williamM Samba Member
Joined: August 07, 2008 Posts: 4342 Location: southwest Arizona
Posted: Wed Mar 01, 2017 8:35 pm Post subject: Re: My Engine-Need Thoughts, Several Questions |
williamM wrote: |
williamM wrote: |
while shopping round
i saw some mufflers at "the thing shop" which were quite reasonable.- like less than $150.
depending on your use- it might be time to do it.
once down to the oil cooler- your a few screws away from total exposure. |
Just went there and not a muffler in sight- was round "black friday" I saw them- must have been a lost leader- Should have bought one then suppose. |
Clip 1 has the muffler for $115- but then want $80 for the 2 tailpipes.- If you can rescue tail pipes - it might work.
Empi makes one for $135. _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5843 Location: Wamego, Kansas, USA
Posted: Thu Mar 02, 2017 4:05 am Post subject: Re: My Engine-Need Thoughts, Several Questions |
saw that 2 piece- "real money" exhaust system like you have so maybe trying to coat your might keep it safe for a while. _________________ some days I get up and just sit and think. Some days I just sit.
ente_kaefer Samba Member
Joined: August 22, 2013 Posts: 242 Location: St Louis, MO
Posted: Thu Mar 02, 2017 8:07 am Post subject: Re: My Engine-Need Thoughts, Several Questions |
The link above would be the 'quieter' option, as it is basically stock. I have the Tri-Mil header on my vehicle, definitely loud, but at the time I purchased my vehicle, it was the only option outside of using the Type 1 / Beetle 'pea shooter' exhaust system. Plan this year is to replace the Tri-Mil with the stock set up, I have a 1973 Thing. |
Posted: Mon Mar 20, 2017 2:26 pm Post subject: Re: My Engine-Need Thoughts, Several Questions |
So I think for now, I'm going to just drop the engine and reseal it. Maybe I'll get lucky and find that torquing down the heads after doing the pushrod tube seals will bump up my compression on the one cylinder.
However, unless I find something really ugly, I will just seal up the motor and call it good for the summer. It is leaking way too much to be able to drive it this summer without risking further damage. For now, I want to just get it to where I can drive around town in the summer and not worry about that.
It has been a while since I've done much of anything with a Type 1 motor, so I want to make sure I've got everything coming.
I want to drop the motor and replace every oil seal I can without splitting the case. Also will replace the input shaft seal on the transmission.
If I remember my T1s correctly, I'll have to remove the gland nut to do the seals on the flywheel, and the gland nut will have to be replaced, right? It looks like from the pic that the needle bearing is a part of the gland nut. Is that correct?
Does this look like a good shopping list? Is there anything not included in the 1600 oil seal kit I would need? Did I accidentally add anything that IS in the 1600 kit?
Here is my shopping cart so far. Looking for any other suggestions of "while you're in there" stuff I didn't think of. I will add a clutch kit.
_________________ Dave Cook
1973 Wild Westerner
My Thing |
citroen Samba Member
Joined: February 28, 2010 Posts: 1578 Location: louisville ky
Posted: Mon Mar 20, 2017 4:07 pm Post subject: Re: My Engine-Need Thoughts, Several Questions |
I dont see the seal on the transmission shaft the seal that you have listed is the final drive seal under the cv joints |
Posted: Sat Jun 10, 2017 5:59 pm Post subject: Re: My Engine-Need Thoughts, Several Questions |
I finally got to working on resealing this engine today. Poor Thing has been sitting in my driveway incapacitated for a few weeks now. (Also needs front end work.)
Anyway, got the motor out and largely torn apart this afternoon. Now I have a few questions.
First, while removing the heads (to do the pushrod tube seals) two studs came out of the block. They are both the upper front studs on either side. Is this a big deal, or can I just screw them back into the block and and torque it down?
Second, it occurred to me that I don't seem to have any thermostat bits. Did Things possibly not come with a thermostat, or did a PO get in there?
Third, there isn't an actual oil seal behind the rear pulley is there?
Finally, do you see anything concerning with the following head or jug pics?
Note the large puddle and general mess. This was the impetus for the whole project.
Driver Side
Passenger Side
How it sits in my garage at the moment.
