Jac25 Samba Member
Posted: Tue Dec 13, 2016 2:47 pm Post subject: Zinc chromate? |
I have some rust behind my kitchen that i want to take care off. I would like to use zinc chromate primer; however, it hard come by locally. The only stuff i found is online; and i would like to know if this is ok to use? Link below
http://m.ebay.com/itm/361502696372?_trksid=p2141725.m3641.l6368 |
MidwestDrifter Samba Member
Joined: June 13, 2012 Posts: 769 Location: Kicking Around Australia
dcheek Samba Member
Posted: Tue Dec 13, 2016 3:25 pm Post subject: Re: Zinc chromate? |
What about POR 15 ?
Dave _________________ 1961 Bug
1965 Bug
1966 Sunroof Bug
1966 Westy
1976 914 2.0
1989 911 Carrera
1982 Diesel Rabbit Pick Up
1982 Diesel Vanagon
2014 Golf (last year German mfr for NA)
2023 Jetta Gli, Autobahn Black Edition 6 speed |
geodude Samba Member
Posted: Tue Dec 13, 2016 3:40 pm Post subject: Re: Zinc chromate? |
POR 15 and other similar products are just a barrier that seals out moisture and rust can still form under the coating if oxygen and moisture can get in there. The zinc primers actually protects the metal even when moisture gets to the metal. The zinc acts as a sacrificial anode actively protecting the metal. Best bet is to passivate the metal with a phosphoric acid solution, coat with a suitable zinc rich primer, and then topcoat with a barrier coating such as a paint or special barrier coatings like POR 15. _________________ 1988 GL Camper
1991 Multivan — the basket case |
Terry Kay Banned
Posted: Tue Dec 13, 2016 3:44 pm Post subject: Re: Zinc chromate? |
[quote="dcheek"]What about POR 15?>>
Not even close to zinc chromate.
It catalyzed black paint, nothing more. _________________ T.K. |
Terry Kay Banned
Posted: Tue Dec 13, 2016 3:49 pm Post subject: Re: Zinc chromate? |
The OP suggested that there isn't any automotive paint dealers around him.
Not one body shop supply in a 10 mile area?
Where's the local body shops get their paint & primer----fly it in?
You are looking for DuPont Vari Prime, acid etch zinc chromate primer. _________________ T.K.
Posted: Tue Dec 13, 2016 3:51 pm Post subject: Re: Zinc chromate? |
Like Geodude says, the zinc paints/primers offers better protection. Even when a zinc primer is scratched or otherwise compromised, it continues to offer corrosion protection. This is because the zinc is sacrificial. In areas where perfect coverage isn't possible a zinc rich primer is desired.
The zinc chromate/phosphate primers have the additional advantage of etching into the parent metal for better adhesion.
A zinc chromate/phosphate primer combined with a urethane based top coat is some of the best corrosion protection available.
If you have existing rust I suggest neutralizing it with an acid wash before coating as Geodude suggests. _________________ 2004 Dodge/Mercedes Sprinter (Custom Camper)
2000 Jetta TDI
1982 Diesel Westy W/ ABA I4 hybrid (Sold)
Epic Road Tripping since 08/05/12 | http://VagariesAbound.blogspot.com/
My Current Build | http://sprinter-source.com/forum/showthread.php?t=41215 |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6932 Location: Fort Lauderdale, Fl.
Jac25 Samba Member
Posted: Tue Dec 13, 2016 10:32 pm Post subject: Re: Zinc chromate? |
Thanks everyone, i guess i wasn't looking in the right places. |
metropoj Samba Member
Posted: Wed Dec 14, 2016 5:09 am Post subject: Re: Zinc chromate? |
I wondered how the Por 15 metal prep fit into all of this but based on company information it appears it is the same as a primer ?
"POR-15® Rust Preventive Coating on any metal surface, including aluminum and shiny polished metal surfaces. Our simple process gently etches metal, creating an ideal anchor pattern for coatings such as POR-15® Rust Preventive Coating, while simultaneously leaving a zinc phosphate coating to insure chemical bonding of paint and steel. Avoid other preps that may leave harmful residues which prevent proper adhesion. After thoroughly degreasing your work piece, apply environmentally safe POR-15 Metal Prep to both neutralize any rust and etch any clean bare metal. This will allow better adhesion of POR-15® Rust Preventive Coating or any other coating"
I wondered if I should be using the metal prep and a zinc chromate primer or just metal prep and Por 15.
