Turn signal flasher relay images and part numbers
Page: Previous  1, 2
70bus
70bus is offline
PostPosted: Mon Jun 23, 2025 6:59 pm    Post subject: Re: Turn signal flasher relay images and part numbers Reply with quote
SWF BGC 200532
6v 2x18W
Craig K
70 Neunsitzer
65 Pritschenwagen
Raul the 65 singlecab
Karl the 70 nine-seater
70bus
70bus is offline
PostPosted: Mon Jun 23, 2025 7:03 pm    Post subject: Re: Turn signal flasher relay images and part numbers Reply with quote
SWF BGD
Multiple versions; see box for volts and watts of permutations
this appears to be BGD0, 12v 3x15W
Craig K
70 Neunsitzer
65 Pritschenwagen
70bus
70bus is offline
PostPosted: Mon Jun 23, 2025 7:08 pm    Post subject: Re: Turn signal flasher relay images and part numbers Reply with quote
Tung-Sol 268
6v
Craig K
70 Neunsitzer
65 Pritschenwagen
70bus
70bus is offline
PostPosted: Mon Jun 23, 2025 7:12 pm    Post subject: Re: Turn signal flasher relay images and part numbers Reply with quote
Wagner 559
Tung-Sol 559
12v
Tung-Sol in Wagner box. One version has paper disk with newer terminal ID
Craig K
70 Neunsitzer
65 Pritschenwagen
70bus
70bus is offline
PostPosted: Mon Jun 23, 2025 7:17 pm    Post subject: Re: Turn signal flasher relay images and part numbers Reply with quote
Webasto WBST29-2/18
6v 2x18W
Craig K
70 Neunsitzer
65 Pritschenwagen
70bus
70bus is offline
PostPosted: Mon Jun 23, 2025 8:07 pm    Post subject: Re: Turn signal flasher relay images and part numbers Reply with quote
211953215a
12v 3 terminals; ground through screw or extra ground wire
SWF BGE 200722
Craig K
70 Neunsitzer
65 Pritschenwagen
70bus
70bus is offline
PostPosted: Mon Jun 23, 2025 8:10 pm    Post subject: Re: Turn signal flasher relay images and part numbers Reply with quote
211953215c
12v
Bosch 0336401004
Hella 96M1J2(4)x21W
Stribel SKF 675
Hella may be USA, Stribel Europe
Craig K
70 Neunsitzer
65 Pritschenwagen
Page: Previous  1, 2
Page 2 of 2
