Wires??!! 67 beetle
Broke67beetle
Broke67beetle is offline
PostPosted: Fri Jul 18, 2025 4:10 pm    Post subject: Wires??!! 67 beetle Reply with quote
So I have my car at the mechanic shop
Just looking over some of the stuff they did ? I was hoping to be able to put this spair tire back( hopes of one day having the original wiper, sprayer.(pissers)work even if it's just temp) and there is a whole bunch of wires, and they put the horns down on the inside?
I don't remember that being there.
Can someone tell me where it's supposed to run? Or maybe I just didn't notice it before
At least they left the broken pieces. Can you see that spade bit? I'm not sure if I can. Weld it back on? I guess I do need a new fuse box( lol)
I really don't think those wires were there before
The bottom terminal when I purchased the car Had a wire running directly from the battery
I had jumpered a wire to a terminal that was constant hot on the fuse panel
They told me it was necessary to remove that ?
What does it do? Is it important car starts without it.
rcooled
rcooled is offline
PostPosted: Fri Jul 18, 2025 4:23 pm    Post subject: Re: Wires??!! 67 beetle Reply with quote
Broke67beetle wrote:
...and they put the horns down on the inside? I don't remember that being there. Can someone tell me where it's supposed to run?
The single horn should live behind this grill in the left-front fender.
I guess I do need a new fuse box...
You guessed right Shocked
'63 Ragtop (current)
'65 Ghia coupe (totaled)
'69.5 Ghia convertible and
Broke67beetle
PostPosted: Fri Jul 18, 2025 6:43 pm    Post subject: Re: Wires??!! 67 beetle Reply with quote
Yeah, I got the horns moved, there were some old brackets.
But how do the wires run? I just did this temporarily, just to make sure they'd actually still work.
Does your main wire harness for the headlights and turn signals run along the inside of the trunk, by the hood release
Broke67beetle
PostPosted: Sat Jul 19, 2025 6:59 am    Post subject: Re: Wires??!! 67 beetle Reply with quote
So this thread. Is because my previous thread was basically just relating to alternator issues. but kind of are still relevant
https://www.thesamba.com/vw/forum/viewtopic.php?t=803771&highlight=
i plan on asking questions about the things I don't understand about the wiring to try and figure out where things went wrong after I got it back from the mechanic.
But I'm gonna Post pictures things and go over the entire car pretty much is the goal.
Please chime in if you see something that stands out, that could be my issue.
I'm gonna run all the tests from the previous post again.
****But if anyone knows please ****
super confused about on my Ignition switch.(back side of the key)
The very bottom pin. I think terminal 30. It's not connected to anything.
Is that important?? What is it suppose to connect to
runamoc Premium Member
runamoc is offline
PostPosted: Sat Jul 19, 2025 8:13 am    Post subject: Re: Wires??!! 67 beetle Reply with quote
Those two tabs are connected. 'always hot' is #30 wire. Depends on where the other #30 wires goes/comes from.
Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs- '80 Rabbit Diesel
VW Wiring = It's just wires
Broke67beetle
PostPosted: Sat Jul 19, 2025 9:18 am    Post subject: Re: Wires??!! 67 beetle Reply with quote
So the 30 is the wire not the terminal
VW_Jimbo Premium Member
VW_Jimbo is offline
PostPosted: Sat Jul 19, 2025 11:22 am    Post subject: Re: Wires??!! 67 beetle Reply with quote
30 is the circuit throughout the car. It denotes battery voltage positive.
Here is the wire diagram from the Technical Section.
The horn is H3
The horn switch is H1
Jimbo
TDCTDI wrote:
67rustavenger wrote:
ashman40
ashman40 is offline
PostPosted: Sat Jul 19, 2025 12:31 pm    Post subject: Re: Wires??!! 67 beetle Reply with quote
Just want to clear up your objective with your horn and ignition switch? Are you just trying to go back to stock wiring or just trying to get them working?
Horn: The black/yellow wire from the fuse box powers the horn. It runs directly from the fuse box to the horn (+) terminal. The black/yellow wire runs along side the brake switch wires (black/red) usually within a shared sleeve. Follow these wires from the fuse box down the left side of the fuel tank. I'm not certain the path in '67 but I believe both sets of wires run thru the grommet at the upper left (upper right as viewed from the front of the car into the trunk) and pass from the trunk space down into the space below the fuel tank. You can see the grommet and wires at the upper right corner of the fuel tank in this pic.
From here the wires run to the brake MC and to the horn.