1973 Wild Westerner
My Thing |
Posted: Sat Jun 10, 2017 7:19 pm Post subject: Re: My Engine-Need Thoughts, Several Questions |
thats a satisfying pile of parts. you might want to bag that oil cooler as contamination there is just as bad as your engine block holes.
soak those PR tubes over night in gas - then run a brush thru them- I put my thumb over one end an blow in the other to see if they have cracks.
First cylinder to head sealing in an old motor I ve seen in a long time. As far as the h studs go- put some sealer on them and screw them back in.
Ya know- new AA 1600 piston and liners are under $150.
just saying- _________________ some days I get up and just sit and think. Some days I just sit.
Posted: Sat Jun 10, 2017 8:17 pm Post subject: Re: My Engine-Need Thoughts, Several Questions |
williamM wrote: |
just saying- |
Thanks! I guess you're saying that the cylinders look to have been sealing well to the heads. Yes, I was happy to see that there wasn't any leaking/damage there.
Are those $150 pistons and cylinders any good? How about rings? I did have a little bit of low compression on one cylinder before taking it apart...
Everything came apart without too much drama. The only thing is that one exhaust stud broke off at the head. I first tried the heat and wax trick to loosen it up, but that didn't work. It just broke closer to the head.
I tried welding a nut several times but it kept breaking off at the weld. So I think I'll have a machine shop get it out at this point--I don't want to damage it. _________________ Dave Cook
1973 Wild Westerner
My Thing |
Posted: Sat Jun 10, 2017 8:21 pm Post subject: Re: My Engine-Need Thoughts, Several Questions |
Oh, and good tip on testing the push rod tubes for leaks. I'll do that.
As far as cleaning all the muck off--
A couple weeks ago, I installed a hot water hose bib on my house. So with some mineral spirits and degreaser, the blazing hot water was able to melt through a lot of the gunk and grease. If at all possible, I highly recommend installing a hot water hose bib!
I also built a free-standing shower that I can supply with garden hoses. So I can clean up outdoors without getting the tub all greasy after projects like this. _________________ Dave Cook
1973 Wild Westerner
My Thing |
Posted: Sun Jun 11, 2017 9:13 pm Post subject: Re: My Engine-Need Thoughts, Several Questions |
sounds like your well under way  _________________ some days I get up and just sit and think. Some days I just sit.
Posted: Sun Jul 09, 2017 1:43 pm Post subject: Re: My Engine-Need Thoughts, Several Questions |
Well I had a goal of getting to drive the Thing to the softball game today. Ain't gonna happen! Darn it!
One thing that was missing from that shopping list pic from May, I just discovered, is the crankshaft oil seal! Why would a full gasket set not include that? So frustrating.
So if anyone else is thinking they will tear apart their motor and replace all the oil gaskets and seals, please add that to your shopping list or you will be similarly disappointed.
The FLAPS will have one tomorrow so I will be able to proceed then. Oh well.
As far as the exhaust, I did disassemble the system, welded up a couple more tiny holes (what seemed to work best was to cut a small piece of sheet metal to cover it, and weld on top of the sheet metal. Otherwise it would blow through easily), and welded some pieces of pipe to the flanges for the tail pipes, as those were rusted pretty badly. I also welded up the EGR port.
I also discovered that the engine gasket set only comes with 4 of the exhaust gaskets, where you need six, at least with a Thing exhaust setup. You need two more for the back pipe to muffler flanges. I ended up using some exhaust silicone sealant on two decent gaskets.
I think in the end, the exhaust should be quite a bit quieter.
Can't wait for that seal to come tomorrow and possibly get the engine in. Though I had talked about going to the lake with a friend, so I guess we'll see if that happens. _________________ Dave Cook
1973 Wild Westerner
My Thing |
Posted: Mon Jul 24, 2017 8:41 am Post subject: Re: My Engine-Need Thoughts, Several Questions |
Glad to see your up n running- mine just got a nose job to correct the PO butcher job- looks great- wish it wasn't so far down the "Things to do list."
Might consider another oil change after having all the innards exposed like that. _________________ some days I get up and just sit and think. Some days I just sit.
