ALB Samba Member
Joined: August 05, 2008 Posts: 3506 Location: beautiful suburban Wet Coast of Canada
Posted: Tue Aug 21, 2012 6:27 am Post subject: |
| durfeec wrote: |
| chrisdiehl wrote: |
| I'm glad I ran across this. I installed j tubes a couple of weeks ago and hadn't heard of these sleds until now. Stupid question.....engine doesn't have to be out to install right? |
sleds are used even with factory heater boxes. they are what protect your push rod tubes. and it would be easier to install with the motor out since they bolt to the backside of the cylinder head tin. the tin that this thread is about is something different than just a sled and can be installed without removing the motor. |
They do more than protect the pushrod tubes, they direct the air so it can join the airstream under the car while it is in motion. The faster the car is going, the harder it is for the expelled cooling air to join the airstream with out the sled tins and either heaterboxes or industrial tins. This layer of air under the car can be as much as 2psi higher than the air trying to exit the lower cylinder shroud area. This is why a car without the sled tins and heaterboxes or industrial tins will seem to cool okay around town but overheat at highway speeds. _________________ On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!! |
volkaholic1 Samba Member
Posted: Wed Aug 22, 2012 1:39 pm Post subject: |
also, if you are running the thermostat with J pipes, you MUST run all the lower tins, heater box sleds, 2 /4 lower rear air deflectors and industrial shields, or else the stat will see cooler air from below the engine and not open enough, or may not open at all = overheated engine. I've been making and selling them for years. _________________ Volkaholic |
gti1977 Samba Member
Posted: Wed Aug 22, 2012 9:55 pm Post subject: |
| I`m restoring and tuning type 4 2,0 wich have exchaust ports down of the heads.I plan to not use heater boxes.Are exist tins for this engine for J-tube use ? |
jeff68 Samba Member
Joined: November 02, 2007 Posts: 306 Location: Sarasota, Florida
Posted: Thu Aug 23, 2012 6:02 am Post subject: |
| FYI - The Bergs also sell the industrial tins. |
Dwayne_71SB Samba Member
Joined: February 26, 2009 Posts: 277 Location: Atlanta, GA
Posted: Thu Aug 23, 2012 7:05 am Post subject: |
| volkaholic1 wrote: |
| I've been making and selling them for years. |
I seriously considered buying yours, and would have if it weren't for the fact that I enjoy making things myself. Yours are definitely very nice and worth the money for anyone who doesn't want to DIY.
These are the ones I made, ended up painting them black to keep them from rusting:
_________________ '71 Super Beetle |
ALB Samba Member
Posted: Thu Aug 23, 2012 8:24 am Post subject: |
Nicely done, Dwayne! _________________ On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!! |
71beigeSB Samba Member
Joined: February 05, 2012 Posts: 96 Location: Gun Barrel City, TX
Posted: Tue Sep 11, 2012 4:41 am Post subject: |
Our 71 super is only go'n to be a weekendend ride & Texas has rather mild winters.
What pieces do I need to change to go with the Jtubes & Ind tins? Heard I need to change/modify the doghouse. The motor is still out while we did some body repairs. _________________ The deeper I dig the Worse it gets.....
71 Super Beetle stock 1600 dp
rattle can Pink & Black |
AlteWagen Troll
Posted: Tue Sep 11, 2012 9:26 am Post subject: |
| The industrial tins just fill the hole left when the heater box is removed. They are held in place with two screws where the heater box attached to the sled tin. No modification to the doghouse is required. |
Doodoob Samba Member
Joined: April 22, 2009 Posts: 267 Location: La Luz, NM
Posted: Sun Sep 23, 2012 11:16 am Post subject: |
I recently made up my own lower tins as I am running an old school S&S Header and it runs even closed to the push rod tubes and more inboard than most. So using the stock sleds and tins wasnt realy an option without a lot of cutting.
