Kennedy Stage 1 Pressure Plate
mickey12
mickey12 is offline
PostPosted: Sun Jan 10, 2021 2:51 pm    Post subject: Kennedy Stage 1 Pressure Plate Reply with quote
I have a Type 1 2021cc DP engine with a Kennedy Stage 1 Pressure Plate. I want to attach it to an early style transaxle w/older throw-out-bearing. I've read a lot of conflicting information.
Can I just get an early style T/O bearing pressure ring for the Kennedy PP and slide it on?
Do I need to remove the old cross shaft and replace it with a heavy duty one, with a new style throw-out bearing?
See pressure plate and throw-out-bearing
clonebug
clonebug is offline
PostPosted: Sun Jan 10, 2021 3:10 pm    Post subject: Re: Kennedy Stage 1 Pressure Plate Reply with quote
You just need the ring that goes on the PP fingers. I'm not sure if you can buy them separately or not but you could email Kennedy and check with them.
Maybe someone on here has one they can part with.
richardcraineum wrote:
I'm so ignorant of efi I don't even know the difference between batch, sequential blah blah blah ..
cbeck wrote:
His user name in a previous life was dick head.
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936
mickey12
mickey12 is offline
PostPosted: Sun Jan 10, 2021 3:25 pm    Post subject: Re: Kennedy Stage 1 Pressure Plate Reply with quote
I think this will work from Dune Buggy Supply?
Throwout Bearing Guide Sleeve
For 1971-1979 Type 1 &
Type 2 - 113-141-181B
$3.99
modok
modok is offline
PostPosted: Sun Jan 10, 2021 3:27 pm    Post subject: Re: Kennedy Stage 1 Pressure Plate Reply with quote
no, this
http://vwparts.aircooled.net/Pressure-Plate-Collar-Early-Style-X-Shaft-p/pressure-plate-collar.htm
it is "possible" to install a late throwout bearing into the trans, but it's a PITA would not recommend.
mickey12
mickey12 is offline
PostPosted: Sun Jan 10, 2021 3:28 pm    Post subject: Re: Kennedy Stage 1 Pressure Plate Reply with quote
Forgot to say that the transaxle is on a 1968 Type 1, if that matters.
clonebug
clonebug is offline
PostPosted: Sun Jan 10, 2021 4:56 pm    Post subject: Re: Kennedy Stage 1 Pressure Plate Reply with quote
What Modok posted a link to is what you will need for your transmission.
If that is an original German throwout bearing.....it might be a little dry inside.
Gently remove the cover in back and you can repack that bearing for another long life.
Audi TT intercooler
EcuMaster PMU16
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sun Jan 10, 2021 5:10 pm    Post subject: Re: Kennedy Stage 1 Pressure Plate Reply with quote
If the casting has the 3 bosses for the mounting studs, it's just a matter of marking the location and drill/tap the holes.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
modok
modok is offline
PostPosted: Sun Jan 10, 2021 5:13 pm    Post subject: Re: Kennedy Stage 1 Pressure Plate Reply with quote
Agreed.
Tho if his trans is actually 1968 model, that's before it had the bosses.
Mr. 010
Glenn is offline
PostPosted: Sun Jan 10, 2021 5:19 pm    Post subject: Re: Kennedy Stage 1 Pressure Plate Reply with quote
modok wrote:
Agreed.
Checked his gallery, there's a picture of a swingaxle, so correct as usual King Friday.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
mickey12
mickey12 is offline
PostPosted: Sun Jan 10, 2021 6:07 pm    Post subject: Re: Kennedy Stage 1 Pressure Plate Reply with quote
thank you, thank you, thank you!!!!!!!!!
