The Stupid Question Thread
Page: Previous  1, 2, 3 ... 138, 139, 140
Cusser
Cusser is offline
PostPosted: Wed Jul 16, 2025 6:39 am    Post subject: Re: The Stupid Question Thread Reply with quote
Tahlequah wrote:
https://vwparts.aircooled.net/Piston-Cylinder-Set-88mm-x-69mm-Forged-Slip-In-p/mahlet188f.htm
has this kit been discontinued? if not, how do i find it? please help, ive got engine tore down and from best i can tell this i the kit they had in it.
Consider a slip-in 87mm cylinder and piston set; this will have slightly thicker cylinder walls - which some like - and will fit right in.
BCE56
BCE56 is offline
PostPosted: Sun Jul 20, 2025 12:27 pm    Post subject: Re: The Stupid Question Thread Reply with quote
A little help?
What color should I paint the bumpers?
SEM Trim Black (to match body moldings)
Seymour Stainless Blast (semi-gloss gray metallic)?
=BCE56=
'86 Syncro Tintop EJ22, OBD II SmallCar adapter plate conversion
'96 Volvo 850 Turbo
'69 Frankenbug now driven daily.
OldSchoolVW's Premium Member
OldSchoolVW's is offline
PostPosted: Sun Jul 20, 2025 12:35 pm    Post subject: Re: The Stupid Question Thread Reply with quote
BCE56 wrote:
A little help?
My opinion ... black to pick up on the trim and wheels would look sharp.
Maybe post a a survey in this forum?
https://www.thesamba.com/vw/forum/viewforum.php?f=1&sid=646ca8ae012d090c5c54bcfd7123f7f8
Tom
"Following distance is proportional to IQ."
"It's okay to think."
"If you don't do it this year, you'll be one year older when you do." Warren Miller
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
'73 Type 3 Fastback
BCE56
BCE56 is offline
PostPosted: Sun Jul 20, 2025 5:04 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Local survey results: Black wins 6:1.
Proceeding accordingly.
=BCE56=
'96 Volvo 850 Turbo
whodunititmate
whodunititmate is offline
PostPosted: Wed Jul 30, 2025 2:35 am    Post subject: Re: The Stupid Question Thread Reply with quote
To change the rubber seals for the vent window/quarterlights in the doors do I need to pull the door apart completley or can I get away with removing the rivet that forms the hinge (for lack of a better word) and lifting the assembly out?
Cusser
Cusser is offline
PostPosted: Wed Jul 30, 2025 1:23 pm    Post subject: Re: The Stupid Question Thread Reply with quote
That's not a stupid question at all.
However, not detailing what year and whether sedan or convertible keeps that in this category...
And explain "quarterlights" for those in USA please.
whodunititmate
PostPosted: Wed Jul 30, 2025 7:17 pm    Post subject: Re: The Stupid Question Thread Reply with quote
I can see how that bit of info missing would keep it in this category, or the one of smart question/stupid owner. The car is a 72 super sedan. Quarter lights being the push out bits of glass in the doors.
vamram Premium Member
vamram is offline
PostPosted: Wed Jul 30, 2025 7:38 pm    Post subject: Re: The Stupid Question Thread Reply with quote
Yes you have to remove the door pull, door card and main window glass and then remove the complete vent window. There's a screw at the top rear edge of the vent Window's frame hidden under the felt channel that gets removed, and a bolt at the base of the vent window frame that holds the lower frame to the metal door panel. Remove these then you sort of tilt the vent window frame back and pull it out. It can be fidgety, careful not to damage the scraper. Then you need to remove the vent glass from the frame to remove the old seal and install the new one.
Click to view image
Save the Supers!!
Page 140 of 140