Always willing to learn a new trick .... _________________ John.
86 TiiCo powered Westy. |
jocoman Samba Member
Joined: August 11, 2016 Posts: 497 Location: Ottawa, Canada
Posted: Wed Dec 14, 2016 7:07 am Post subject: Re: Zinc chromate? |
I am going to need to tackle a rust problem at some point.
I came across this thread and it is most interesting.
This was in 2004, 12 years ago. What is the current thinking? Is POR-15 system the way to go? |
E1 Samba Member
Joined: January 21, 2013 Posts: 8321 Location: Westfalia, Earth
Posted: Wed Dec 14, 2016 7:51 am Post subject: Re: Zinc chromate? |
I might suggest doing lots of research on body shop forums.
You need input from people doing rust work day in and day out. As a photographer, I have learned if you want mostly-bad advice, ask a camera store. In my past experience as a custom painter, I received good advice from painters, not dealers selling supplies. Sometimes you can get great advice at dealers in either case, but the problem is you won't know until it's too late.
Best of Luck. |
Terry Kay Banned
Posted: Wed Dec 14, 2016 8:19 am Post subject: Re: Zinc chromate? |
POR-15 ( again ) is nothing more tha a pre-catalyzed enamel.
It will not acid etch into the metal, it can't be used on aluminum, or stainless to offer a good binder for fill primer prior to top coating.
Vari prime applied to properly prepared sheet metal will acid bind to the sheet metal, plus offer a zinc barrier to rust.
The POR-15 is a back yard slipshot way of getting nowhere, and to make the final topcoat of anything, that final top coat must be applied prior to the POR stuff sets up.
It's overpriced garbage, & I know of zero professional refinishing shops that have ever used the allegid miracle in a can.
It will never be or act as zinc chromate acid etch primer / sealer. _________________ T.K.
Posted: Wed Dec 14, 2016 8:32 am Post subject: Re: Zinc chromate? |
"It will never be or act as zinc chromate acid etch primer / sealer."
You're right it won't. The metal etch product is supposed to do that. You missed that part.
I'll have to check out the vari prime stuff and see what its all about.
So since you are here replying, you normally put vari prime down, then the 8115 panel adhesive to do seams ? _________________ John.
bluebus86 Banned
Posted: Wed Dec 14, 2016 8:37 am Post subject: Re: Zinc chromate? |
por 15 is a poor choice. i wont use the stuff, tried it once. instead zinc chromate, variprime, dp two part primer are far superior.
good luck
ps dont use eastwood rust converter either, it promotes rust.
stick with name brnad products backed buy huge chemical companies that have invested millions in R and D to make quality products.
POR and eastwood probably have a higher advertising budget than research budget!
get products from PPG, DuPont, 3M etc...... or their subsidiaries _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
E1 Samba Member
Posted: Wed Dec 14, 2016 8:47 am Post subject: Re: Zinc chromate? |
bluebus86 wrote: |
get products from PPG, DuPont, 3M etc...... or their subsidiaries |
Agree with this.
I have a longtime client and friend doing very high-end Pebble Beach restos, and can ask him if of interest. Most of his projects are on very old cars, and I can ask my brother, too, who was a career bodyman in Florida. |
Terry Kay Banned
Posted: Wed Dec 14, 2016 8:49 am Post subject: Re: Zinc chromate? |
You have to do some reading on what product does what in a professional environment, what to use when.
You asked about the seams.
8115 displaces water /moisture-- you know that--right?
When automobiles are manufactured today, is all of the sheet metal primed first, and then the panels glued on, or glued, & then primed ?
8115 should be applied to properly prepared sheet metal, allowed to cure, then primed.
I sand blast the seams, 8815 them, then scuff them, vari-prime them, scuff, fill prime them, finish sand & topcoat.
Pretty much apply zinc , primer & paint in the same order as the mfg's. do.
I use POR on nothing.
It's for brainwashed hobbiest only.
It is truely garbage. _________________ T.K. |
