oil cooler seals...once again
Page: Previous  1, 2
Bobnotch
Bobnotch is offline
PostPosted: Thu Oct 14, 2021 5:25 pm    Post subject: Re: oil cooler seals...once again Reply with quote
Simon DeCasas wrote:
What is he part number for the 10mm seals I get conflicting answers and are planning to run 10mm case and 10mm cooler, but I also have 10mm coolers and a 8mm case so I'm at a loss.
I just get a complete rebuild gasket kit, as there are other things I might be sealing up. As KTPhil pointed out above, it might actually be easier to pull the engine to replace the seals.
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
ataraxia
ataraxia is offline
PostPosted: Fri Oct 15, 2021 8:42 am    Post subject: Re: oil cooler seals...once again Reply with quote
In your shoes - I'd focus on the sizes and not the part number. I bought all three sizes at one point because I had a similar situation and it was cheaper than paying shipping twice.
tjmartin317
tjmartin317 is offline
PostPosted: Sun Apr 21, 2024 2:08 pm    Post subject: Re: oil cooler seals...once again Reply with quote
KTPhil wrote:
yoyoma wrote:
Hello, where is the oil cooler and seals located and how are they accessed on a type 3? 1971 fuel injected, specifically.
The manuals will tell you about pulling runners, wires, hoses, tin, and such.
But depending on what's up with your engine, it may be better to drop the engine and do other cleanup/refreshing while it's out. Trying to do it in the car is a PITA so it's a worthy tradeoff.
Reviving this old thread but this is the question: noticed my cooler seals are leaking like a mother-effer… I started unscrewing as many as those flathead screws as I could without removing anything. Got five on the FI side including one facing up. It is a royal pain getting to them and I’m not exactly sure I’m getting all of them. But I also know that the generator has to come out, which I’m not looking forward to. But I’m torn whether or not I want to remove the engine again to do this… other things could be refreshed, it’ll just be more engine shenanigans…
Idk what advice I’m looking for, I think I was just musing… should have posted this on the complaining about Type 3s forum
Page: Previous  1, 2
Page 2 of 2