[/img] |
Yarkle  Samba Member
Joined: August 03, 2009 Posts: 1262 Location: the Hills of Western Maine
Posted: Tue Dec 25, 2012 6:06 pm Post subject: |
| Could you run these with the heaterboxes? would it make any difference? |
75smith Samba Member
Posted: Tue Dec 25, 2012 6:35 pm Post subject: |
these replace the heater-boxes, so if you have heater-boxes you don't need/can't run these
these fill the void that a heater-box would fill normally _________________ My 1975 Beetle Build Updated 8-21-12
My engine build |
Yarkle  Samba Member
Posted: Tue Dec 25, 2012 8:26 pm Post subject: |
| ok, cool..thanks. Thats what I thought! |
clonebug Samba Member
Joined: January 29, 2005 Posts: 4130 Location: NW Washington
Posted: Tue Mar 12, 2013 12:41 pm Post subject: |
I made mine from some cheap roofing flash material. It's easy to cut and bend to whatever shape you need.
Flashing
Trim it down
Find a way to bend it...
Trim it and bend to fit.
I use a small one inch by two inch piece of the waste and make a 90 degree bend in the middle and drill a hole to use it as a stop to hold the bend.
Trim the length to fit....
Test mount and drill the holes to mount the existing tin and you have sleds for about $4.00 in parts and a half hour or so labor.
| richardcraineum wrote: |
| I'm so ignorant of efi I don't even know the difference between batch, sequential blah blah blah .. |
| cbeck wrote: |
| His user name in a previous life was dick head. |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
mrmarcdude Samba Member
Joined: December 15, 2005 Posts: 714 Location: Vacaville, Ca
Posted: Fri Apr 12, 2013 5:26 pm Post subject: |
Altewagon, this thread rocks! I have recently been thinking of fabricating some myself, and your plans are perfect. It gets pretty hot here in California, and I would love to do everything I can to ensure that my motor stays nice and cool. Thank you!  _________________ - Marc M.
-65 Beetle -1600dp- |
Mikedrevguy Samba Member
Joined: October 15, 2008 Posts: 2304 Location: No. Idaho
Posted: Mon Apr 10, 2017 5:43 pm Post subject: Re: Type 181 / 126 - Industrial heater box delete tin |
Better late than never?
Finally got round to fabbing some up.
First attempt helped me realize that to accommodate the AJsims headers I ran, I had to cut the sleds.
Round two fit better. Plus, I have a set ready for stock sleds, if/when I get round to that.
Not pretty, but, should do the trick.
_________________ 74 1303 (RevBug): plan for German Look
76 914 with 2260
69 Bwajaja
"The wise speak because they have something to say; while the foolish speak because they have to say something." Plato
Illigitimi non-Carborundum!! |
daos Samba Member
Joined: January 01, 2017 Posts: 312 Location: Stockholm, SWE
Posted: Sat Jun 01, 2019 12:40 pm Post subject: Re: Type 181 / 126 - Industrial heater box delete tin |
here's my contribution to j-tube heater box delete cooling tin goodness, this is for a 1969 type 3.
made in 1mm alu. drilled/tapped the 2 round protrusions on the heads. it's almost as if they were made specifically for this purpose.
been running a little hot without these, hope they help.
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80472 Location: Sneaking up behind you
Posted: Sat Jun 01, 2019 12:47 pm Post subject: Re: Type 181 / 126 - Industrial heater box delete tin |
I'm using the real deal.... not that hard to find.
_________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
jason Samba Member
Posted: Sat Jun 01, 2019 6:37 pm Post subject: Re: Type 181 / 126 - Industrial heater box delete tin |
| Daos’s look better and screw to head, better design. |
daos Samba Member
Posted: Sat Jun 01, 2019 11:57 pm Post subject: Re: Type 181 / 126 - Industrial heater box delete tin |
i'll take that
a nice bit of alu is hard to beat though. and there's also the satisfaction of doing something yourself, when you can. |
