What did you do to your Bug Today?
Page: Previous  1, 2, 3, ... 458, 459, 460  Next
Paul D
Paul D is offline
PostPosted: Sat Aug 23, 2008 12:00 pm    Post subject: Re: What you do to your Bug Today? Reply with quote
train99 wrote:
I like reading the What did you do to your bus today thread and think we bug owners need a similar thread so I'm starting one.
I moved it out of the way so I could work on my Bus! Smile
76 Fuel Injected Standard Bug
KantDriveFast wrote:
As cool as it is to find old VWs that have been sitting since the '70s, most of these are cut up (buses especially) and smell like weed and feet. Sad
JHZMAN
JHZMAN is offline
PostPosted: Sat Aug 23, 2008 3:09 pm    Post subject: Reply with quote
Sanded the front fenders and hood. Adjusted the steering a wee bit and ordered the steering dampener from the local VW Shop. I try to do a little every day, so by the end of the week I can see something acomplished. All this besides painting the 69 firebird and prepping a 48 Anglia for paint for a friend. Not a bad Saturdays work.
CATCH THE MAGIC, WHEREVER THE WIND BLOWS.
OLD FOGGIE
04 SILVERADO
73 STANDARD BEETLE
33 CHEVY SEDAN
69 FIREBIRD 400
31 FORD SEDAN
29 FORD ROADSTER
68 CAMARO
70 FORD 302 MUSTANG
scotty-o
scotty-o is offline
PostPosted: Sat Aug 23, 2008 3:13 pm    Post subject: Reply with quote
Fixed my right tail light. Bulb not grounding to socket.
Di-electric grease to the rescue!!
-Scotty
'72 std
volksbugusa
volksbugusa is offline
PostPosted: Sat Aug 23, 2008 3:17 pm    Post subject: Reply with quote
today
installed tranny,drive shafts,new rear shocks,snubbers...
volksbugusa,
Matthew E D'Azzo
volksbugusa
https://www.facebook.com/groups/506947294919060
mnussbau
mnussbau is offline
PostPosted: Sat Aug 23, 2008 3:25 pm    Post subject: Reply with quote
I replaced the accelerator pump linkage on the sedan's 34pict3 carb with a spare I had to try to fix the stumble...old linkage was bad and barely did anything. Then I adjusted the mixture and bypass screws. After that it ran much better! For grins I checked manifold vacuum, getting 16-17" at idle. Oh, and I put on a new oil pressure switch, the old one was flaky.
Mike
‘74 bug vert
Parts...
Shipwreck
Shipwreck is offline
PostPosted: Sat Aug 23, 2008 4:12 pm    Post subject: Reply with quote
I changed the fuel sending unit and installed a new glovebox latch.
bon2198
bon2198 is offline
PostPosted: Sat Aug 23, 2008 4:18 pm    Post subject: Reply with quote
I checked the oil and got ready for a cruise. then it started pouring rain!!!!! damn tampa weather!!!! so i opened the new weather stripping and made sure the correct one came. it is!!! hopefully tomorrow will be a nice day, even though i have to work.
1970 VW Beetle 1776cc MOFOCO w/hydraulic lifters, 042 heads and dual dellorto's
"It's better to be hated for what you are than loved for what you are not"
At the end of the day it's YOUR car so do what YOU want to it.
deluxekombi67
deluxekombi67 is offline
PostPosted: Sat Aug 23, 2008 4:50 pm    Post subject: Reply with quote
i washed the windows...lots of rain lately they were very nasty
67 bugs are only days away from being a Fat Chick!
OG 1973 standard with factory OG PAINT Porsche phone dial rims with hand painted crests
Hell yea i LOVE the Mullholland look and im from Florida so what? Smile
Hophead
Hophead is offline
PostPosted: Sat Aug 23, 2008 9:43 pm    Post subject: Reply with quote
Yesterday I drove up to Redding (70 mi) to drop off my crank/flywheel/clutch etc. to get balanced for my 2110cc. I am having the same guy hone My AA 90.5 open so I have .0045"clearence.
Today I finished wiping down the chassis with lacquer thinner so tomorrow I can tack rag it anfd shoot a few more coats of high build surfacer on it tomorrow.
I just finished an excellent NY steak dinner at home with some Russian River Damnation belgian ale. I have a good buzz going so I will switch back to Sierra Nevada Pale Ale and go out into the garage and take a dremel to My AL case to smooth out all the stress risers from the factory clearencing. I will have the olympics on in the backround. The Aussies just stole the gold from Chinese in mens diving.
