ricaroo Samba Member
Posted: Thu Jul 27, 2017 7:50 am Post subject: Door Hinge Screw Spinning |
My drivers side door hinge at the bottom is loose where it attaches to the door when I went to tighten the screws one of them just keeps spinning, before I start taking things apart what is the screw attaching to inside the door.
Does anyone have an exploded view
Thanks
Rick _________________ 1971 Standard Beetle 2 dr Sedan 1600dp |
Tom Butler Samba Member
Joined: October 03, 2016 Posts: 287 Location: Bay Area, California
Posted: Thu Jul 27, 2017 9:01 am Post subject: Re: Door Hinge Screw Spinning |
If you are talking the door side Id bet you can just take your door cards off and get a nut and bolt in there if it is spinning. If its the car side it might be a bit harder to get it in there.
I am not sure if there exists an exploded view (im sure there is I just couldnt locate it)
But if you search goog for keywords like "vw beetle door hinge" and "VW beetle door hinge exploded view" You might be able to see a few angles and figure it out.
Godspeed _________________ 1971 Super Beetle
http://www.thesamba.com/vw/forum/viewtopic.php?t=674120
Proud Member Pata De Perro Vw Club
iowegian wrote: |
Instead of converting your car to a different color, why not just buy one that is a color you like? |
Posted: Thu Jul 27, 2017 10:55 am Post subject: Re: Door Hinge Screw Spinning |
Thank You Tom, and yes it is the door side.
beetlenut Samba Member
Posted: Thu Jul 27, 2017 5:05 pm Post subject: Re: Door Hinge Screw Spinning |
I actually just took my passenger door off at the hinges, and the door side of the hinge is riveted to the door frame. Mine's a 74 super so maybe they attached differently on your older car. _________________ scrapyards are for quitters
Wetstuff wrote: |
... I spend more time shaking it than directing it?! I get a pretty decent blast for 8sec. then have to shake it again. |
- Words to live by right there!
My 74 Super rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=6507104#6507104 |
Posted: Thu Jul 27, 2017 5:49 pm Post subject: Re: Door Hinge Screw Spinning |
My hinges on the door side have the same #4 Phillips head screw that is on the pillar side _________________ 1971 Standard Beetle 2 dr Sedan 1600dp |
Posted: Thu Jul 27, 2017 6:31 pm Post subject: Re: Door Hinge Screw Spinning |
ricaroo wrote: |
My hinges on the door side have the same #4 Phillips head screw that is on the pillar side |
So there's probably a nut plate on the inside of your door that the screws screw into. Threads probably stripped on the one that spins. You might be able to get a nut on the threads of the spinning one that protrude out of the back of the nut plate. Remove your door card for access. _________________ scrapyards are for quitters
Wetstuff wrote: |
