tates1882 Samba Member
Joined: August 07, 2012 Posts: 279 Location: Southwest Idaho
Posted: Wed Aug 11, 2021 11:40 am Post subject: Transmission rebuild |
I have my transmission, 88 manual, at the rebuilder after the inspection I was quoted $4500. This included a more robust 4th gear as the only upgrade and the rest just being stock replacement parts and labor. Looks like I could buy from BD, GW or Rancho without giving them a core for under 3800. Any thoughts? _________________ 88 Vanaru, ej22, naht
dabaron Samba Member
Joined: June 21, 2018 Posts: 2725 Location: Philly, mang
Posted: Wed Aug 11, 2021 12:20 pm Post subject: Re: Transmission rebuild |
that seems rather pricey. my AT rebuild with a Peloquin and AT cooler was 800 less than that! _________________ 1991 Vanagon GL Camper
i had no idea i wanted to be a mechanic |
dobryan Samba Member
Joined: March 24, 2006 Posts: 17194 Location: Brookeville, MD
bobbyblack  Samba Member
Joined: May 21, 2015 Posts: 4627 Location: United States, Iowa
Posted: Wed Aug 11, 2021 12:37 pm Post subject: Re: Transmission rebuild |
Ask Mr Gas in Colorado the same question... I've had a few chats with them, seem to be good. Another good ref was for Arizona Trasaxle. _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Joined: January 01, 2007 Posts: 17871 Location: sticksville, ct.
Posted: Wed Aug 11, 2021 4:10 pm Post subject: Re: Transmission rebuild |
i'm pretty close friends with Matt Steedle so i can tell you what he's told me...
parts prices have shot up and there are major shortages. he can't even get the same rebuild stuff he used in my auto trans back in december.
unless you find a shop that has inventory and didn't do a price increase on what they have....expect to pay more.
Matt told me in just the few months since he did mine the price went up 500 bux.
welcome to the 'new normal' _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 10246 Location: Mt Lemmon, AZ
Posted: Wed Aug 11, 2021 5:17 pm Post subject: Re: Transmission rebuild |
bobbyblack wrote: |
...Another good ref was for Arizona Trasaxle. |
Mine came from Arizona Transaxle in May, 2020.
I had to buy a core outright (an extra $650 -- UPS lost the core I was sending them) and I picked up a few extras (Weddle .82 4th, oil splash plates) and also got the clutch kit through them.
Total was under $3000.
Bill is the guy to talk to -- Arizona Transaxle Exchange 602-269-1444 |
Vanagon Nut Samba Member
Joined: February 08, 2008 Posts: 10497 Location: Sunshine Coast B.C.
Posted: Wed Aug 11, 2021 7:32 pm Post subject: Re: Transmission rebuild |
https://aatransaxle.com _________________ 1981 Westy DIY 15º ABA
(VW Gas I4)
1988 Westy DIY 50º ABA
VE7TBN |
Howesight Samba Member
Joined: July 02, 2008 Posts: 3410 Location: Vancouver, B.C.
Posted: Wed Aug 11, 2021 8:18 pm Post subject: Re: Transmission rebuild |
tates1882 wrote: |
I have my transmission, 88 manual, at the rebuilder after the inspection I was quoted $4500. This included a more robust 4th gear as the only upgrade and the rest just being stock replacement parts and labor. Looks like I could buy from BD, GW or Rancho without giving them a core for under 3800. Any thoughts? |
If the "more robust 4th gear" is the one from Guard Transaxle, then that may explain the price since Paul Guard's transaxle parts are simply the highest quality available. You won't destroy that GT 4th gear in your lifetime with a 2.2 EJ. Also, as Skills says above, OEM parts are becoming very scarce. The only real fair price comparison is to separate out labour cost from parts cost. _________________ '86 Syncro Westy SVX |
Posted: Wed Aug 11, 2021 9:04 pm Post subject: Re: Transmission rebuild |
Thanks for the feedback, Yes GT gears for 4th. Probably going to go a different route than the current rebuilder. $1700 plus parts and core, 560 per each GT gear. So, my core is costing me 2206. Basically it sounds like the entire thing is junk: R&P while not "damaged" is not recommended to be reused, 2nd gear toast, 4th toast, 1-2 & 3-4 sliders need sleeves, gear carrier needs sleeved, case needs sleeved, main shaft not recommend to be reused. I have access to another core but there is no saying its any better, costs 400 so not sure I wanna gamble on it.
Given that my carrier and case are super sloppy that could explain why the axles have been "grinding" the plastic caps out at the output flange. _________________ 88 Vanaru, ej22, naht |
