DAIZEE Samba Member
Joined: January 26, 2010 Posts: 7552 Location: Greater Toronto Area Ontario West Side
Posted: Fri Mar 23, 2012 7:47 pm Post subject: |
Peppermint Oil (not fragrance) is on the soaked cotton balls locked into the glass jar with metal lid with nail holes punched in it. How could they defecate on the cotton balls? Did you leave all your cupboards open and take as much off the dash and front as you could so they wouldn't have any dark places?
At the garage, they are always overrun with mice who have made holes of entry. I put a set up at each hole and where ever i found nests and droppings, including the washroom, kitchenette and lunch room and not one turd! _________________ '09 2.5L Jetta 5 cylinder, 5 spd, super turbo, see thread in H2O Cooled Jetta, etc...
84 Vanagon GL Wolfsburg Westy WBX 4 speed (sold) |
Salem7 Samba Member
Joined: January 24, 2010 Posts: 229 Location: Washington County, New York
Posted: Fri Mar 23, 2012 8:10 pm Post subject: |
I put drops of the peppermint oil on cotton balls and put them throughout the van, drawers, cabinets etc. As always everything that could be a problem was removed, no food items what so ever! These were instructions I picked up somewhere. Definitely mouse poop everywhere! _________________ 1982 Westfalia 1.6NA diesel. Converted to Turbo 1.6 and sold.
1995 Eurovan Camper Winnebago, early serial number 5 speed |
Congaman Samba Member
Posted: Sat Mar 24, 2012 5:38 pm Post subject: |
Found a box of tongue and groove bamboo flooring left over from when the house was built. Had literally just enough to make a floor for my new 1981 Vanagon. Literally only 12 inches of flooring left over. Took 30 minutes.
davesclassicvws Samba Member
Joined: January 09, 2003 Posts: 55 Location: Camas, WA
Posted: Sat Mar 24, 2012 9:41 pm Post subject: Installed in line blower to heater system |
Went through the heating system on my 82 Westy today. I discovered that one valve wasn't connected. Adjusted the other side to ensure the valve opens completly. Adjusted the control cables in the dash. Installed a new switch and fan.
Wow what a difference the fan makes. Leaving on a trip to the coast next weekend. It will be nice to have heat. _________________ 1969 VW Beetle
1972 Karmann Ghia
1982 Vanagon Westfalia ('OlBlue)
2000 New Beetle |
mariusstrom Samba Member
Posted: Sat Mar 24, 2012 9:46 pm Post subject: |
Installed my new Das Mule rock sliders.  |
tarandusVDub Samba Member
Joined: August 27, 2010 Posts: 1683 Location: Between Here and There
Posted: Sun Mar 25, 2012 8:20 am Post subject: |
My daughter and I replaced the felt channels and scrapers on driver's and passenger's windows. The old soap and water trick is a must. We have an icy fog this morning, and the seals look guttentite. Another wee item on the honey do list is done! _________________ 1990 Syncro 16" DoppleKabine 2.1 DJ 112i
________________________
Sold: 1972 Bay Campmobile; 1984 Westy, base model, 2WD. |
Syncronoid Samba Member
Joined: January 21, 2012 Posts: 1120 Location: Stanford, CA and Bend, OR
Posted: Sun Mar 25, 2012 6:18 pm Post subject: |
Finished installing the deep cycle battery, Truckfridge, Inverter and Charger... Westy Ventures style. Thanks for the help Karl!! Next up, wiring it all up. Complete Syncro before/after photos coming to a new post this week.
kamzcab86 Samba Moderator
Posted: Sun Mar 25, 2012 9:06 pm Post subject: |
Yesterday: Installed new hook-ups, center floor mat, and new AZ Centennial license plate.  _________________ 1986 Cabriolet: www.Cabby-Info.com
2016 Golf GTI S
lemonspeed Samba Member
Posted: Sun Mar 25, 2012 9:08 pm Post subject: |
shoveled the snow from around Clem, car cover removed and battery back in to charge.....found a few exploded water bottles from winter freeze ....and a little mold - Day one of van life for 2012 felt good _________________ Instagram : @overland_van
90 Vanagon Carat "domino"
81 Westfalia (sold) "clemintine"
73 Transporter (sold) "chloe"
80 Vanagon (sold) "brownie" |
DAIZEE Samba Member
Posted: Mon Mar 26, 2012 1:02 pm Post subject: |
more wire connections, put new seal on front signal lights, mounted 2 new(er) visors and missing hardware, oh right and put the 2 steering column brackets back on. Looked all over for my rear lights, couldn't find them so looked at the rear of the van and there they were, where they are supposed to be I'm using the spray silicone to create new seals where the rotted gasket was. Been getting water in my lights. Also going to drill minute draining holes at lowest level. _________________ '09 2.5L Jetta 5 cylinder, 5 spd, super turbo, see thread in H2O Cooled Jetta, etc...
