etrudeau Samba Member
Joined: September 19, 2018 Posts: 4 Location: Montreal
Posted: Mon Jan 27, 2020 3:46 pm Post subject: 1994 Eurovan 5 cyl with manual trans... options for engine swap |
I am green in mechanic...so I need help.
A 1994, 5 cylinders has low compression on one cylinder, not sure what cause that, but would like to know what are the main reasons...I will investigate.
The main question...if I need to rebuild the engine, should I consider an engine swap for something a bit stronger? not necessarily a VR6 but an engine with more edge... Which VW or Audi engine will fit best? Ideally I would like to stay with gas engine but open to diesel as well, (what are the advantages)
Also doing that, Will I need to upgrade brakes?
Thanks and again I am not good at mechanic, keep it simple to understand  |
Joshwa Samba Member
Joined: November 18, 2015 Posts: 823 Location: North Seattle WA
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 12160 Location: Port Manteau
Posted: Mon Jan 27, 2020 5:13 pm Post subject: Re: 1994 Eurovan 5 cyl with manual trans... options for engine swap |
I think the AEB 1.8t might be easier, since it should bolt right up to the factory European 1.9TD sump. Wouldn't a European 2.5 TDI bolt right up to the 2.4 sump and mounts? I suspect that with any of these swaps you'd want to change out the transmission gearing, as the 2.4 is probably geared pretty short. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Posted: Mon Jan 27, 2020 6:11 pm Post subject: Re: 1994 Eurovan 5 cyl with manual trans... options for engine swap |
@Joshwa
Which one do you recommend? which one is the easiest? |
Joshwa Samba Member
volkybus Samba Member
Joined: November 03, 2013 Posts: 486 Location: CASTLETON VT USA
Posted: Sun Mar 22, 2020 11:03 am Post subject: Re: 1994 Eurovan 5 cyl with manual trans... options for engine swap |
Boy , when you do this don't you lose a ton of power? Diesels are very slow compared to gas and hard to start in winter.. plus you may have emissions to deal with de
Pending where you are..plus there is lots of work and,$$ involved...I hate to be so negative but I'm I realist.. Good luck either way..Bill |
Joshwa Samba Member
Stripped66 Samba Member
Joined: May 31, 2005 Posts: 3500 Location: Charleston, SC
Posted: Mon Mar 23, 2020 9:58 am Post subject: Re: 1994 Eurovan 5 cyl with manual trans... options for engine swap |
Anybody consider the newer 2.5L VW inline 5's? They are dirt cheap, torque is similar to the VR6's, HP lands between the 12v and 24v versions of the VR6, and the 2.5L shouldn't require a change in gearing like a TDi would. IMO, the price of one of these engine, plus a stand-alone EMS, is thousands cheaper than a diesel conversion. _________________
66brm wrote: |
Bodacious wrote: |
Why not just make a custom set of wires with a Y splice in them. Then you could just run one distributor. |
I don't think electrickery works that way |
Posted: Mon Mar 23, 2020 10:29 am Post subject: Re: 1994 Eurovan 5 cyl with manual trans... options for engine swap |
I'm pretty sure the newer fives are built on an entirely different pan and bellhousing footprint, than the older Audi designed versions, but I could be wrong. They are super abundant and cheap right now _________________ Casey--
y u rune klassik? |
Posted: Mon Mar 23, 2020 12:42 pm Post subject: Re: 1994 Eurovan 5 cyl with manual trans... options for engine swap |
Zeitgeist 13 wrote: |
I'm pretty sure the newer fives are built on an entirely different pan and bellhousing footprint, than the older Audi designed versions, but I could be wrong. They are super abundant and cheap right now |
I haven't spent enough time researching the differences, as claims made online between forum users and vendors seem to vary and contradict.
I realize the 1.8t engine bolts up to the 5-cylinder EV bellhousings. [seems to be a fact]
The 07k (I-5) definitely bolts up to the 02A and 02J (1.8t/2.0) transaxles with some grinding to the bellhousing to clear the timing chain housing on the 07k engine. [edited: this is what Fabless Manufacturing specifies on their engine swap kits]
I've read multiple claims that the 07k shares the same bellhousing pattern as the 1.8t, but I haven't seen pics or dimensions to confirm/refute this. [claims]
Last but not least, I've read that the 07k also bolts up to the 01E transaxle (Audi V6) [claim], which the 1.8t also bolts up to [fact?], but the 01E requires an adapter plate to mate it to a VR6 [fact].
