deadwesty Samba Member
Posted: Sat Feb 10, 2024 6:04 pm Post subject: CA DMV VIN verification question |
An out of state titled westy that had its door jamb vin tag painted over.
We can see chassis stamped vin number, but it had the usual three numbers with āZā instead. Can it be used as the second vin for verification?
It also has the sticker under fuse box for paint code, etc. it shows full vin number on it. Will DMV accept that too?
Appreciate any in put. Thanks! _________________ Instagram- @vwwanderers
1986 westy syncro
1990 tin top syncro |
jimf909 Samba Member
Posted: Sat Feb 10, 2024 6:57 pm Post subject: Re: CA DMV vin verification question |
I'm not sure if your question can be answered by looking at CA DMV VIN verification documents but these may be helpful:
VIN verification form
https://www.dmv.ca.gov/portal/file/verification-of-vehicle-reg-31-pdf/
Vehicle Verifier License Handbook: see page six for VIN identification which allows for: MFR label (for some imports) and Equipment List Label.
https://www.dmv.ca.gov/portal/file/vehicle-verifier-license-handbook-ol-301-pdf/
1.165 Vehicle Verification
https://www.dmv.ca.gov/portal/handbook/vehicle-ind...fications/
You may want to know these rules in case your verifier is not clear on them.
From my remarkably uneducated POV it looks like an untampered windshield VIN plus the sticker under the dash will have you covered. Free advice is worth what was paid for it.  _________________ - Jim
Butcher wrote: |
This is the main fault with DIY'ers, they get together on these forums and pat themselves on their backs spreading bad information. |
Guilty as charged.
termuehlen  Samba Member
Joined: May 02, 2012 Posts: 1027 Location: Redwood City
Posted: Sat Feb 10, 2024 8:57 pm Post subject: Re: CA DMV vin verification question |
In late 2020 when Covid was in full swing, I was looking for some way to get a VIN verification for a vehicle. I contacted http://www.verifyyourvehicle.com/ and spoke with Don Pierson, who was super helpful. At the time, he said "A licensed VIN verifier requires all the stickers in place and readable to be able to verify any vehicle for titling in California." I would suggest that you give him a call or email and provide your specifics. I'm sure it won't be the first time that a VIN sticker has been painted over. _________________ 1988 Westfalia automatic Subaru OBD1
1986 syncro tintop wbx |
hopkin  Samba Member
Joined: June 25, 2012 Posts: 2542 Location: Ottawa, Ontario
Posted: Sun Feb 11, 2024 5:55 am Post subject: Re: CA DMV VIN verification question |
deadwesty wrote: |
Appreciate any in put. Thanks! |
Three "Z's" ins positions 4,5,6 of the VIN indicate a non-North American VIN has been assigned.
The configuration of the 17 digit VIN is/was different between North America and Canada and the rest of the world.
For example this chart shows VIN's assigned to Mexican built Beetles from 1993-2004.
Note the 3 "Z" used from 1993-1996 and then the switch to an NA compliant VIN in 1997. Also note that digit 9 in a North American VIN is a check digit while (in the case of this chart) it was set to '3' from 1993-1996, which is not a check digit.
The wikipedia page on VINs has more info ...
https://en.wikipedia.org/wiki/Vehicle_identification_number
_________________ 1971 Super Beetle (past)
1974 SunBug (past)
1972 914 (past)
1991 Honda Civic (Original Owner)
1996 'Open Air' Mexican Beetle (current)
2015 Golf (past)
2017 Dune Edition (daughter's car) |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32983 Location: Reading Pennsylvania
kamzcab86 Samba Moderator
Posted: Sun Feb 11, 2024 10:38 am Post subject: Re: CA DMV VIN verification question |
hopkin wrote: |
Three "Z's" ins positions 4,5,6 of the VIN indicate a non-North American VIN has been assigned. |
VINs outside North America, and the VINs found stamped into the chassis of all 1981-1993 (or later) North American Volkswagens, contain four "Z"s. For North American VWs, these are merely filler digits. The chassis VINs were standard issue as the vehicles rolled off the initial phase of the assembly line; the only difference between these standard-issue model-year VINs is the sequential production number. Locations outside of the USA & Canada do not require the same VIN information and, therefore, use filler digits during stamping to make the initial assembly process easier and faster.
_________________ ~Kamz
2016 Golf GTI S
