Circuit breaker orientation
Stephenmarklay
Stephenmarklay is offline
PostPosted: Mon Oct 03, 2016 11:59 am    Post subject: Circuit breaker orientation Reply with quote
On my Aux install i have a couple manual reset circuit breakers. The small shortstop variety. Those have a mains side and aux side. But I am running a charger in the opposite direction the charger is fused but I wondered if the breaker will be harmed? what gives with the direction?
1985 Westfalia. Project 2017.
bluebus86
Banned
bluebus86 is offline
PostPosted: Mon Oct 03, 2016 12:57 pm    Post subject: Re: Circuit breaker orientation Reply with quote
a breaker is pretty apathetic, dont care, they are non polarized in regards to main and auxilary side, at least internally. . however dont put the main on the aux side unless you relable or obliterate the wrong labling. this is for safety.also per codes the switch for toggle type breakers should be down for off, and up for on, on verticle mounting just like properly installed wall light switches are orientated., this is for safety, also. a falling object striking it in the off position is not going to switch it on. plus it is uniform standard for visual inspection of state of breaker.
however why would you need to run the wires on the wrong side, wires not long enough to reach?
note some fancy dancy new fangled ground and arc fault smart breakers may have polarity sensitivty to main and auxilary side.
also if you have a fuse inline you dont need the breaker, and visa versa. using both wont help you any, so bypass one of them. if you suspect you may have semi frequent overloads then a breaker is a wise choice economically long term verses buying fuses all the time. if you dont expect overloads except in an emergency, then a fuse may be more economical.
note a breaker tripped regularly does tend to wear out. they get hot before tripping, and that heat can eventually weaken the spring that holds them closed, causing them to trip more frequently, add to that the arcing each high amp breaking event does to the contacts, they get pitted, oxidize, and then make a high resistance contact, which causes them to heat more, again making the breaker trip at below rated loads, each time pitting the contacts a bit more. if a well used breaker seems to start tripping more frequently, it might be worn, use ammeter to test.
bottom line is dont overload it often.
bluebus86
Banned
PostPosted: Mon Oct 03, 2016 1:09 pm    Post subject: Re: Circuit breaker orientation Reply with quote
Circuit breaker orientation? Sure we welcome all orientations, we even have a transister bathroom policy! We are well integrated circuits.
I hope we all suffer few zener moments, and diode. I hope this from the bottohm of my heart.. Confused Confused Confused Confused
ps Did you hear about the Presidents new electromigration policy, it will thin the lines at the border. Confused Laughing
i knew this is a silicide mission once we made contact.
This is all very Shockley information.
V/R am done.
Stephenmarklay
PostPosted: Mon Oct 03, 2016 1:24 pm    Post subject: Re: Circuit breaker orientation Reply with quote
Thanks again Bluebus86. I kind of wish I would have I would have planned my AUX/Charger/Solar/Combiner stuff a little longer since I feel like I am chasing my tail.
Anyway I have an AUX feeding a sub fuse box under the sink. I put a 50A circuit breaker on that line as it is possible to have too much connected (fused accessories) and I don’t won’t to overload the wiring.
The the sub fuse box has a positive and negative bus that I am using to connect a line to the outside to use as either for accessory power (tire inflater or christmas lights) but I also plan on using a 100W portable solar charger with that. That charge will now be going back to the AUX through the circuit breaker. I also plan on putting a shore charger on that bus again going the wrong direction.
Both the outside accessory line and the shore charger will be separately fused as the are not running through the panel just borrowing the bus.
The reason I am doing this is to minimize the amount of big wires (8 AWG in this case) to the battery box. I don’t want the van to look like a power station.
Stephenmarklay
bluebus86 wrote:
Circuit breaker orientation? Sure we welcome all orientations, we even have a transister bathroom policy! We are well integrated circuits. I hope we all diode. Confused Confused Confused Confused
Funny Smile
bluebus86
Banned
PostPosted: Mon Oct 03, 2016 1:48 pm    Post subject: Re: Circuit breaker orientation Reply with quote
maybe i am thinking this wrong, but do you want to run the solar output to one side of the breaker, and the other side both the input power (from battery) and the load? if so the load wont be protected wehn under battery supply, only when under solar supply.
the load and only the load is on one side, the other can have the supply, be it battery or and solar. usually but battery and solar should be in parallel anyway for charging
good luck
Stephenmarklay
PostPosted: Mon Oct 03, 2016 2:23 pm    Post subject: Re: Circuit breaker orientation Reply with quote
Trust me your not the only one a little bit confused Smile
I am for sure having fits about this.
Taking the breaker out of the equation I have a power and ground running to a fuse box via the AUX. The loads are all fused.
I also have a line in connecting to the same points not the fuse box as the AUX. So if solar is on connected its is essentially just connected to the AUX via the bus on the fuse box.