[edited] Quite simply, I don't know for certain. I will contact Fabless Mfg and inquire about the compatibility of the bellhousing patterns.[/edit]
Anyway, I'll quit confusing the topic until I drive my transaxle into oblivion and am forced to revisit powertrain options! _________________
66brm wrote: |
Bodacious wrote: |
Joshwa Samba Member
Posted: Mon Mar 23, 2020 2:26 pm Post subject: Re: 1994 Eurovan 5 cyl with manual trans... options for engine swap |
Stripped66 wrote: |
Anybody consider the newer 2.5L VW inline 5's? They are dirt cheap, torque is similar to the VR6's, HP lands between the 12v and 24v versions of the VR6, and the 2.5L shouldn't require a change in gearing like a TDi would. IMO, the price of one of these engine, plus a stand-alone EMS, is thousands cheaper than a diesel conversion. |
I’m curious on how it’s thousands cheaper. Most everything was bolt on for my diesel conversion. I foresee more custom work with any other engines aside from the ones I listed or the 2.5 diesel. In my opinion conversions are reasonable to cheap, if you can do them yourself, but expensive if you can’t. _________________ 93 Weekender TDI conversion (AHU)
93 MV TDI conversion (1Z)
Weekender rear cot
Late model cabin air filter on 93
Euro spec bumper install on 93 |
Posted: Mon Mar 23, 2020 7:10 pm Post subject: Re: 1994 Eurovan 5 cyl with manual trans... options for engine swap |
Joshwa wrote: |
I’m curious on how it’s thousands cheaper. Most everything was bolt on for my diesel conversion. I foresee more custom work with any other engines aside from the ones I listed or the 2.5 diesel. |
That assumption was based on the bellhousing bolt pattern, which Zeitgeist noted may not match the earlier 5-cylinder bellhousings. If it was a bolt-together affair (I'll confirm the bellhousing pattern...but even if it is a match, there is still the issue of the timing chain cover, oil pan, ancillaries, etc), you could source a used 07K and a new stand-alone EMS for less than $1200 (and even less if you sourced a used EMS, or opted to assemble a Megasquirt kit yourself).
The costs for a diesel swap? You documented over $2300 on your first swap, but you can vouch whether you could have been more frugal on that build. If I jump online and just search ALH's, I can find some sub-$1000 engines with 250K+ miles. Or, lower mileage engines for $2K+. And then swap 5th gear ratios, or R&P? Or matching engine and transmission combos for ~$5k?
Joshwa wrote: |
In my opinion conversions are reasonable to cheap, if you can do them yourself, but expensive if you can’t. |
Absolutely. And, yeah, I was looking at the higher end of what a bolt-together solution might entail on a diesel-swap. But because I don't know to what degree the 07K may be a bolt-on affair, I can't opine on the costs beyond the engine and engine management...so, I apologize for any confusion by even suggesting it! _________________
66brm wrote: |
Bodacious wrote: |
Posted: Mon Mar 23, 2020 10:01 pm Post subject: Re: 1994 Eurovan 5 cyl with manual trans... options for engine swap |
Wow, $2300 is pretty cheap for an engine swap of any kind. I think the DIY ALH swap into my Vanagon comes in around $3k, half of which was solely the cost for my manual injection pump. If I were to do it again, I think I could possibly make it happen for between $1500 and $2000.
I think an AEB 1.8t could be done for really cheap, using all the stock engine management system and wiring. How much is a T4 1.9TD install package? _________________ Casey--
y u rune klassik? |
Joshwa Samba Member
Posted: Tue Mar 24, 2020 5:56 am Post subject: Re: 1994 Eurovan 5 cyl with manual trans... options for engine swap |
Just to address my uncertainty above, Fabless Manufacturing and Kennedy Engineering documents that the 07K shares the same bellhousing pattern as the 1.8t and 2.0. So, that's the easy part.
The hard parts:
- What additional modification to the EV transaxle that is needed to clear the timing chain cover on the 07K is unknown.
- Passenger side motor mount will likely require a custom adaptation
- Ancillaries (alternator, PS pump, A/C compressor) will need to be adapted
- Air enters intake/throttle-body from driver's side
- Engine management (whether you attempt to adapt the stock ECM or start from scratch with a new EMS, assuming you have no experience with either)
Should the OP consider the 07K? Probably not.
Still, I'm interested to see whether the growing popularity of the 07K swaps eventually makes its way over to the EV. _________________
66brm wrote: |
Bodacious wrote: |
Joshwa Samba Member
Posted: Tue Mar 24, 2020 8:30 am Post subject: Re: 1994 Eurovan 5 cyl with manual trans... options for engine swap |
It makes sense that VAG made the new fiver bell footprint the same as other popular engines. I googled 07K and saw a pic of the bare block. It appears to be configured like a VR6, but in inline orientation.
The sump would also need to be modded to tilt the engine forward instead of 15 degrees backward like all the othe FWD cars. Thanks for shedding some light on this engine option. _________________ Casey--
y u rune klassik? |
Posted: Tue Mar 24, 2020 8:47 am Post subject: Re: 1994 Eurovan 5 cyl with manual trans... options for engine swap |
Indeed, I didn't mention the sump mods or Josh's list as they are the same issues with any engine swap that's not EV-specific.
I know the 1.8t swap into EV has been done before, but it also poses the same challenges as the 07K...but with an older, more expensive engine that might additionally require a new or rebuilt turbo to restore reasonable performance (bias: I've owned a 1.8t powered A4 for the past 13 years...).
Given the OP's admitted lack of of mechanical expertise, it might be wise to steer him towards Josh's diesel build thread. He may be able to assess whether he's capable of starting and finishing the least complicated of the swaps discussed. _________________
66brm wrote: |
Bodacious wrote: |
Joshwa Samba Member
Posted: Wed Mar 25, 2020 2:50 pm Post subject: Re: 1994 Eurovan 5 cyl with manual trans... options for engine swap |
This person is not mechanically solid so how about rebuilding his own engine.
Or having it done by a pro..parts r available.
Either way it's a crap shoot on used..
Just a idea
.if rebuilding your own or putting a used engine is the same price I'M d go.for the rebuild..a used engine is a used engine which may blow up in 500 miles...u really never know
..Bill in Puerto Rico 4 now
.and other used engines swaps... is not for the weak of heart..and your van may be down for months but very nice in u pull it off..
Thanks for listening to a old hippy |
