70bus  Samba Member
Posted: Mon Feb 24, 2025 9:39 pm Post subject: Re: The Lazy person's stupid Split Bus questions thread |
Any TRUCK owners remove their gas sender without removing the gas tank? Just making sure before I unbolt the divider panels and crawl in there that I won't be blocked by 1/4" or something annoying. _________________ Craig K
70 Neunsitzer
65 Pritschenwagen
Raul the 65 singlecab
Karl the 70 nine-seater |
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4777 Location: St Charles, MO
Posted: Tue Feb 25, 2025 8:57 am Post subject: Re: The Lazy person's stupid Split Bus questions thread |
Almost a decade ago I just removed the fuel tank on my '59 D-Cab (which of course does not have a fuel gauge or sender). It wasn't that hard to do. I doubt that you can remove the sender in yours straight upwards without cutting a hole in your load bed. Drain the tank, remove the fuel outlet/drain assembly with filter sock, and un-strap the tank. Maybe you could rotate the tank enough to get to the fuel sender, loosen and remove it, but your neck and back will be broken by then from all the contortion-ism. Probably easier to continue to remove the tank! Pull the tank towards the driver side, and rotate the empty tank about 90 degrees as you manouver it out through the vertical rectangular opening on the driver side into your S.C. treasure chest area (or under rear seat stowage area on a D.C.) and then outside.
Have a new fuel "sock" with fresh red gaskets, and the thick spongy foam gasket between the tank bottom and the chassis on-hand as you'll probably want to replace them all while you have the tank rotated or removed.
EDIT: I thought that I had this process documented fairly well in my huge build thread on that '59 Double Cab Pick-up, so I looked and found it; Click here to see how I re-installed the tank (you'll just use the procedure in reverse to remove your tank:
https://www.thesamba.com/vw/forum/viewtopic.php?t=...;start=300
Click here to view the whole build thread:
https://www.thesamba.com/vw/forum/viewtopic.php?t=545000
Say hi to Raul for me...
Bill Bowman _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
70bus  Samba Member
Posted: Tue Feb 25, 2025 6:39 pm Post subject: Re: The Lazy person's stupid Split Bus questions thread |
thanks Bll - Raul has a full belly right now, so I'll have to drive him a bit before I drain. The replacement sender better work is all I gotta say! _________________ Craig K
70 Neunsitzer
65 Pritschenwagen
70bus  Samba Member
Posted: Sun Jun 08, 2025 9:26 pm Post subject: Re: The Lazy person's stupid Split Bus questions thread |
For the record - a truck owner can easily remove a sender fom the tank without effort or removals (aside from divider panels if you have them). PLENTY of room.
Also, that gas smell you've been having? Never use an orange seal! This is one year old.
70 Neunsitzer
65 Pritschenwagen
Malokin Martin Samba Member
Posted: Sun Jun 08, 2025 10:32 pm Post subject: Re: The Lazy person's stupid Split Bus questions thread |
On the early piano hinge rear hatch, why do they have a second “up” position?
I get the idea of having options, but I just don’t see how I would ever use the the “insane all the way open pointing at the sky” position |
Posted: Tue Jun 10, 2025 9:02 am Post subject: Re: The Lazy person's stupid Split Bus questions thread |
All the way up position - speed brake?
Bill _________________ I'm looking for these license plate frames for my fleet:
Clara  Samba Member
Posted: Tue Jun 10, 2025 1:00 pm Post subject: Re: The Lazy person's stupid Split Bus questions thread |
Malokin Martin wrote: |
tall people (such as Greg) like the higher position. _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
EverettB  Administrator
Joined: April 11, 2000 Posts: 71568 Location: Phoenix 602
Posted: Tue Jun 10, 2025 2:58 pm Post subject: Re: The Lazy person's stupid Split Bus questions thread |
Clara wrote: |
tall people (such as Greg) like the higher position. |
I was thinking it's a tall vs short person thing too.
Unless it's for clearance while loading stuff through the hatch but I can't see the height mattering much. _________________ How to Post Photos
70bus  Samba Member
Posted: Thu Jul 03, 2025 6:34 pm Post subject: Re: The Lazy person's stupid Split Bus questions thread |
Gloss level on a truck's L41 black steering column? I have satin and gloss rattlecan epoxy; gloss seems too much and satin seems not enough :P. They were handed me by a guy who has restored VWs, and he recommends the satin. Or spray the gloss a little dry, but I know that's a skill to get it just right.
Thoughts? _________________ Craig K
70 Neunsitzer
65 Pritschenwagen
Who.Me? Samba Member
Joined: July 14, 2014 Posts: 2541 Location: UK (South)
Posted: Sun Jul 06, 2025 9:36 am Post subject: Re: The Lazy person's stupid Split Bus questions thread |
Radio question about the older, valve two-part Blaupunkt radios that have a reciever which mounts to the dash, and a separate transformer/amplifier 'power pack'...
How does the power pack mount in a bus application?
Pictures in the installation manuals for those two-part radios in the Technical section all seem to show Beetle installations. https://www.thesamba.com/vw/archives/manuals/radios.php _________________ Andy
Looking for info on my truck's history. Are you from Campbell California or nearby. Do you recognise it? ... http://www.thesamba.com/vw/forum/viewtopic.php?t=636786 |
BarryL  Samba Member
Joined: November 01, 2004 Posts: 15253 Location: Casa de Oro, California
Posted: Sun Jul 06, 2025 6:15 pm Post subject: Re: The Lazy person's stupid Split Bus questions thread |
Like this up and behind.
As you know the amp is on swiveling brackets. |
Posted: Mon Jul 07, 2025 2:05 am Post subject: Re: The Lazy person's stupid Split Bus questions thread |
BarryL wrote: |
Great. Thanks.  _________________ Andy