That solar line has its own fuse not part of that fuse box. Enter the circuit breaker. The breaker is in the AUX line to the fuse box. The purpose is to protect that wire from overheating if some dim wit (me) decides to draw 50 amps at one time (I don’t think I will even have that high of loads anyway) from the AUX though the fuse box.
While current will flow into that circuit breaker to charge the AUX it is not there for its consideration and does not need that protection. Again that line is fused separate.
*Since that solar line goes to the side of the van and directly connects to the AUX there is also opportunity to be used as a load if the panel is not plugged in.
*This would be no different than a small solar charger plugged into a cigarette lighter.
I hope I am making an iota of sense.
bluebus86
Banned
PostPosted: Mon Oct 03, 2016 3:45 pm    Post subject: Re: Circuit breaker orientation Reply with quote
the AUX, what is that? a terminal? whats it on?
thanks.
Stephenmarklay
PostPosted: Mon Oct 03, 2016 4:12 pm    Post subject: Re: Circuit breaker orientation Reply with quote
thanks.
I tend to forget what is my head is not in every one else's too. AUX was just my abbreviation for Auxiliary battery.
bluebus86
Banned
PostPosted: Mon Oct 03, 2016 4:22 pm    Post subject: Re: Circuit breaker orientation Reply with quote
ok, YES, current can flow either direction thru a circuit breaker, it is simply a switch that automatically opens at a predetermined current, so treat it like a switch, charge battery thru it one way, load battery thru it the other. that will work! and it will give rated protection in either mode.
just lable the terminals to reflect what you have done so someone else can quickly figure it out basically either side can be the "mains" side on the breaker depending on if battery is being drained or charged at any time
good luck
ps it is good to draw it all out in a schematic. then take a photo or scan your proposed schematic for critisism, and comments. several folks here are pretty knowledgeable on dual batteries, solar and such, I just dive a plain ole tin top, and am of limited help. lets see your plan, even if you dont need help,, your plan then would help others.
fxr
fxr is offline
PostPosted: Mon Oct 03, 2016 4:27 pm    Post subject: Re: Circuit breaker orientation Reply with quote
I'm confused by a description of a 12V thermal circuit breaker with 'mains' and 'aux' terminals.
Never, ever, seen one of those before.
Surely they are polarity insensitive? I'd never use one that suggested it was...
Jim Crowther
Vespa GTS 300
bluebus86
Banned
PostPosted: Mon Oct 03, 2016 4:47 pm    Post subject: Re: Circuit breaker orientation Reply with quote
the mains means the hot side. it is too help assure a standardized wiring method. less accidnets occur if the danverous hot side is always oriented the same. important when the breaker is switched off for service, the electrician will know which side is still hot, an industry standard, just like wall light switches are always down for off. hot water knobs are on tbe left, cold on the right. the lables are to encourage conformance to standard practice. your wall light switch is labled on and off, yet you can wire it anyway you want, but most everyone follows the labling, and thus 99.99% of light switches operate the same way, down is off.
Stephenmarklay
PostPosted: Mon Oct 03, 2016 4:50 pm    Post subject: Re: Circuit breaker orientation Reply with quote
Here is a picture.
bluebus86
Banned
PostPosted: Mon Oct 03, 2016 5:02 pm    Post subject: Re: Circuit breaker orientation Reply with quote
Here is a picture.
looks like a thermal snap switch. self resetting when cool. Cool I was thinking of a service breaker, that is manual reset, and can be manually opened. either way, it is bidirectional.
Wildthings
Wildthings is offline
PostPosted: Mon Oct 03, 2016 6:05 pm    Post subject: Re: Circuit breaker orientation Reply with quote
I don't know why it would say "BAT" and "AUX", if it were directional at all (which I doubt), I would think it would say "+" or "-".
Stephenmarklay
PostPosted: Mon Oct 03, 2016 8:05 pm    Post subject: Re: Circuit breaker orientation Reply with quote
Yeah who knows. Maybe they do that so that someone does not ground one of the terminals.
Stephenmarklay
PostPosted: Mon Oct 03, 2016 8:08 pm    Post subject: Re: Circuit breaker orientation Reply with quote
good luck
Your right. I guess when I started I figured it was no begin deal. They of course it got more complicated. I have not even mentioned how this will all tie back to the starter battery with my combiner. Luckily the one I bought is a small company (One guy) with great customer service.
fxr
fxr is offline
PostPosted: Tue Oct 04, 2016 6:21 am    Post subject: Re: Circuit breaker orientation Reply with quote
OK, knowing at a glance that the copper-plated one is the one connected to the battery rather than the load could be useful to those who are aware of that convention and who might be fault-finding (or otherwise fiddling with it). Not essential for functionality though. Wink
Jim Crowther
Vespa GTS 300
