zoti Samba Member
Joined: December 26, 2007 Posts: 2163 Location: Plano, TX USA
Posted: Sun Jun 19, 2022 7:05 pm Post subject: 88 Westfalia suspension rebuild |
Lots of pictures. Doing every bushing and ball joint. Everything is original to the van and most is in really good condition for the age.
zoti Samba Member
Posted: Sun Jun 19, 2022 7:09 pm Post subject: Re: 88 Westfalia suspension rebuild |
zoti Samba Member
Posted: Sun Jun 19, 2022 7:14 pm Post subject: Re: 88 Westfalia suspension rebuild |
zoti Samba Member
Posted: Sun Jun 19, 2022 7:15 pm Post subject: Re: 88 Westfalia suspension rebuild |
zoti Samba Member
Posted: Sun Jun 19, 2022 7:17 pm Post subject: Re: 88 Westfalia suspension rebuild |
VicVan Samba Member
Joined: July 01, 2015 Posts: 1987 Location: Vancouver Island, BC
Posted: Sun Jun 19, 2022 8:27 pm Post subject: Re: 88 Westfalia suspension rebuild |
Nice !
What paint did you use? What springs, what shocks?
Have fun installing the new parts! _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
zoti Samba Member
Posted: Sun Jun 19, 2022 8:34 pm Post subject: Re: 88 Westfalia suspension rebuild |
| VicVan wrote: |
Nice !
Have fun installing the new parts! |
I used POR 15 on the parts. The springs and stabilizer bar I just sprayed with rust oleum.
Don't remember the name of the shocks. I just went standard. I didn't replace the springs. They look good. My van sits high.
I also have 4 new tires that will be installed. |
Robsmaze Samba Member
Posted: Sun Jun 19, 2022 8:54 pm Post subject: Re: 88 Westfalia suspension rebuild |
I spent Saturday (9am to 7pm) doing the radius arm and sway bar bushings and it felt like a massive endeavor. I’m so impressed with the scope of this suspension rebuild. Mighty fine work. _________________ ‘87 2WD 2.1L Westy
‘87 2WD 1.7L Diesel Doka (euro spec) |
zoti Samba Member
Posted: Sun Jun 19, 2022 9:20 pm Post subject: Re: 88 Westfalia suspension rebuild |
| Robsmaze wrote: |
| I spent Saturday (9am to 7pm) doing the radius arm and sway bar bushings and it felt like a massive endeavor. I’m so impressed with the scope of this suspension rebuild. Mighty fine work. |
Why was it so hard?
I had to really clean the rod and heat up the control arm to unscrew it but other than that it was not a biggie. |
Posted: Sun Jun 19, 2022 9:29 pm Post subject: Re: 88 Westfalia suspension rebuild |
About 3 hours were spent getting the radius rods loose. Heat, penetrant, heat, penetrant. Some bad experiences with breaking bolts has gotten me cautious. I finally just stood on the 27mm wrench on the passenger side and it came loose. My van also has this wonderful rubbery, tarish underbody coating that was done sloppily 30 years ago, so several hours were spent cleaning with a wire brush and repainting everything. Then, I overlubed the drop link bushings and had a hell of a time getting them on the sway bar. Finally a team effort of my girlfriend using a quick clamp while I held it in place popped them both on in 3 minutes, after I tried to do it myself for an hour and a half. There is a lesson there about asking for help that I’m sure I didn’t learn.
And (despite warnings) I got bushing lube in my hair. had to wash it twice - lol.
I still have the upper and lower control arm bushings to do in a couple weekends. We’ll see if that goes more smoothly! _________________ ‘87 2WD 2.1L Westy
1988M5 Samba Member
Joined: January 23, 2016 Posts: 848 Location: Tucson, AZ
Posted: Sun Jun 19, 2022 10:59 pm Post subject: Re: 88 Westfalia suspension rebuild |
Great documentation Zodi. Simple photo progress of tackling a large job is inspiration for others to "just do it". And don't you just love that refreshing feeling when it's all buttoned up and the work is behind you? Giant "to-do list" check mark with pride!
Cheers,
BK _________________ 1991 tin top GL
Some BMWs. |
WestiT3_1986 Samba Member
Posted: Mon Jun 20, 2022 3:34 am Post subject: Re: 88 Westfalia suspension rebuild |
| Very nice job! May I ask, what kind of de-ruster you used on the lower controlarms? Seems like a jelly consistence? |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32988 Location: Reading Pennsylvania
zoti Samba Member
Posted: Mon Jun 20, 2022 10:01 am Post subject: Re: 88 Westfalia suspension rebuild |
| WestiT3_1986 wrote: |
It's a POR15 kit. Has a degreaser, metal etcher and then the paint itself. |
zoti Samba Member
Posted: Mon Jun 20, 2022 10:03 am Post subject: Re: 88 Westfalia suspension rebuild |
When I cut the bolt of the pass side lower control arm it messed up the mount so this morning I used my crappy welder to fill it and sand, fill and sand until I was happy enough with it.
I'm not a welder but this is good enough for me.
zoti Samba Member
Posted: Sat Jun 25, 2022 7:45 pm Post subject: Re: 88 Westfalia suspension rebuild |
Finishing the front
zoti Samba Member
Posted: Sat Jun 25, 2022 7:46 pm Post subject: Re: 88 Westfalia suspension rebuild |
And start driver rear
zoti Samba Member
Posted: Mon Jun 27, 2022 2:40 pm Post subject: Re: 88 Westfalia suspension rebuild |
I thought I was being smart trying to use a condom to prevent the brake build from draining. Apparently, brake fluid is not a good lube. The condom broke from the fumes. lol. Ended up putting a plastic bag and rubber bands.
zoti Samba Member
Posted: Tue Jun 28, 2022 1:46 pm Post subject: Re: 88 Westfalia suspension rebuild |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 5902 Location: Bemidji, MN
Posted: Tue Jun 28, 2022 5:52 pm Post subject: Re: 88 Westfalia suspension rebuild |
thanks for all the documentation! great help! _________________ -dan
www.thefixitworkshop.com |