70' Beetle Pan off Resto
2110cc
82 X 90.5
P&P 043 40x35.5
9.6-1 comp
FK-8
48 IDA
DCMR2
DCMR2 is offline
PostPosted: Sat Aug 23, 2008 9:57 pm    Post subject: Reply with quote
I took the steering column apart trying to find the source of my turn signal problem. Found a damaged wire that goes to the flasher and repaired it. Still blowing #1 fuse and no turn signals. Checked the point gap. Started to rain.
1970 White Beetle "Delilah"
vsb74
vsb74 is offline
PostPosted: Sat Aug 23, 2008 10:21 pm    Post subject: Reply with quote
Installed new fuel lines, moved the fuel filter out of the engine compartment and put it under the tank. Also fixed the horn and replaced the front bumper. Not a bad day!
whutdidyousay
whutdidyousay is offline
PostPosted: Sat Aug 23, 2008 11:25 pm    Post subject: Reply with quote
I let her sit while I put 180 miles on my Jimmy..... went to a couple peoples houses I met on craigslist to get parts for her. I got:
Oil cooler & seals
doghouse shroud
COMPLETE tune up parts
COMPLETE fuel system
Headlight eyebrows
Shifter
Degree pulley
Chrome generator pulley
Generator belt
all the stuff to do an oil change
" " trans oil change
I also got some tools....... was alot of fun, but tomorrow will be even better.... I have a friend coming over to pull the engine with me and i'm gunna go pressure wash the motor then go to town makin her perfect.
'68 bug (Sadie)
danke meine Freunde
I'm tryin to build a dream one piece at a time, just bear with me.
Hophead
Hophead is offline
PostPosted: Sat Aug 23, 2008 11:48 pm    Post subject: Reply with quote
Oil cooler & seals
doghouse shroud
Headlight eyebrows
Shifter
Degree pulley
Generator belt
Wow, thats a good haul. I went to my local junyard last week and all I got was a steel degree pulley, 1.5 qt deep sump, and full flow oil system. All made by Gene Berg for $ 30.00. Very Happy
2110cc
82 X 90.5
P&P 043 40x35.5
9.6-1 comp
FK-8
48 IDA
73BuzzBomb
73BuzzBomb is offline
PostPosted: Sun Aug 24, 2008 1:01 pm    Post subject: Reply with quote
took it to a show in Gainesville, GA.
'73 Super
2270 type IV
bon2198
bon2198 is offline
PostPosted: Sun Aug 24, 2008 1:05 pm    Post subject: Reply with quote
drove it to work today. got stuck in the rain on the way home. when i got home i noticed that the carpet on the passenger side was a bit damp. pulled out the passenger seat and took out the front carpeting. sure enough there is water on the floor. now to find the source.... grrrrr... it's ok, i've been meaning to pull the interior and Rust Bullet the inside followed by rhino liner.
JeffDeWitt
JeffDeWitt is offline
PostPosted: Sun Aug 24, 2008 1:10 pm    Post subject: Reply with quote
Afraid all I did with the Bug today was drive it, I've got a lot of yard work that I've been putting off far to long.
Funny thing though, TWICE yesterday I had carloads of young guys (early teens I think), give me a thumbs up and tell me I had a cool car!
mnussbau
mnussbau is offline
PostPosted: Sun Aug 24, 2008 4:53 pm    Post subject: Reply with quote
Squeezed the body moldings on both my bugs just a bit to tighten it up, the molding keeps popping off the plastic clips at the ends.
Mike
‘74 bug vert
Parts...
vugbug68
vugbug68 is offline
PostPosted: Sun Aug 24, 2008 10:55 pm    Post subject: Reply with quote
did an oil change (with shell rotella) Wink , valve adjustment, put my 019 back in and timed it. then went over to my friends house and helped him do the exact same thing on his bug plus spark plugs
71 Super
66 Corvair
69 Baja Bug
Hophead
Hophead is offline
PostPosted: Mon Aug 25, 2008 12:31 am    Post subject: Reply with quote
Today I checked oil supply galley in the right hand case half against the Berg blueprinted oil pump. Pretty close. It looks like I will need to shave .040 off of case hole towards the oil pump flange. The case cleaned up pretty fast with the dremel last night.
2110cc
82 X 90.5
P&P 043 40x35.5
9.6-1 comp
FK-8
48 IDA
ArmedGeek
ArmedGeek is offline
PostPosted: Mon Aug 25, 2008 2:17 am    Post subject: Reply with quote
Burned up a bucha wiring. Small fire. no damage tho. other than the wiring of course.
Gee, now i have something to do this weekend.
1973 Std Beetle
"Work is punishment for failing to procrastinate effectively."
Page 2 of 460
