1.6 diesel screech...water pump?
Docfranco
Docfranco is offline
PostPosted: Fri Sep 22, 2017 10:28 am    Post subject: 1.6 diesel screech...water pump? Reply with quote
Hi
I have a 1982 1.6 westy, it has developed a screech I can hear most in mornings and not at idle but just off idle under load then goes away after about 2500rpm (guess)
I'm guessing the water pump is on way out. I see rock auto has them for 25$
Is it worth the trouble to replace it myself? Meaning, it a simple R&r?
I do intend to source and put a 1.9td in but not ready yet....
dhaavers
dhaavers is offline
PostPosted: Fri Sep 22, 2017 10:53 am    Post subject: Re: 1.6 diesel screech...water pump? Reply with quote
Check/adjust all your belts. A loose alt belt "tends" to squeal, but a bad water pump "tends" to leak...
- Dave
"The WonderVan"
crazyvwvanman
crazyvwvanman is offline
PostPosted: Fri Sep 22, 2017 11:18 am    Post subject: Re: 1.6 diesel screech...water pump? Reply with quote
Carefully watch the alternator light on the dash when you start the engine. If the squeal doesn't begin until the light turns off then it is probably a belt that is making the noise.
Mark
Docfranco wrote:
Hi
I have a 1982 1.6 westy, it has developed a screech I can hear most in mornings and not at idle but just off idle under load then goes away after about 2500rpm (guess) .....
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Fri Sep 22, 2017 12:06 pm    Post subject: Re: 1.6 diesel screech...water pump? Reply with quote
Try loosening the belt enough to be able to spin the pulleys on the H2O pump and alternator. They both should spin fairly easily with no rough spots in the rotation. That might allow you to determine if either are the source for your belt noises
Casey--
'89 Bluestar ALH
'01 Weekender --> full camper
NEAT, no ICE.
Docfranco
PostPosted: Fri Sep 22, 2017 6:44 pm    Post subject: Re: 1.6 diesel screech...water pump? Reply with quote
Thank you. I think it’s the belt.
It’s loose, but there is only one, it appears the
Alternator is adjusted to the end of its range,
I could not find a belt size for the single belt
Arrangement..
Should I just take my belt in and get a few mm
Smaller??
Jeffrey Lee
Jeffrey Lee is offline
PostPosted: Fri Sep 22, 2017 7:11 pm    Post subject: Re: 1.6 diesel screech...water pump? Reply with quote
All diesel Vanagons used a two-belt setup, though many previous owners believed they could simplify and 'improve' upon it by using a single longer belt. The problem is that this may not provide the proper belt tension and rotational speed for both water pump and alternator. The three pulleys aren't even in the same plane of alignment without some rather hinky modifications.
I suggest you source two new correct belts (plus a couple of spares); the belt specs and more info on the topic can be found here:
https://www.thesamba.com/vw/forum/viewtopic.php?p=7301536
Good luck!
Camp Westfalia
Camping Tips • Newsletter • Cool Campervan Apparel
www.CampWestfalia.com
kaalualu
kaalualu is offline
PostPosted: Fri Sep 22, 2017 7:43 pm    Post subject: Re: 1.6 diesel screech...water pump? Reply with quote
My timing belt tensioner made some screeching when it was on its way out, be careful.
'84 Transporter 16" CLK's/LED's/ AT's/Mansi injectors
'86 Wolfey Weekender Westfalia AT's/otherwise stock
Sold-'82 TinTop Diesel
Docfranco
PostPosted: Sat Sep 23, 2017 7:34 am    Post subject: Re: 1.6 diesel screech...water pump? Reply with quote
So upon closer examination the water pump only has one pilot
So it was modified from stock.
I may just get a smaller belt and see if the will charge and not
Screech
dobryan Premium Member
dobryan is offline
PostPosted: Sat Sep 23, 2017 8:43 am    Post subject: Re: 1.6 diesel screech...water pump? Reply with quote
Can you post a couple of pics of the belt side of the engine?
Dave O
The Western Syncro build
