Intrinsic Samba Member
Joined: November 16, 2011 Posts: 266 Location: Clearwater, FL
Posted: Wed Jun 06, 2018 5:20 am Post subject: Dual Solex, installation questions |
Hello, with the dual solex carb setup, using the factory linkage, does anyone have a photo of description of the installation of the factory throttle return spring?
Also, should I wire the electric chokes for 12v power full time when the engine is on, or does this circuit run through some sort of controller to switch off the power when the temperatures are high or a time limit has been exceeded?
Thanks |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 23435 Location: Kimball, Mi
Posted: Wed Jun 06, 2018 7:36 am Post subject: Re: Dual Solex, installation questions |
Intrinsic wrote: |
Thanks |
The springs go from a hole in the bellcrank for the linkage, to the hoop in the upper cooling tin.
Chokes are powered from the coil power wire (use 1 of the multiple connectors on the coil (terminal 15)). _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
EverettB  Administrator
Joined: April 11, 2000 Posts: 71608 Location: Phoenix 602
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 6041 Location: Brooklyn
Posted: Wed Jun 06, 2018 9:28 am Post subject: Re: Dual Solex, installation questions |
Also note that the choke power is unfused, as is the entire ignition coil power circuit as originally wired by VW.
So, in other words, don't drop one of those carb linkage rods down onto the choke wire with the ignition on.  _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Posted: Thu Jun 07, 2018 12:01 pm Post subject: Re: Dual Solex, installation questions |
Thanks for all the help, this is exactly what I needed. |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13552 Location: Tejas!
gt1953 Samba Member
Joined: May 08, 2002 Posts: 13948 Location: White Mountains Arizona
Posted: Fri Jun 08, 2018 12:18 pm Post subject: Re: Dual Solex, installation questions |
Bob Notch...thanks for that link as I will be needing it. Just got delivered my new pre owned used carbs qty4, intakes qty4, linkage, and air cleaner. I will be removing the Weber center mount and have the correct carbs on the engine. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
