluestar
Jon_slider Samba Member
Posted: Sat Aug 02, 2014 12:18 pm Post subject: Re: T3 Syncro (Vanagon) Rear Shock Absorber Alternative |
| SyncroGhia wrote: |
As usual, when I find something that works, I try to let people know and here is another....
the damping rates were compared...
If you put longer rear shock absorbers on, your rear CV joints will be able to move further than they were designed to by VW. I would suggest that if you want to go +2, you fit Porsche 944 CV joints... |
Excellent info! The Disco and the Vanagon have very similar weight and GVWR, makes sense the shocks would have similar rates
and Ive been running the 944CV's for thousands of miles without issue. I like that they have more articulation, while retaining the stock stub axle and transaxle output flanges, so a stock axle can be used for replacement in a pinch
much respect for doing all the size comparisons and sharing your "Discovery"  _________________ My Soapboxes: Inflation; Handling; Gearing; Decoupling; Swepco |
luVWagn Samba Member
Joined: February 21, 2008 Posts: 1342 Location: Snoqualmie (WA)
Posted: Sat Aug 02, 2014 6:29 pm Post subject: |
Any ideas on the perfect syncro 16 replacements? Any diff, or go with the +2? _________________ '91 Double Door Transporter |
Posted: Sat Aug 02, 2014 10:57 pm Post subject: |
Thanks Jon.
| luVWagn wrote: |
| Any ideas on the perfect syncro 16 replacements? Any diff, or go with the +2? |
I would definitely go +2 if on a 16. Damping rate is a personal thing.
I would personally look for either foam cell or adjustable damping rate shocks.
T3 Syncro 6x6 SOLD
T3 RS6 Bluestar
Waldi Samba Member
Joined: February 28, 2014 Posts: 1752 Location: Germany
Posted: Sun Aug 03, 2014 3:43 am Post subject: High end Syncro shock absorbers |
I will show/offer u a high-end solution.
The absorber are fabricated in a italien factory espacialy for the t3 Syncro for longer springs from Busschmiede.de.
https://fotos.web.de/ui/external/MVdJe5CfQBCcWKLaWkkaBw96203
The price is 1500€ without springs.
Edit: the rear absorbers can be ajusted in pulling, pushing and frequency.
The front in pulling. |
t3 Ed Samba Member
Posted: Sat Aug 09, 2014 5:39 pm Post subject: |
| I am so interested in this topic that I contacted a local Koni stockist to find out what was available. There are two types of Koni adjustables available. A bit pricey, but I like the idea of adjusting the rebound setting . The Koni guy did however say that the stock length replacement for a Disco , a "heavy track" shock, was about 30mm too short for the t3 syncro fully extended. That means I would have to go for the "plus 30" in the real HD raid shock. Real expensive but also really stiff- bit worried about how stiff it would be. I am keen on trying their stock length heavy track shock but worried about the fully extended length. Does anyone know if Koni have different ways of measuring shocks or are they perhaps being a bit conservative with their fully extended measurement ? Ed. |
narendra.vw Samba Member
Joined: February 07, 2013 Posts: 439 Location: Bangalore India
Posted: Sat Aug 09, 2014 11:14 pm Post subject: |
Nice Discovery. Thanks. |
Posted: Sun Aug 10, 2014 12:06 am Post subject: |
| t3 Ed wrote: |
It's interesting that your Koni guy listed them as being short. Every Discovery 2 rear damper that I've seen and checked is identical (within a mm or so) to the T3 Syncro.
I haven't had a pair of Discovery 2 Koni rear dampers in my hands though as most Disco owners aren't prepared to pay that much.
T3 Syncro 6x6 SOLD
T3 RS6 Bluestar
boof1306 Samba Member
Joined: July 10, 2010 Posts: 304 Location: MELBOURNE AUSTRALIA
Posted: Sun Aug 10, 2014 2:33 am Post subject: |
| Hi Eddie, I wonder if he is looking at 2wd specs? Mine had 2wd rear shocks on it when I bought it they where about 30mm short. Greg |
t3 Ed Samba Member
Posted: Tue Aug 12, 2014 2:59 am Post subject: |
| Might try check the specs again or if I have time , bring an original syncro shock to compare side by side. I had the Konis on my 2wd but never measured the difference between the 4wd & 2wd shocks, although I did notice the 2wd shock looked shorter. Ed. |