I believe there is also a cut/tab in the inner left fender well where the horn wire passes on its way to the horn. This keeps it from flopping around. I would recommend adding a sleeve to the wire as it passes thru the slot.
The second wire to the horn runs from the horn (-) terminal back up into the trunk space and ends at the horn button/ring.
Ignition switch: The stock ignition switch wiring has a thick red wire running from the headlight switch #30 terminal to the #30 terminal of the ignition switch. This #30 wire is the power source to the ignition switch. On '70-earlier Beetles, the power from the battery stops first at the headlight switch in the trunk. The headlight is the distribution point for all battery constant power in the trunk space. From the headlight switch the power branches to the fuse box and the ignition switch.
The #50 and #15 terminals on the ignition switch are the outputs. #15 wire runs back to the fuse box to power a pair of fuses as well as continue on to power the ignition coil (unprotected by a fuse). #50 runs to the starter solenoid, also unprotected by a fuse.
I can understand why the PO might want to run power over a separate line from the battery straight to the ignition switch. It reduces the burden on the single stock red #30 wire that carries ALL the load. This second wire directly to the ignition switch means the load for all electrical devices is split over two power sources.
No matter whether you are getting your ignition switch power from the headlight switch (stock) or a dedicated wire from the battery (not stock) I cannot see how the ignition is able to power the fuses or the starter solenoid without a #30 wire connected.
You mention accessory position on your ignition switch description. The stock ignition switch only had 3 positions: OFF, ON/RUN and START. The START position is spring loaded and when turned to this position the starter motor cranks the engine. The ON/RUN position is where everything is powered. On most cars the ACC (accessory) position is where the only the radio and less critical systems are powered. VW Beetle ignition switches don't have an ACC position. Are you running a stock ignition switch and nothing else? If you are able to crank the starter with the ignition switch without the #30 wire connected you have something wired wrong. Confirm where the other wires (#15 and #50) run.
AshMan40
Broke67beetle
PostPosted: Sat Jul 19, 2025 1:00 pm    Post subject: Re: Wires??!! 67 beetle Reply with quote
I guess the main thing would be stopping any parasitic draw
Stock would be nice it would make it easier to follow the wiring diagram.
But the main goal is working
And not overloading any other systems
Sorry, I'm not very good with terminology. I always thought accessory was, on But not running
I was just redoing the horn wires
Since I don't know how they did it at the mechanic shop
I just made some pieces that connect to the wiring the mechanic did
I ran them out where the headlight wires go out
I am pretty happy with it still needs some tucking
This last one I forgot to put the shrink tubing on, and now I can't get it apart on the back end. But other than that, I'm gonna try and tuck them inside the wiring harness, but I have another wire harness cover if it doesn't fit, I can just put over the outside.
Edit
Wires tucked
Rust prevention applied
Ready for spare
Broke67beetle
PostPosted: Sat Jul 19, 2025 1:13 pm    Post subject: Re: Wires??!! 67 beetle Reply with quote
Oh my God, your car is beautiful.
I knew the wires didn't run around by the hood Release. I can't understand why they moved them.
Thank you for the image. Yeah, I'm probably not gonna be able to get the wires Back to stock without a whole new wiring harness
Broke67beetle
PostPosted: Sat Jul 19, 2025 5:46 pm    Post subject: Re: Wires??!! 67 beetle Reply with quote
The horn is H3
Thanks for the diagram
The numbers that are on the wires. What do they indicate?
Say we are looking at the horn. H3 the wires have a 1.0 on them
Or if we are looking at d the (ignition switch.?) Would the 15/30/50 (would be the pins?)
and the 1.5/2.5/4.0 (???)
Sorry its probably a really dumb question
slayer61
slayer61 is offline
PostPosted: Sat Jul 19, 2025 7:08 pm    Post subject: Re: Wires??!! 67 beetle Reply with quote
The 1.5, 2.5 etc is the size of the wire in millimeters Very Happy
Cusser wrote:
... Most folks are idiots when it deals with electrical !!!
3/4 race cam? What's missing, one of the lobes? Shocked
Paul
'68 Manx clone... Sears??
RLR/Strange brakes
2276 built on AS21 case
W-125 w/ GB 1.25:1 rockers
Mahle forged pistons
CB 4340 crank
CB H beam rods
deep sump
45 DCOE
RAD 3071 Turbo
EMPI GTV 2 STG II wedge ports
MSD Box and distributor
Car Craft turbo header
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger Facebook Twitter Instagram Gallery Classifieds Feedback
aquifer Premium Member
aquifer is offline
PostPosted: Sat Jul 19, 2025 8:26 pm    Post subject: Re: Wires??!! 67 beetle Reply with quote
Here is a chart to convert metric wire size to AWG. As slayer61 said, those little numbers are the metric size of the wire. They dont’ always match up perfectly, for example where the wiring diagram calls for 1.0, I use 18 AWG.