Milfordite Samba Member
Joined: August 18, 2011 Posts: 43 Location: United States
Posted: Mon Mar 26, 2012 5:03 pm Post subject: |
Took a ride in our Westy for the first time in 4 or 5 months today. Over the winter I rebuilt the engine, resealed the transaxle, all new CV joints, complete new cooling system from the radiator back, all new fuel lines and gas tank, new Koni shocks, new rear bushings, new wheels and tires and some other stuff I 'm forgetting about. Next is to redo the A/C system, add an inverter and a new radio. Whew! Runs great, very happy to have it back again! I missed my baby!  _________________ 1990 VW Vanagon westy |
jashv Samba Member
Joined: September 01, 2004 Posts: 442 Location: Shepherdsville, KY
Posted: Tue Mar 27, 2012 5:44 pm Post subject: |
Drove it Saturday, battery is 100% dead on Sunday, can't determine why. The primary battery won't hold a charge and neither will the secondary Guess I'll be buying a battery very soon. - They were old anyway. |
westynova Samba Member
Joined: December 14, 2008 Posts: 209 Location: Nova Scotia, Canada
Posted: Wed Mar 28, 2012 1:42 pm Post subject: |
Went by the storage facility to have a look at her. Still too cold out and too much residual salt on the road. Will have another look after the Easter Weekend. My have it towed to the house so i can do a bit of work in the driveway. Getting excited for the 2012 driving/camping season. _________________ 84 Westy
2010 VW Golf TDI Wagon
2009 Jeep Rubicon Unlimited, Lifted and Locked |
teej Samba Member
Joined: November 26, 2010 Posts: 908 Location: Seattle
Posted: Wed Mar 28, 2012 9:06 pm Post subject: |
Changed the manual trans gear oil. After much reading here, switched from Redline MT-90 to Swepco 210.
Broke two Flaps hand pumps--bad batch? In any case, simple proved better for me--funnel and tube through the wheel well worked a charm. _________________ 1986+ Wolfsburg Weekender Pop-Top 2.3 WBX Manual Trans |
Jon_slider Samba Member
Posted: Thu Mar 29, 2012 1:24 pm Post subject: One more mystery solved. Spade connector corrosion |
I have already had my fridge out and cleaned, and it was working until recently. The fridge LED would light up when running the motor, with the fridge source selector in Battery position.
A few days ago, the LED stopped lighting. So I went to Radio Shack and bought the Blue LED #276-0311 and soldered it in. Still no light.
I went to VanCafe and asked if there were any fuses to the fridge, they said to check the ones in the black plastic box by the driver door. The fuses were good.
Then Chris at VC, my hero for today, asked if possibly any of my fridge electric connectors under the sink might have come loose, so I checked.. no, they were all tight..
but I decided to unplug and reconnect them.. After unplugging the single black wire junction, and plugging it back in, I started the engine with the Fridge in Battery mode, and the Fridge light now Works!
Moral of the story, spade connectors corrode with time and make poor contact..
Now Im ready for Death Valley, with more than just canned food.. I get to bring some burgers and sausage for the grill.. _________________ My Soapboxes: Inflation; Handling; Gearing; Decoupling; Swepco |
schoonerman Samba Member
Posted: Fri Mar 30, 2012 11:01 pm Post subject: |
Tune up time,
Changed fuel filter...air filter..plugs...dizzy cap..rotor.
I cut open the fuel filter and removed the paper filter to check how dirty it was, which would indicate the condition of the fuel tank, it was possible to roll it out on the floor, like a toilet paper roll and see that it was stained in the center, but no rust particles.
Also removed the A/C compressor off the engine as I never used the A/C,
and it never worked anyhow..boy was it heavy, been carrying around a load of dead weight for 4 years, maybe the fuel economy will improve?
Roll on Spring!!!! _________________ 87 Westy/Vanagon |
brendanklein Samba Member
Joined: March 05, 2012 Posts: 14 Location: san marcos ça
Posted: Sat Mar 31, 2012 11:20 am Post subject: |
ordered up my power steering unit from bus depot... getting set to tow it to a mechanic who's gonna help do the tranny, fuel lines and install the new PS unit.
CAN NOT WAIT!  _________________ 87 tin top GL. currently residing in my driveway while I source parts.
Restoring Oscar Blog |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 8523 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Sat Mar 31, 2012 5:41 pm Post subject: |
Planned to replace front calipers, new pads & flex hoses:
- PS done except for hose, due to top nut rounded over.
I left it to soak another week...me not ready to deal with potential damage to hard lines, but caliper job not hard & went great.
- DS done except for caliper, which arrived with bent bleeder screw...now waiting for return & reorder.
So she sits...
(Earlier this week) - mounted 2 new interior grab handles (driver & slider doors)
- black satin Krylon Fusion for all door handles, window hardware & both grilles
- PB blaster rear & clutch bleeders (3x this week) prepping for brake fluid flush & full brake adjustment once hose & caliper done... _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Themasterof42 Samba Member
Posted: Sat Mar 31, 2012 8:11 pm Post subject: |
Replaced my fuel pump, fuel injectors, fuel pressure regulator, plastic fuel grommet, oxygen sensor, and water temp sensor. Tomorrow I'll give it a whirl and see if my issues are taken care of  |
Baxta Samba Member
Joined: November 09, 2008 Posts: 356 Location: Abbotsford, BC
Posted: Sun Apr 01, 2012 12:27 pm Post subject: |
Passed AirCare (smog) with flying colors, bought 3 month insurance to tide me over until I get Collectors Plates;
Replaced (very recently) dying ignition switch;
Traced wiring & gently bent connectors for the flexi-circuit board to dash connector and restored my dash lighting;
Last weekend I drilled (gasp!) the pop top to install Yakima ARGs and a corresponding kayak roof rack.
Been a good week! _________________ Greg
'87 Syncro Westy 'Bastian'
2.2l |