I made this chart for myself as a guide. I’m pretty sure it’s accurate, but you never know about what you find online these days!
Project vehicles:
1967 Beetle #1. Bought in 2024, mostly original, October 1966 build date.
1967 Beetle #2. Bought in the mid 80's, restored myself in the late 90's, June 1967 build date.
1998 Jaguar XJR. Bought in 2015, rust free AZ car, refurbished myself. Driven in nice weather.
Parts needed:
Front & rear NOS or used OEM door panels for a '67 in the original Gazelle color (dark tan/light brown).
Broke67beetle
PostPosted: Sun Jul 20, 2025 3:55 am    Post subject: Re: Wires??!! 67 beetle Reply with quote
Thank you that is really helpful
aquifer slayer61 i was thinking wire gage but definitely not metric
So if am reading the diagram correctly
D is the ignition switch 50 is the bottom circuit, which runs to the starter? That means it is only a single pin
There should not be 2
So it probably has an adapter on it which i can remove ?
Why would previous owner have had that ran to the battery
Is their any reason to leave that or connect it to something
Broke67beetle
PostPosted: Sun Jul 20, 2025 4:35 am    Post subject: Re: Wires??!! 67 beetle Reply with quote
Yep
Red wire goes to harness (battery?)
Green wire goes to the switch behind the wiper motor (f?)
That looks right
***edit*** picture is wrong green is headlight Switch red is battery.
Numbers are incorrect circuits. They should be reversed.
trying to reconnect, D 50 i now know why they added the extra connector, if it was just a little longer
aquifer is offline
PostPosted: Sun Jul 20, 2025 4:39 am    Post subject: Re: Wires??!! 67 beetle Reply with quote
From the factory there was only one wire there, and my 67 has only one terminal. No particular reason to try and remove the extra terminal because it doesn’t go to anything and therefore is not the source of your parasitic draw. Maybe someone had wired in a stereo or amplifier at some point in the car’s life and T’d off that terminal for the power.
The real issue is that it almost looks like the wires at your 50 and 30 terminals are reversed. 30 should be a wire coming down from the light switch. 50 should be going back to the starter solenoid. I can’t really tell from the picture, but you should look at that closer.
Make sure you visually see which terminal is labeled 50 and 30, don’t just go by the wiring diagram as to which is the top and bottom terminal. Looks like there was paint overspray on the switch so it might be hard to see. But you need to be sure you can see the labels at the terminals in case the ignition switch is aftermarket or something. Don’t assume anything.
On my 67, the “bottom” terminal is 30 and it comes from the light switch. The other one is 50 and runs back to the starter solenoid. The third one (black wire) goes over to the fuse box and is hot when the key is turned on.
Project vehicles:
Parts needed:
Broke67beetle
PostPosted: Sun Jul 20, 2025 5:54 am    Post subject: Re: Wires??!! 67 beetle Reply with quote
Ok I will check for # on the back of ignition switch I think I see a circle off to the left of the bottom pin hopefully it says 50
if it says 30 i should switch them right?
(maybe clean with q-tip and acetone? )
*** edit.***
Guess that circle was the vw symbol lol
numbers are off to the right of the pins(?)
So i'm seeing it's a 30 at the bottom and the 50 at the top left
So that would means (when looking at my previous picture.)The red wire should go to the bottom and the green wire should go top Left.????
Broke67beetle
PostPosted: Sun Jul 20, 2025 6:44 am    Post subject: Re: Wires??!! 67 beetle Reply with quote
***edit ***
No
****Edit ****
I think this is right
Broke67beetle
PostPosted: Sun Jul 20, 2025 12:05 pm    Post subject: Re: Wires??!! 67 beetle Reply with quote
Looking at the diagram assuming what I can't see is correct.
Everything should be fine
I just can't understand why sometimes the generator light doesn't come on with the key in the on position and the engine not turned over
KTPhil Premium Member
KTPhil is offline
PostPosted: Mon Jul 21, 2025 8:13 am    Post subject: Re: Wires??!! 67 beetle Reply with quote
Barney should never have been allowed to own a Beetle, much less paint it.
Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback
